Old 11-10-2009, 04:11 PM   #1
SonicYeller
Member#: 147755
2011 CTS-V Sedan M6
1993 Talon TSi AWD
Default Misfire / Stutter only under WOT?
Mods:
-20G
-AP V2 w/custom tune
-TBE / Uppipe
-820cc Modded Injectors
-Walbro 255
-LW Crank Pulley
-NGK Iridium one step colder
-Grimmspeed EBCS
-STi TMIC
-Yadda, yadda, yadda
Car ran fine for few months after the turbo install and tune, then about a month ago started having the issue it has now. The car runs excellent at idle and just driving around, but once you go WOT it misses and stutters once it hits boost. You can run the car all the way up to redline at part throttle and it pulls fine. When the issue first started to occur about a month ago, it was only a slightly noticable power loss in 3rd and 4th after driving the car for a long time. Now it has gotten bad enough that it just misfires under WOT no matter how long it has been driven. I've tried cleaning the MAF with no change. The plugs only have about 6,000 miles on them. When the car sets misfire codes after an ECU reset, it sets p0302 first and eventually will set codes for all the other cylinders over the course of several days.
So... does this sound like a coilpack issue or do I need to check my plugs? They were gapped at .030 when I put them in.
SonicYeller is offline   Reply With Quote
Old 11-10-2009, 04:40 PM   #2
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
regap your plugs down to .28 and check for cracks on the porcelain part of your plugs dont over tighten them it could cause damage you only need 15 ft lbs tork
Dragon Wagon is offline   Reply With Quote
Old 11-10-2009, 04:45 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
boost leak.....if it aint plugs
Old 11-11-2009, 02:45 AM   #4
nace325e
Member#: 228932
02 WRX
MBP
i was having the same prob, i changed my plugs and it went away
nace325e is offline   Reply With Quote
Old 11-11-2009, 03:06 AM   #5
supersuby2
Member#: 161678
2002 wrx V5 RA swap
I had the same problem as well and after trying many things it ended up being 2 things, weak grounds on the heads, and my plugs. I had put in one step colder plugs and they where iridium NGKs. I have read alot that people don't have good luck with the iridiums, and have even more trouble with the one step colder plug. So after swapping coilpacks with some extras my buddy had, replacing my MAF sensor, fuel filter and pump and pressure regulator it came down to the plugs being the majority of the problem. I replaced the iridium one step colder units with stock heat range copper NGKs for 2 bucks a piece and problem solved!!
supersuby2 is offline   Reply With Quote
Old 11-11-2009, 06:25 PM   #6
02blueru
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
Could also be a fuel issue... I had the same problem and turns out my fuel pump was bad. Major pain in the ass tracking the issue down.
02blueru is offline   Reply With Quote
Old 11-24-2009, 09:25 PM   #7
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Im working on an '06 STi that has the same symptoms. I just put NGK +1 colder iridiums in the car as well.. The car was also tuned for stock plugs. Anyone know if colder plugs require any tuning?
bigmike25rs is offline   Reply With Quote
Old 11-25-2009, 12:55 AM   #8
supersuby2
Member#: 161678
2002 wrx V5 RA swap
Not sure they would require tuning but i have heard a few guys say they see alot of misfires from one step colder and also swear by the cheaper copper NGK. These 2 reasons are why i went back to stock heat and copper plugs and i have not misfired in several months now
Old 02-14-2010, 03:36 AM   #9
slavik.86
Member#: 238300
00 2.5rs built
ej255 swap
i have same problem. any luck anyone?
slavik.86 is offline   Reply With Quote
Old 02-14-2010, 03:12 PM   #10
Meatbawl
Member#: 175878
My experience with NGK Iridium colder plugs has been that they like to foul quicker. On my STI that was running pig rich, I was lucky to get 2k out of the plugs. I routinely took them out every time I changed the oil to clean them. Switched to stock heat range coppers and got a lot more mileage out of them.
I also had the same issue that you had at one point after doing a compression test. Apparently when putting one of the plugs back in afterwards, it must have got bumped and the gap was off just a little bit. Replaced the plug with a new one with the correct gap and it eliminated the stutter/popping at WOT.
Don't even mess with trying to re-gap the iridiums, they get ruined when placing a gapping tool into them. I recommend switching to a standard heat range plug (my personal new favorite plug is the Denso Platinum TT's @ $1.99 a plug at Advance Auto Parts), check the gaps ( 0.27-0.29 I believe), reinstall, and go for a drive.
Meatbawl is offline   Reply With Quote
Old 03-03-2010, 12:35 AM   #11
lancelot86
Member#: 240032
2010 FXT
I have basically the same problem on my 08 STI but mine only starts to stutter/misfire/rev limit after I go past 5,000 rpm WOT. Seems to be most noticeable when in Sport Sharp. It only just started happening about a month ago. It's been sub freezing temps for the whole time so I'm not sure if that has anything to do with it. I've ran 2 bottles of heet through the system and I only use 91 or 93 octane. I take it into the shop in a few days.
lancelot86 is offline   Reply With Quote
Old 03-03-2010, 12:47 AM   #12
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
what kind of 20g?
jaegmeister is offline   Reply With Quote
High RPM misfire/stutter SW00P_G Built Motor Discussion 104 09-07-2011 09:56 AM
stutter under WOT and NO! CEL's soob noob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-13-2009 05:43 PM
stutter under WOT soob noob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-21-2009 09:13 PM
Stuttering/missing under WOT Norcalrallyist Pre-2002 Factory Turbo Powertrain 21 08-02-2007 06:41 PM
02 WRX issues : cylinder 3&4 misfire + rough acc under WOT The_Triton Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-09-2007 10:25 AM
