Old 05-15-2002, 06:33 PM   #1
tonytiger
Member#: 3844
1993 Legacy 1.8
Question Thinner head gasget, bigger compression ratio?
As we know changing the head gasgets to thinner ones increases the CR a bit. How much it changes depends on the current one.
Well, have anybody changed theirs?
The stock head gasget looks pretty thin already, how thin is it actually when bolted on?
How big is the EJ18 combustion space? I mean the burning space in the heads? Knowing this I could count the produced CR with the thinner gasget.
Any material suggestions?
I doubt changing it will cause self detonation
That's it for the start.
Thank you.
tony
tonytiger is offline   Reply With Quote
Old 05-16-2002, 12:57 AM   #2
Jademonkey
Member#: 9213
2000 RS
Red
Wouldn't a thicker gasket accomplish this?
Jademonkey is offline   Reply With Quote
Old 05-16-2002, 01:10 AM   #3
RawCode
Member#: 3115
2002 Impreza 2.5RS
A bigger head gasket would lower compression because it would create more volume in the cylinder.
RawCode
RawCode is offline   Reply With Quote
Old 05-16-2002, 02:57 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
FWIW you are going to get .1 compression out of this and SEVERLY increase your risk of valve train damage should you snap the timing belt.
Jeremy
Old 05-16-2002, 04:04 AM   #5
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Exclamation I thought
I thought at one time Cobb Tuning was offering thinner headgaskets to up the compression ratio of the EJ25.
Kevin Thomas is offline   Reply With Quote
Old 05-16-2002, 04:37 AM   #6
tonytiger
Member#: 3844
1993 Legacy 1.8
The thinnernes of the stock gasget was the thing I was woried about, it can't be much more thinner that it is currently. As you HndaTch627, Jeremy said the increase of CR might only 0.1 it's not worth the money - at least here where I live.
By the way, why does the timing belt have a bigger risk to snap? I'm not familliar with the issue...
But since COBB has offered them, forget everything what I've said, that must be a really good mod then Ads tons of HP
Thank you for the responces.
tony
Old 05-16-2002, 11:13 AM   #7
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
The compression ratio is the ratio of the maximum volume in the cylinder over the minimum volume in the cylinder. So, by increasing the stroke of the cylinder head by putting a larger gasket on, you increase the compression ratio.
What this does to the stock engine parts I'm not sure of, but I'm going with what's been said already.
AJ711 is offline   Reply With Quote
Old 05-16-2002, 11:38 AM   #8
proecm
Member#: 12081
Tony,
I would encourage you to do what you are planning on doing, the CR could probably be increased quite a bit without risk of detonation, considering being in Finland you should be able to get 100 octane out of the street pump, right?
If thinner hed gasket is not enough increase in CR, just plane the head 0.5 mm or so and you should be fine. Keep in mind that you will not see as much improvement in power as you will in mileage.
/David
proecm is offline   Reply With Quote
Old 05-16-2002, 01:18 PM   #9
BugBomb
Member#: 1342
99 OBS & SUXASS
May your line be smooth
midnx,
I think you have that backwards. Let's exaggerate things to make it a little more obvious. Let's say that our imaginary piston moves back and forth 9 inches in the cylinder. At the peak of the cylinders compression there is a 1" airspace from piston to valve, and when the piston moves back 9" you have a 10" airspace. This would be a 10:1 compression ratio. If you moved the valves 1" away from the piston by putting in a REALLY thick gasket, you add 1" to both airspaces. Now you have 11" to 2", or 5.5:1 compression ratio (much lower compression).
Does this make any sense?
BugBomb is offline   Reply With Quote
Old 05-16-2002, 01:40 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
tony
LMFAO!!!! haha that's great man ....i was just stating that the EJ25 is designed to have the cams free spin and stop at a certain point before it bends valves....by effectively lowering the clearance between the valves and the piston you are increasing your risk of valvetrain damage SHOULD a failure occur.
jeremy
Old 05-17-2002, 02:53 PM   #11
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Thanks for the clarification BugBomb, I was going with my general knowledge from my Thermodynamics course I just got done taking. I see what you're saying too, and understand where my thinking was wrong. Thanks.
AJ
Compression Ratios and Heads (STI, Spec C, etc) sponaugle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 01-31-2015 10:42 PM
96' ej25 shortblock with 98' ej22 heads.. Whats the Compression Ratio? lotus2843 Subaru Conversions 12 02-07-2006 05:29 AM
What would the compression ratio be with a 96 ej20H shortblock with 96 ej25 heads? hotshot2109 Subaru Conversions 3 10-10-2005 11:02 AM
What is my new compression ratio? EJ18 heads w/ EJ20 block STi-Nismo Dood Subaru Conversions 1 01-08-2005 05:23 PM
