Old 05-15-2002, 05:22 PM   #1
BlazingRS
Member#: 16443
01 2.5 RS
blue ridge pearl
Question whats up with this CE light
The time has come to do something about that darn "check engine" light!
After just recently doing the 15k service, I had the CE light reset. Only 200 mi later it came back on again. I know for a fact that the cause is the ganzflow intake. Basically I just want the light OFF! Is there a plug that I can pull or something?
*I know this was surely posted before, however, as you know the search is down
BlazingRS is offline   Reply With Quote
Old 05-15-2002, 05:34 PM   #2
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
umm... the ganz won't throw a CEL... there is a plug but i don't know what it is since the search is down
KillerTHC is offline   Reply With Quote
Old 05-15-2002, 07:31 PM   #3
aigburth
Member#: 8619
1996 RHD GC '96
http://spookyempire.com
Cycle your key 3 times,this will get the light to go off,but the code will still be stored.
Alan
aigburth is offline   Reply With Quote
Old 05-15-2002, 07:47 PM   #4
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
cycle the key 3 times? what the?
akcel is offline   Reply With Quote
Old 05-15-2002, 07:56 PM   #5
obyone
Member#: 16523
I think thats when you turn the key but don't crank the engine.
obyone is offline   Reply With Quote
Old 05-15-2002, 08:09 PM   #6
akcel
Member#: 10268
gc8 I ride ride 24s
and this turns the cel off? i've NEVER heard of that...i've heard of resetting the ecu to get it off but hmmm
Old 05-15-2002, 08:13 PM   #7
aigburth
Member#: 8619
1996 RHD GC '96
Trust me try it,turn your key to power on 3 times in a row.
Alan
Old 05-16-2002, 12:06 AM   #8
BlazingRS
Member#: 16443
01 2.5 RS
blue ridge pearl
I just got back from trying the key trick , but no luck! Is there something I did wrong? Another solution perhaps.... gosh, that darn light
Old 05-16-2002, 02:54 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
FWIW it's NOT 3 key cycles...it is 3 DRIVE cycles to get the light to go off. and it's not from your ganzflow.
what the hell code are you throwing??
jeremy
Old 05-16-2002, 02:57 AM   #10
Andrew
Member#: 1170
2005 STi
the hell is a drive cycle
Andrew is offline   Reply With Quote
Old 05-16-2002, 04:55 AM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
umm i've driven my car more than 3 times...and i still have a cel
Old 05-16-2002, 10:50 AM   #12
Ethan
Member#: 246
well why don't you put the stock airbox on and take it to the dealer. Sounds like you only have about 15,200 miles on it so its still covered under warrenty.
Ethan is offline   Reply With Quote
Old 05-16-2002, 11:14 AM   #13
RallyNavvie
Member#: 7113
2008 Spec B
Is this an AFI question? If it is (and it should be to be posted in here) than take apart the dash and unplug the bulb for the light. Mine has been disconnected for as long as I can remember. I, for one, am getting sick of AFI people complaining about CELs. You're obviously going to throw codes on an AFI system unless you got lucky somehow. If you don't want to just unplug the bulb then get a new ECU.
I swear, 5% of the posts in here are regarding CELs
~Garrett
RallyNavvie is offline   Reply With Quote
Old 05-16-2002, 12:50 PM   #14
Aphex
Member#: 146
'16 WRX Limited
heh heh, the worst is WRX guys, they think that every mod they do to their car should not throw a CEL light, if it does nobody else will buy the product and something must seriously be wrong, ha ha ha ha.
but this seems like an N/A question to me, since he's got the ganzflow intake.
Aphex is offline   Reply With Quote
Old 05-16-2002, 01:35 PM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
a DRIVE cycle is not just driving the car, it's starting the car and driving where all 6 monitors run and pass, no one knows how long it takes to complete a drive cycle and what the necessary parameters are except the manufacturer.
Jeremy
Old 05-16-2002, 04:12 PM   #16
akcel
Member#: 10268
gc8 I ride ride 24s
Jeremy
weak :P
-akcel
Old 05-22-2002, 09:39 PM   #17
BlazingRS
Member#: 16443
01 2.5 RS
blue ridge pearl
Ok people, could anyone possibly explain then what exactly is a drive cycle so I can do this? I really want to get this light off badly! Still, other options are welcome.... thanks
Old 05-23-2002, 12:51 AM   #18
RallyNavvie
Member#: 7113
2008 Spec B
What mods are on the car?
~G
Old 05-24-2002, 02:17 AM   #19
BlazingRS
Member#: 16443
01 2.5 RS
blue ridge pearl
THe only mod I've done is the intake (ganzflow). Is it true that this wouldn't be the cause for the CEL?
Old 05-24-2002, 02:20 AM   #20
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
There is one sure fire way to turn off the CEL...........Take the bulb out!!!!!!
That works or me!!!!
LVSUBARU is offline   Reply With Quote
Old 05-24-2002, 02:25 AM   #21
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
sorry i don't like jail cells...but hey whatever floats your boat...sounds like you have a bad o2 sensor or a bad catalyst...why not fuggin take the thing to the dealer and GET IT CHECKED!
Old 05-24-2002, 02:37 AM   #22
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I am a dealer!!!!!
I don't live in CA so it isn't illegal. I was geting codes for the rear O2S. I've replaced it since. My CEL probally isn't even on anymore!
Old 05-24-2002, 11:21 AM   #23
RallyNavvie
Member#: 7113
2008 Spec B
The point I was trying to make is it doesn't really belong in the AFI forum. Leave the NA jockeys to help you figure this one out. On this side of the performance coin we just take the damn bulb off because all it is to us AFI folks is a reminder we have a turbo/SC under the hood.
~Garrett
Old 05-24-2002, 02:09 PM   #24
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
I am a dealer!!!!!
ummm FYI it's a federal offense to tamper w/ the CE light as well as remove a working catalyst.
jeremy
Old 05-24-2002, 09:14 PM   #25
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Shhhhhhh!
Just don't tell the FBI and I'll be OK!
Dude whats up with this!? Sleepy Wagon. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-29-2006 11:16 AM
whats up with this 98subyrezaRS Normally Aspirated Powertrain 4 01-01-2006 10:52 AM
whats up with this???? notyet227 Texas Impreza Club Forum -- TXIC 4 09-11-2005 11:11 AM
Ok...so whats up with this WRteXmeX Texas Impreza Club Forum -- TXIC 1 10-23-2002 10:17 AM
whats up with the security light? GeoT100 Service & Maintenance 2 04-11-2002 11:18 AM
