Old 11-08-2009, 07:03 PM   #1
a143gsxr
Member#: 199976
2008 Sti
Default Bypassing fuel pump voltage controller??
ya'll take a look at my thread please...
http://forums.nasioc.com/forums/show....php?t=1879614
a143gsxr is offline   Reply With Quote
Old 04-03-2010, 05:39 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
bump?
Old 04-04-2010, 12:22 PM   #3
arghx7
Member#: 232940
just bypass it. cut that bitch out. as you've said, it's common to bypass the fuel pump controller on other cars. Granted, the Subaru system is a little more advanced than what you'll see on a 20 year old import with a resistor relay, but once you get more modified the fuel pump controller can be a pain.
from the factory fuel pump speed control is used for:
1) reducing noise (Whinebros are pretty loud)
2) reducing wear on the pump
3) reducing evaporative emissions by cutting back on the amount of hot fuel recirculated back to the tank
those are all valid reasons to have fuel pump control, but for a lot of us they're not super important. I've never done it on an '08 STi so I can't tell you what you may run into, but be mindful that this won't necessarily solve whatever problems you are having. Just don't wire it up to ignition power, that's ghetto.
arghx7 is offline   Reply With Quote
Old 04-08-2010, 11:04 AM   #4
240sxguy
Member#: 229791
2002 WRX wagon
I wired a relay in, and used the stock fuel pump controller to trigger the relay. Everything works just like stock, and its pretty easy to reverse if I want to. All the power etc.. is right there.
240sxguy is offline   Reply With Quote
Old 11-16-2010, 01:00 PM   #5
bettyblue
Member#: 90920
2005 2.0FPGREEN 6SPD
2002 bugeye Vf39
bringing this one back.. i just did a fuel pump in an 06 sti and i think i fried the fuel pump controller because the relay under the glove box is clicking but the pump wont fire up anyone have any expertise?
bettyblue is offline   Reply With Quote
Old 12-10-2010, 01:07 PM   #6
mpiotro
Member#: 1341
2002 WRX Wagon
Sedona Red Pearl
Using fuel pump controller to power a relay...
Will relay stay closed when factory PWM is only 33% duty cycle?
mpiotro is offline   Reply With Quote
Old 12-10-2010, 08:33 PM   #7
hectowrx
Member#: 109155
2003 white wrx ej205
[email protected] feel the panic!
how you do this and if this keeps working if you have a stand alone like hydra?
hectowrx is offline   Reply With Quote
Old 07-24-2012, 10:17 AM   #8
jayblizzo
Member#: 58957
2010 WRX STI
SSM
is it safe to use the stock positve that goes to the pump to power up a relay?
btw my fuel pump controller doesnt work.
jayblizzo is offline   Reply With Quote
Old 07-24-2012, 01:56 PM   #9
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
I put this together a few days ago.
http://forums.nasioc.com/forums/show....php?t=2382384
banshee04 is offline   Reply With Quote
Old 07-24-2012, 02:08 PM   #10
jayblizzo
Member#: 58957
2010 WRX STI
SSM
i already did this, but now my fuel pump controller doesnt work so i had run a ground to the pump for it to work.
will the positive voltage fluctuate when the controller doesnt work?
Old 07-24-2012, 02:14 PM   #11
banshee04
Member#: 179014
'06 WRX/STi
If the controller isnt working/bypassed and the pump is hard wired, then the pump will be at 100% all of the time.
Old 07-24-2012, 02:15 PM   #12
jayblizzo
Member#: 58957
2010 WRX STI
SSM
that is what i am looking to do
Old 07-28-2012, 06:09 PM   #13
scoobyman83
Member#: 250398
I'm pretty sure that if your fuel pump controller isnt working and you wired your pump according to banshee04's instruction, your fuel pump will not work either, because the relay used in his instructions is activated by voltage sent from fuel controller.
To bypass fuel controller completely, you just need to use a new wire, that gives voltage when your ignition key is turned on and you use that wire to activate the relay. I'm pretty sure that you can re-use the wire that goes from the fuel pump relay to fuel controller.
However, once you turn your ignition key, your pump will be on 100% of the time, even before you start the car.
scoobyman83 is offline   Reply With Quote
Old 07-29-2012, 11:51 AM   #14
scoobyman83
Member#: 250398
Ok, scrap that.
Bypassing the fuel controller in the fashion i described will not work.
I found the power wire that goes from fuel pump relay to fuel controller and i found the power wire that goes from fuel controller to fuel pump, however, disconnecting the fuel controller and connecting those two wires together without the fuel controller itself, will not prime the fuel pump.
Old 07-29-2012, 12:46 PM   #15
banshee04
Member#: 179014
'06 WRX/STi
Which wire did you connect? On this diagram, the black and yellow wire from the fuel pump relay is the trigger wire going into the fuel pump controller, and then the fuel pump.
So it looks like you need to remove the stock fuel pump relay and wire your own in. I would us all the factory wire except I would still run a 10ga wire to the relay insted of that small factory stuff.
Old 07-29-2012, 05:11 PM   #16
scoobyman83
Member#: 250398
I managed to figure out what my problem was, i did not notice that the fuel pump is using fuel pump control module's ground.
Which car is this diagram for btw ?
Old 07-29-2012, 05:30 PM   #17
scoobyman83
Member#: 250398
Banshee, would you by any chance have a diagram for a 2006 impreza sti ?
Old 07-29-2012, 09:26 PM   #18
banshee04
Member#: 179014
'06 WRX/STi
This diagram is for a 2004-2007 WRX/STi
Old 07-30-2012, 03:34 AM   #19
scoobyman83
Member#: 250398
Thanks, for some weird reason, the colors on the diagram do not match the colors on the plug for my control unit.
Old 07-30-2012, 11:22 AM   #20
banshee04
Member#: 179014
'06 WRX/STi
What year is you car?
Old 07-30-2012, 05:02 PM   #21
scoobyman83
Member#: 250398
2006 wrx sti
Old 07-31-2012, 10:56 AM   #22
scoobyman83
Member#: 250398
Here is my controller and plug
The colors are: black, white, black, purple/white, green/red, black/yellow.
Old 07-31-2012, 11:07 AM   #23
jayblizzo
Member#: 58957
2010 WRX STI
SSM
is there a black and orange?
Old 07-31-2012, 02:02 PM   #24
scoobyman83
Member#: 250398
No, they are colored exactly as i listed them and as you see on the picture.
Old 07-31-2012, 02:28 PM   #25
smitty5788
Member#: 267886
2011 STI
Jay, that is not an 08+ controller, our wires are not the same colors.
This is the plug to the controller on the 08+
smitty5788 is offline   Reply With Quote
Fuel Pump Voltage Controller Bypass Mod??? a143gsxr Engine Management & Tuning 0 11-08-2009 04:47 PM
STi fuel pump voltage control circuit TurboQueef Built Motor Discussion 2 09-13-2008 10:52 AM
Fuel Pump Relay Control and Airconditioner Cut Relay Control modifiedauto Newbies & FAQs 0 09-19-2007 08:43 PM
Fuel Pump Voltage?? skimmilk68 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-09-2004 12:57 PM
Can UTEC control fuel pump voltages yet Wombat North Engine Management & Tuning 3 03-28-2004 03:20 PM
