Old 11-07-2009, 04:28 PM   #1
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
Default Benchmark Tuning 2001 2.5RSTi - 341WTQ / 298 WHP - Pump Gas
I am happy to announce after a few months of building our 01 2.5RS with a custom hybrid motor we put together is running with some impressive results. I will have to post the dyno graph when I get back into the shop, but this was my first chance to start the thread.
Event: Dyno
Car: 2001 2.5RS
Tuner: Matt of Benchmark Tuning
Dyno Info: Mustang Dyno
Peak HP: 298 WHP
Peak Torque: 341 WTQ
Target Boost: 21 PSI Tapering to 12 PSI at redline
Target AFR: 11.8-11.6
Fuel: 93 Octane Pump Gas (Shell)
Engine/Power Modifications: Stock un-touched VF39, Tomei Header, TGV Deletes, CP Pistons, Race ported WRX heads (stock size valves), 3" TBE, WH 900cc Injectors Custom fuel rail set-up, walbro 255, TurboXS style FMIC with reverse flow piping, GSBCS
Driveline Modifications: JDM Ver 7 STi Spec C / RA Non-DCCD Short Ratio 6 Spd with Exedy Twin Plate clutch
Suspension Modifications: Cusco Zero2 Coilovers, Aluminum Control Arms, Beatrush front control arm support bracket, and more
A stock STI will do 220-230wtq/220-230whp
A stage 2 STi is around 270-290WTQ/ 260-280 WHP.
I will have a graph for you guys soon but I can tell you we are running a speed density ROM on the stock 02 WRX ECU.
This is all in a full interior non-gutted car. Being an RS it only weighs right around 2800 lbs
Graph is here
Benchmark Tuning is offline   Reply With Quote
Old 11-07-2009, 10:51 PM   #2
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Looks good...especially on that heartbreaker of a dyno. Wonder what it'd put down @ Komet.
Why 12psi @ redline? Talk to you next week.
zeropsi is offline   Reply With Quote
Old 11-08-2009, 02:04 AM   #3
CatfaceType-R
Member#: 81102
very nice, should be a low 12's car
CatfaceType-R is offline   Reply With Quote
Old 11-08-2009, 02:30 AM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
looks good on paper
curious as to why it tapers all the way to 12psi @ redline though.
Old 11-08-2009, 03:17 AM   #5
socalLGT
Member#: 89752
08 STI
When you have heads that flow you get a wicked taper to redline
I remember tuning an LGT with a cammed, built motor but the stock VF40 a couple years ago. With a 3 port solenoid maxed out it made 9 psi at redline
socalLGT is offline   Reply With Quote
Old 11-08-2009, 11:43 AM   #6
zeropsi
Member#: 175453
AE86 GT-S coupe
That's what I had figured, since I'm fairly familiar with heads Matt put on the car, but figured I'd ask. They make my V8 EJ207 Big Ports look restrictive.
Old 11-08-2009, 08:29 PM   #7
Benchmark Tuning
Member#: 154444
paul is right, the heads flowing as well as they do will make boost taper like that. There is still a little bit left in it down low I feel, but I'm liking where it is at, at least for now.
if I can find a track still open we would definitely find out.
yep, I haven't maxed the solenoid out down low yet but up top it is pretty well maxed, and that's a Grimmspeed BCS too.
these do flow better than many race ported heads that use 1mm over valves, it was very impressive to compare
Graph is up...
Old 11-08-2009, 08:47 PM   #8
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
pics of car please.
JoeTX is offline   Reply With Quote
Old 11-08-2009, 09:55 PM   #9
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Is this a 2.5l block with wrx heads? The torque makes me wonder if it is but you mention wrx heads so im guessing a 2.5l block?!
NickWRX is offline   Reply With Quote
Old 11-08-2009, 10:48 PM   #10
Benchmark Tuning
Member#: 154444
Yes it is a 2.5 STi block with CP Pistons and Race Ported WRX heads... with stock size valves (upgraded valves and valvetrain)... Stock STi Cams
Old 11-08-2009, 11:38 PM   #11
Benchmark Tuning
Member#: 154444
a few pics for everyone
Old 11-09-2009, 06:46 AM   #12
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Who did the porting on the heads?
speedyHAM is offline   Reply With Quote
Old 11-09-2009, 07:03 AM   #13
Benchmark Tuning
Member#: 154444
The work on these particular heads was done by a guy who primarily does head work on high HP drag cars, mostly NHRA. If you would like more info you can shoot me over a PM.
Old 11-09-2009, 10:33 AM   #14
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Big_DeWeY is offline   Reply With Quote
Old 11-09-2009, 03:56 PM   #15
Prevent
Member#: 149114
Matts heads make your V8 EJ207 heads look like a rough draft ?
Matt, i cant wait to see this car at the shootout, it sounded badass at the dyno day.
Prevent is offline   Reply With Quote
Old 11-09-2009, 04:09 PM   #16
lowrider89
Member#: 143022
2005 modded S4
id drive it!
lowrider89 is offline   Reply With Quote
Old 11-09-2009, 04:12 PM   #17
tslak
Member#: 217639
2001 2.5RS
Blue Ridge Pearl
Mmmm...BRP coupe with monstah powah
Love it.
tslak is offline   Reply With Quote
Old 11-09-2009, 07:27 PM   #18
Sleeper2.0
Member#: 207976
2005 WRX Wagon
CGM
Originally Posted by Big_DeWeY View Post
Sleeper2.0 is offline   Reply With Quote
Old 11-10-2009, 11:19 AM   #19
Benchmark Tuning
Member#: 154444
Originally Posted by lowrider89 View Post
id drive it!
me too
Love it.
it's a little bit of fun...suprises a lot of people
Originally Posted by Sleeper2.0 View Post
hmmmm.....i like popcorn too whats the occasion?!?!?!
Old 11-10-2009, 11:33 AM   #20
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Showdown at the shootout is a brewin'
I hope you keep the vf39 for it. It would make for an interesting race
Old 11-10-2009, 12:14 PM   #21
Benchmark Tuning
Member#: 154444
really?....either way i'd win though if both are tuned by me
we'll see how it goes... the car might be for sale... i have a new project I have to devote my time to might want to check the for sale posts today
Old 11-10-2009, 12:25 PM   #22
Big_DeWeY
Member#: 37078
95 L
Blue-ish
It should be two different paths to the same ending though. It would be good for comparison at the very least.
Old 11-10-2009, 12:30 PM   #23
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Very true maybe it will still be.
mxturboracer86 is offline   Reply With Quote
Old 11-10-2009, 06:00 PM   #24
Sleeper2.0
Member#: 207976
2005 WRX Wagon
CGM
You vs. Dewey *
if it happens...
*no cheating by under-tuning Deweys
Old 12-21-2009, 01:12 AM   #25
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
You vs. Dewey *
if it happens...
Either way I win if I tune both cars
Element Tuned Hydra, Cosworth, Intake, 503 whp pump gas Element Tuning Proven Power Bragging 46 10-08-2009 07:16 PM
FULL 6-SPEED CONVERSION FOR A 2001 2.5RSTi SKUNK2.5 Private 'Wanted' Classifieds 1 04-23-2008 10:01 AM
716 WHP Pump Gas Gt40 M3 Dyno Flash Proven Power Bragging 51 01-25-2008 06:43 PM
Just another 300 whp pump gas Stage 2 flashed STI by Dyno Flash Dyno Flash Proven Power Bragging 7 11-03-2006 04:21 AM
Highest whp & best 1/4 mile w/ a VF39 on a 2.5L block on only pump gas? Chiketkd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-02-2006 09:42 PM
