Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 11-11-2009, 09:41 AM   #1
penderperson
Member Sales Rating: (15)
Member#: 172370
2006 STI
Default FS: Advance Design coilovers
For sale is one set of Advance Design(Ground control's in house shock company) Double Adjustable coilovers. They fit 05 STI's and worked fine on my 05 WRX, come with 450/375 springs (or no springs) and they have a 16mm shaft (I use Ground Control camber plates).
They are valved for for BSP, I got them from an 05 STI and after running them on street tires decided they were too stiff in compression and nitrogen pressure for my needs. They sure handled well, i've never gotten so much rotation and on-command oversteer as with these shocks! The alignment flexibility is pretty awesome too. Also, the fronts have been shortened to add bump travel at low ride heights.
Let me know if you have any questions, looking for $1700obo.
Retail = $1600 for inserts($400/ea), $600 for housings ($150 ea), $80 perches and sleeves, $220 springs, $600 for revalve = $3100
penderperson is offline   Reply With Quote
Old 11-13-2009, 01:55 AM   #2
penderperson
Member#: 172370
2006 STI
To the top
Old 11-13-2009, 03:59 PM   #3
penderperson
Member#: 172370
2006 STI
Bump, any interest in these at all?
Old 11-14-2009, 12:13 AM   #4
penderperson
Member#: 172370
2006 STI
Bump!
Old 11-14-2009, 02:19 PM   #5
penderperson
Member#: 172370
2006 STI
Saturday
Old 11-15-2009, 07:23 PM   #6
nickrice20
Member Sales Rating: (48)
Member#: 95153
2016 BMW F48 X1
Mineral White
Well considering that an 05+ STI hub is 5x114.3 and all USDM WRX's hub are 5x100 I doubt that you just bolted it right up. So maybe you go these from an 04 STI which was the only USDM STI that came with 5x100 hubs. Either way you need to figure out what hub pattern these are for and sell them accordingly. Just my thoughts, and good luck with the sale.
Nick
nickrice20 is offline   Reply With Quote
Old 11-15-2009, 11:02 PM   #7
penderperson
Member#: 172370
2006 STI
Nick
The bolt pattern has nothing to do with the dimensions of the hub ear and the dog ears on the shock. The differences are there, but due to the huge lower bolt holes in the dog ears(on the shocks), the SLIGHT difference in the hub hole locations and hub ear width(on the hub) didn't cause a single problem for any of the four autocrosses or 500 miles of street driving I did prior to the revalve.
I do specify what they're for, so for those who don't believe or want to "risk" it, if its not an 05 STI then it's not kosher.
*For the extended version, the 05 STI dog ears on these housings are about .025" wider than the WRX hub ear, they fit. Try to put WRX dog ears onto an 05+ STI hub ear and it will be .025" too narrow = will not fit.
Thanks for the interest,
Rob
Old 11-16-2009, 12:29 AM   #8
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Rob
Well you learn something new everyday. I had never heard of a coilover setup working on both so another free bump for you.
Old 11-18-2009, 12:08 AM   #9
penderperson
Member#: 172370
2006 STI
bump it up
FS: Advance sale Prodrive Blue WRX Springs scottjua TXIC Private Classifieds 30 10-27-2008 03:40 PM
Want to win in autox? 05 STi Ground Control Advance design coilovers/camber plates trhoppe Private 'For Sale' Classifieds 6 08-22-2005 09:12 AM
Ground Control Advance Design suspension w/camber plates trhoppe Private 'For Sale' Classifieds 2 02-22-2005 01:38 PM
Looking for info on Ground Control Advance Design Coilovers grippgoat Brakes, Steering & Suspension 9 07-01-2004 11:54 AM
Ground Control Advance Design Coilover pics MiXer Brakes, Steering & Suspension 10 10-31-2001 12:42 AM
