#1 |
Member#: 137904
Event: dyno pull
Location: Scoobyclinic, Chesterfield, U.K. Ambient Temp: 50 Elevation: 670 ft Car: 1995 STI RA Tuner: Pat, Scoobyclinic Dyno Info: Dyno Dynamics Peak HP at RPM: 587bhp@6400 Peak Torque at RPM: 580@4300rpm Baseline hp/tq for a stock on same dyno: 2.5 STI 275-280bhp Target Boost: 28psi Target AFR: 12 Fuel: Pump E85 Engine/Power Modifications: Scoobyclinic 2.3L engine, Stock STI 8 heads with stock cams, Solaris ecu, new blouch GT30 XT-R billet turbo with .63 a/r housing, E85 pump fuel. Driveline Modifications: PPG 5 speed syncro box, stock dccd centre diff, exedy twin plate clutch. Suspension Modifications: Hotbits DT2 coilovers Blouch GT30 XT-R (blue) vs GT30R (red) both on .63 a/r exaust housing ![]() Boost and AFR ![]() Blouch GT30 XT-R on left and stock GT30R on right ![]()
#2 |
Member#: 43905
South East
Vehicle:02 WRXBastardchild WRB |
@4k better hold on to something! Great numbers |
#3 |
Member#: 137904
car ran 10.37 @ 132mph 1/4 mile earlier this year on the standard gt30r with 540bhp, the tracks here are closed till the new year but should go a little quicker with extra 45bhp and 40 ftlb
photo of car ![]() Scooby Sprint winner 2009, Scooby shootout drag winner 2008 / 2009, Time Attack UK (club class) winner 2008 |
#4 |
Member#: 185106
RMIC
Vehicle:2006 Subaru WRX WRB HTA68'd |
sick sick car man! congrats!
#5 |
Member#: 193222
Vehicle:2005 vf34'd wrx OBP L&M tuned ;) |
Sick build!
#6 |
I declare Shenanigans!
Moderator Member#: 150794
SCIC
Vehicle:2.3 built bugeye In it to win it |
That's beautiful! I'm assuming you engine-dynoed the car to get BHP, or is it calculated from WHP?
I run a built 2.3 myself and had my eye on that range of turbo, VERY curious to see what your whp numbers look like. That boost curve tells a nice story of its own though ![]() *giddy like a schoolgirl* Beautiful car too! |
#7 |
Member#: 33458
Vehicle:1988 Justy 1.2L 4WD 2002 WRX 2.1L AWD |
Where can more info about this turbo be found? Is there a 35r-sized model?
#8 |
Member#: 119764
Vehicle:2006 STi WRB |
#9 |
Member#: 137904
bhp is dyno calculated, the the stock gt30r made 419WHP and the new XT-R made 455WHP (as on 2nd graph)
turbo is gt3076r size, and is made by Blouch Turbo, and they have a GT35 XT-R Billet turbo |
#10 |
Member#: 205427
Vehicle:2000 RSTI, I think Army Green |
Those are some promising numbers, how do you like the 30r for time attack? Are you running a ALS?
#11 |
Member#: 103232
Vehicle:GDA Built 2.5hybrid AKA SLEEPYBEAR soblowme |
Wow must be a fun ride! Spools up faster, and makes more power.
#12 |
Member#: 137168
South East
Vehicle:06 Built SGM WRX Nasioc is the SHADY! |
N I C E !
#13 |
Member#: 119945
Vehicle:2004 sti java black pearl |
yeah more info on this blouch GT30 XT-R billet turbo please......
#14 |
Member#: 212339
That spool up is incredible with all that power!
#15 |
Member#: 81102
BAIC
Vehicle:01' BMW K1200RS 90'Maco Red Camry GST FTW |
very nice, nice to see you guys from the UK posting over here
#16 |
Member#: 202183
Vehicle:2008 WRX Sedan Dark Grey Metallic |
lets see engine shots
#17 |
Wow.... Been looking for a turbo for my 2.5 build. May have just found it
#18 |
What is all done to the block? Sleeved?
#19 |
Member#: 137904
![]() block is a stock EJ22 with scoobyclinic 2.3 stroker kit and stock STI 8 heads |
#20 | |
Member#: 137904
![]() 2008 time attack video (gt35r on pump fuel and meth) 2009 sprint final video (gt30r on e85) 2009 drag final video (gt30r on e85) |
#21 |
Member#: 185346
Vehicle:2007 Impreza WRX STi SWP |
wow that car is amazing! and great numbers!
#22 |
Member#: 33458
#23 |
SCIC
Is it ACTUALLY a stroker, or does it get the extra displacement from larger pistons? Just curious
![]() Mine uses a 2.5 N/A crank with 92.5mm pistons, curious how they compare... I flippin love your setup! That's gotta be one of the best all-around setups I've seen Last edited by Audiosavvy; 11-11-2009 at 05:21 PM. |
#24 |
Member#: 129631
Vehicle:06 Obp Sti back to slow lolz |
+12345 Fast spool and sick topend... Gonna have to keep an eye on this turbo for my next setup.
#25 |
Member#: 115104
Vehicle:2003 popsicles and boobies |
*voice of Sean Connery*Good GOD man!! Those are very impressive numbers, very impressive.
