Closed Thread
Old 11-08-2009, 03:21 AM   #1
W1lson
Member#: 140223
2015 BRZ Limited
Default 2009 Subie WRX dyno tuned at HB Speed
297.3 whp, 333.36 tq on a Dynomite dyno
Car is so much smoother now with the tune.. :laughing:
Mods: AEM CAI, Tsudo non-catted DP, Magnaflow CBE, and Cobb AP with dyno tune from HB Speed
Props to HB Speed for doing a great job!
W1lson is offline
Old 11-08-2009, 03:30 AM   #2
2006WRX4ME
Member#: 134286
2006 WRX Limited
I'm jealous of those numbers. What kind of engine management are you running?
2006WRX4ME is offline
Old 11-08-2009, 03:33 AM   #3
W1lson
Member#: 140223
2015 BRZ Limited
oops, forgot to add that, im using cobb ap
W1lson is offline
Old 11-08-2009, 03:53 AM   #4
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Your **** is slow
VladiWrX is offline
Old 11-08-2009, 02:12 PM   #5
mcganz121
Member#: 138569
2017 STI+B8A4
06STI <- 09WRX <- 06WRX
I assume stock fuel pump and tmic?
mcganz121 is offline
Old 11-08-2009, 05:32 PM   #6
@NT
Member#: 207366
Can't wait to get my '09 tuned
@NT is offline
Old 11-08-2009, 07:14 PM   #7
1cleenwrx
Member#: 170542
08 AGILEbuilt-STI
93Soarer/01RSTI/06SPEC-B
+1 thats nice! i wonder how much more it can put out with fmic, fuel pump, and injectors.
1cleenwrx is offline
Old 11-08-2009, 08:45 PM   #8
DasWRX
Member#: 187259
2009 WRX Sedan
nice!
DasWRX is offline
Old 11-08-2009, 09:25 PM   #9
WRX09MD
Member#: 222160
2014 Audi S4
Glacier White
Just got my 09 SWP Sedan Pro Tuned on a Dyno Pack Dyno. I have SPT exhaust, Invidia catted DP, Cobb Ap. Stock TMIC and fuel pump. I got 294 HP and 320 TQ to the wheels at 20 psi and lovin it.
WRX09MD is offline
Old 11-08-2009, 09:47 PM   #10
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
What kind of ricer would run an fmic with a stage 2 setup?
VladiWrX is offline
Old 11-09-2009, 05:00 AM   #11
Mecka20000
Member#: 176162
MY02 Jesus Once Told
Me, "Numbers Sell"......
Talking
the kind that wants to have it in and ready for his stage 4+ setup way way in advance and wouldn't mind the power loss i guess?
Mecka20000 is offline
Old 11-09-2009, 02:30 PM   #12
redzfit
Member#: 191518
2007 STI
Me haha!!! I will be getting retuned on the 19th from HB Speed
I will also have them install a fuel pump
redzfit is offline
Old 11-09-2009, 04:39 PM   #13
IE09WRX
Member#: 213560
09 WRX Cobb SoCal
[email protected]
How much boost are you runnin?
IE09WRX is offline
Old 11-09-2009, 04:52 PM   #14
Badler
Member#: 133597
Somebody who doesn't want heatsoak.
Badler is offline
Old 11-09-2009, 05:17 PM   #15
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
nice numbers! jesus sure as hell can tune!
mongoosaroo is offline
Old 11-09-2009, 11:52 PM   #16
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
can you please edit in the proper format?
Event: dyno pull / quarter mile
Location: shop name for dyno pull / track name for quarter mile...include city and state
Ambient Temp: in degrees Fahrenheit
Elevation: feet above sea level
Weather: sunny, cloudy, wet, dry, hot, cold, etc...
