Old 05-15-2002, 12:13 PM   #1
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Default Need: VTD center diff and transfer clutch details
Can anyone give me the specifics (part number? manufacturer? detailed mechanical details or specifications?) on the VTD-AWD center differential on the 4EAT WRX?
My hunch is that it's a TrueTrac from TracTech, but I'm not sure of it. I'm not sure who manufactures the variable clutch pack, either.
I have some oscilloscope plots of the transfer duty clutch solenoid that I'd like to correlate with mechanical behavior before I give the data to everyone. I will say that it's a 10Hz PWM waveform, but I need to check my grounds because I'm getting some weird transition states.
(edit: Note, this is specifically for the 4EAT WRX.)
/Andrew
Kha0S is offline   Reply With Quote
Old 05-15-2002, 12:23 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: Need: VTD center diff and transfer clutch details
/Andrew
I'll see what I can find out.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 05-15-2002, 12:37 PM   #3
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Thumbs up
Thanks Jorge...
My big questions are:
1) Bias ratio and other details on the planetary diff.
2) Where the inputs/outputs are set up on the diff.
3) Where, in relation to the transaxle and the diff is the electro-hydraulic clutch pack?
4) What are the reasonable limits within which the electrohydraulic pack can be driven? Should it always be kept between 10 and 90% pressure levels, or can it exceed those?
5) How is the solenoid driving the clutch pack? I'd imagine that the solenoid is merely controlling a pressure valve inside the transaxle which regulates the pressure exerted upon the ram in the clutch pack, but any details would be helpful.
/Andrew
FS: Spec B 6-speed tranny, clutch, flywheel, center diff, and rear diff CHEAP dahane Drivetrain 5 12-23-2009 02:23 PM
FS: Spec B 6-speed tranny, clutch, flywheel, center diff, and rear diff CHEAP dahane Legacy Specific Parts 5 12-23-2009 02:22 PM
WTB: VTD center diff from 4eat/5eat! g00fy Private 'Wanted' Classifieds 2 11-03-2008 05:07 PM
Does the tranny, center diff, and front diff all bathe in the same oil? pio!pio! STi Forum Archive 1 06-06-2003 11:17 PM
VTD center diff info RiftsWRX Transmission (AT/MT) & Driveline 4 07-26-2002 09:41 AM
