Old 11-08-2009, 04:55 PM   #1
gazzy2000
Member#: 229236
2001 2003 BP Legacy
Default Low boost issue- done heaps of diagnostics already!
Hey,
My V5/6 STi is only boosting 10 PSI, i can reset the ECU and its boosts to 14.7, then while under boost it will do a big hestitation and an go back to 10 again and stay there. SOme thing is telling the ECU to stop or limit the duty cycle to the boost solenoid.
Used a MBC and it boosted to 15, stayed there but was very jerky at boost. I am not looking for a work around using Manual or Electronic boost controllers, i want it working factory.
I have bridged the turbo outlet to the actuator and its the same PSI, so i know the spring in the actuator is OK. Its a VF22, Car has no mods apart from Siamese DP.
I have tried:
= another ECU
= 4 boost solenoids (2 & 3 port)
= Knock sensor relocation
= another intercooler
= all new vac hoses (tried using the stock ones with different noids too)
= different sized restrictor Pills
= solder a wire stright from ECU to Boost solenoid to by-pass any problem wiring.
= 2 MAP sensors
= got new battery
= checked earths
Only thing i havent really tried an AFM.
I am running out of ideas, any help would be appreciated.
CHeers
gazzy2000 is offline   Reply With Quote
Old 11-13-2009, 01:14 AM   #2
DavC825
Member#: 201736
12 IS-F..its white
Slowest 07 STi
Have you tried a now MAF censor? What year is the car?
DavC825 is offline   Reply With Quote
Old 11-17-2009, 05:33 PM   #3
gazzy2000
Member#: 229236
2001 2003 BP Legacy
Yip, brought a brand new one and reset ECU, didnt change a thing.
ECU is a 99 00 V5/6 STI
I have a new Fuel pump and filter coming too.
I think the engine is detecting knock and pulling the boost and timing.
Old 11-20-2009, 12:16 PM   #4
DavC825
Member#: 201736
12 IS-F..its white
Slowest 07 STi
hmmm...dunno what to tell ya. maybe it needs a tune?
Turbo inlet pipe installed... Low boost issue! danimal03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-01-2006 09:46 AM
cobb '06 wrx , was there a low-boost issue related to one of the maps? jkoc AccessPort 2 02-18-2006 12:24 AM
Yet another Cobb 2.5 low boost issue eatsrice Engine Management & Tuning 10 08-29-2005 12:16 PM
Cobb 2.5 w/Deadbolt VF34 low boost issues WRC51 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-30-2005 09:50 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 01:22 AM
