Old 05-15-2002, 01:18 PM   #1
FuZZyLoGiC
Member#: 5970
2004 \/\/|2>< STi
Bp]V[ 97 |_||\|1<|-|1p2.0
Default Defi install time?
Ok Defi hood w/Boost Psi, Oit temp and EGT. How long should it take? I have a bung for the oil temp that will fit the oil gally under the IC. The manfold will need to be taped and the boost should be NP at all. What do you think?
FuZZyLoGiC is offline   Reply With Quote
Old 05-15-2002, 09:57 PM   #2
FuZZyLoGiC
Member#: 5970
2004 \/\/|2>< STi
WoW, no one knows?
Old 05-16-2002, 12:42 AM   #3
codean
Member#: 10186
Well I have the same defi gauges that you do and installing the boost and oil pressure gauges are not bad at all. I have not installed the EGT gauge yet because I was waiting for my uppipe so I could do both at the same time (will do it this weekend). I found that the most time consuming part of the install was figuring out where to put the boost sensor, running the wires, and finding a good spot to mount the control unit.
codean is offline   Reply With Quote
any good shops that do DEFi installs? teh sash Southern California Impreza Club Forum -- SCIC 12 02-21-2006 06:26 PM
Questions about Defi Install Shabib67 Electrical & Lighting 0 12-20-2005 11:23 AM
DEFI Install? Silver-Bolt Electrical & Lighting 3 02-04-2004 10:53 PM
please help with defi install ruskirex Electrical & Lighting 0 05-01-2003 02:30 AM
Defi install FuZZyLoGiC Mid West Subaru Owners Club Forum -- MWSOC 2 05-15-2002 09:50 PM
