#1 |
Member#: 218783
ok so i have a 1995 impreza L AWD with a 2004 wrx motor and the stock 95 tranny
the car has sti turbo, sti intercooler, turbo back exhaust, headers, BOV, basically all the bolt ons.. problem is it does not boost past 1psi and the car will not rev past about 4600rpms... i have done the following.. took off downpipe and check to make sure turbo spins freely and it does.. i installed a impreza VSS into the 95 tranny and wired it to the stock wrx ecu and didnt work i am absolutely stumped and dont want to get raked at a shop please give me some insight the only ideas i have is taking the turbo off completely and checking it and doing a full wrx tranny swap.. what do i need to do a full tranny swap? any input well appreciated or any side job mechanics in the north jersey area
#2 |
Member#: 54026
try a manual boost controller, completely bypassing the stock unit, I would guess the waste gate has got to be opening prematurely. This would be the only way to not have boost under load. also sounds like a tune/ecu iossue if you can not physically go past the 4xxx point.
Plan: A Recheck all wiring, loop check everything if you can with a multi meter B Is the tune/ecu correct for the application C Manual boost controller see if boost can be increased manually, you can build one for about 10.00 if you know what parts to buy. |
#3 |
Member#: 218783
there is a manual boost controller disconnected on the car ill try and hook it up maybe the previous owner turned the boost all the way down
it also had a utec chip and was removed sitting in the trunk... |
#4 |
Member#: 218783
the car will go past 4600 rpm only when i let it sit for a day but once the car warms up it must read codes and limit me to 4xxx rpms ugh
#5 |
Member#: 218783
hooked up manual boost controller.. no good .. im so fustrated
#6 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
what cels is it throwing
my wild guess is bad maf or bad maf wiring |
| Thread Tools | |
| Display Modes | |
| 1995 Impreza L coupe with 04 WRX swap $6800 firm | ddschwaner | Private Vehicle 'For Sale' Classifieds | 69 | 01-05-2010 09:10 PM |
| 1995 subaru impreza L AWD swap problems HELP | ddschwaner | Factory 2.0L Turbo Powertrain | 0 | 11-08-2009 08:58 PM |
| FS MA: 1995 WRB Impreza L Coupe AWD 5MT | sportz135 | Private Vehicle 'For Sale' Classifieds | 3 | 10-02-2009 11:50 AM |
| FS: 1995 WRB Impreza L Coupe AWD 5MT | sportz135 | NESIC Private Classifieds | 26 | 08-11-2009 01:18 PM |
| FS: 1995 Impreza L-WRX: EJ205 WRX Swap | Rallycarperson | Tri-State Area Private Classifieds | 40 | 02-02-2009 09:51 PM |
