Old 11-08-2009, 04:25 PM   #1
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Default 91 Legacy 4EAT into 93 Legacy
I have a donor 91 Legacy that I was going to pull the 4EAT from to put in my parents 93 Legacy (also an automatic, but its broken ). Both are non turbo.
Anyone see any potential issues with this? I'm not saavy enough on the Legacy stuff to know if the ratios/differential are different, etc.
Thanks,
Derek
SSLegacyGT is offline   Reply With Quote
Old 11-08-2009, 05:02 PM   #2
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
Only major consideration is the gear ratios...you'll have to count the number of teeth on the ring gears through the drain plug opening. If they are the same you are good to go.
04stigeorge is offline   Reply With Quote
Old 11-08-2009, 07:54 PM   #3
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Hmmm OK. Anyone know if there were different ratios for different years? I was hoping that for the year range that these models were out, that all of the NA model Legacy's would be the same.
I guess that would be the easiest way to know for sure, but I was hoping to know before even buying the donor car. Thanks for the help so far!
Old 11-09-2009, 08:02 PM   #4
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
there was generally 2 different ratios. The only way to be sure is what I suggested. Wheel and rim size can make a difference as well as models and year...too many variables to be 100% sure.
Old 11-10-2009, 02:19 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The 90-91 Legacy AWD non-turbo AT's have a 4.111 final drive ratio. The 92-94 Legacy AWD non-turbo AT's have a 3.90 final drive ratio. If they're FWD, the final drive ratio is 3.70 and are the same for the 90-94 Legacy.
Josh
Legacy777 is offline   Reply With Quote
02 legacy gt into a legacy B4 shane90 Subaru Conversions 2 12-21-2009 11:34 PM
01 RS 4EAT into 93 Legacy - Problems? SSLegacyGT Transmission (AT/MT) & Driveline 3 02-08-2009 01:08 PM
91 turbo legacy 4eat not shifting out of 2ndto 3rd willyp Pre-2002 Factory Turbo Powertrain 11 11-05-2008 09:12 PM
ej20tt into 93 legacy?? 92b4man Subaru Conversions 4 06-28-2008 03:12 AM
Legacy EJ20G into 93 L FWD skyliner33v Subaru Conversions 36 04-28-2004 04:01 AM