Track and Conditions: concrete or asphalt, clean or dusty, flat or running slightly up or downhill (for 1/4 mile only)
Tires: brand, model, size
Car: year, model
Tuner: name of person who tuned the car (add shop name and location if posting 1/4 mile time)
Dyno Info: brand
Peak HP at RPM: note whether or not it is SAE corrected
Peak Torque at RPM: note whether or not it is SAE corrected
Baseline hp/tq for a stock on same dyno: list numbers and note whether its WRX or STi and 2.0L or 2.5L
Target Boost: preferably in psi
Target AFR:
Fuel: not just pump gas or race gas...list octane rating and leaded or unleaded
Engine/Power Modifications: internal, external, or electronic components that directly affect power made by the engine
Driveline Modifications: transmission/gearing changes, final drive/differential changes, driveshaft changes, clutch, flywheel, etc.
Suspension Modifications: struts, springs, coilovers, braces, bushings, and other items that reduce body motion and increase power transfer to the ground
Other Modifications: weight removal, addition of a roll cage, lighter wheels or rotors, smaller than OE diameter tires, and other items that affect vehicle weight, rotational inertia, and power delivered to the contact patch
synolimit is offline
Old 11-10-2009, 03:44 AM   #17
WRrexu
Member#: 217061
2009 Wrx
I WANT DP AND TUNE aefsgdfshdsf
nice car and numbers 09 wrx FTW
WRrexu is offline
Old 11-10-2009, 04:18 AM   #18
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
That I can understand. If you've got plans for big turbo in the future might as well get the fmic now.
But for people with stock turbo's?
A large tmic will not heat soak with this size turbo unless you're sitting in traffic. And even then its not bad at all.
FMIC with such a small turbo is overkill. Kinda like the people in 1.6L n/a honda's running 4" exhaust piping.
What ever, I won't argue about it. Those that understand will understand. Those that like a big shiny intercooler with their stock turbo will always like the ricer bling. Nothing will change their mind.
VladiWrX is offline
Old 11-10-2009, 04:34 AM   #19
redzfit
Member#: 191518
2007 STI
18 psi and if I remember correctly is tapered off to like 16....
I can not wait to get tuned on the 19th, I am hoping to get 320whp on this dyno with equal wtq with the stock turbo!!!!!!!
redzfit is offline
Old 11-10-2009, 06:06 AM   #20
redzfit
Member#: 191518
2007 STI
What if your fmic is not shiny but stealth like
But more seriously from what I have seen from various 09 WRX dyno's is that people running fmic with a stock turbo are getting higher amounts of wtq....
redzfit is offline
Old 11-10-2009, 07:58 AM   #21
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
18psi you say? I'm running 21psi tapering to 16 by redline... Wonder what I'd dyno at... hmm. Oh and I'm running a FMIC, which all you nay sayers out there, I have not been bogged down by a sea of lag.
Anyway, bet the ops car is a blast
scramjett is offline
Old 11-10-2009, 10:15 AM   #22
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Please update your 1st post with the proper format found here
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline
Old 11-10-2009, 10:17 AM   #23
Wanarex
Member#: 173034
Agreed! Front mount will always more consistently cool the air.
Wanarex is offline
Old 11-10-2009, 02:41 PM   #24
redzfit
Member#: 191518
2007 STI
Here is a link to my dyno graph on the same dyno for comparison http://forums.nasioc.com/forums/show....php?t=1681620
redzfit is offline
Old 11-10-2009, 03:21 PM   #25
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Oh well that dyno was missing from the link. You should post up a 3rd gear datalog to redline. I'd be really curious to see what kind of timing you are running for those numbers and what you pull for 45-65mph.
Closed Thread
2006 STi tuned by HB Speed @ 314whp/322ft-lb Departed Proven Power Bragging 1 03-06-2010 08:36 PM
2004 Forester XT 5spd td06h-20g 8cm^2 tuned by HB speed wrxtool SCIC Private Classifieds 44 08-19-2009 05:53 PM
Robispec Suspension Day -- Sat 5/16 at HB Speed Robispec Southern California Impreza Club Forum -- SCIC 71 05-18-2009 12:28 PM
Greened Hybrid Tuned by HB Speed slowmike Proven Power Bragging 20 11-18-2008 12:34 AM
