Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-28-2010, 01:48 PM   #26
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
If Prova comes out with a GD unit, we will stock it
RallySport Direct is offline   Reply With Quote
Old 01-29-2010, 11:12 AM   #27
RallySport Direct
Member#: 33174
We are Open Late!
Got word from Prova. THEY do have a GD wheel. We are trying to get some info on what model years it will fit. We will update as soon as we hear back from Japan.
Old 02-01-2010, 06:12 AM   #28
andrewhans
Member#: 154128
1987 Volvo 240DL
Red
^^^FTW
andrewhans is offline   Reply With Quote
Old 03-10-2010, 07:38 PM   #29
sszyma
Member#: 31399
2007 WRX
2014 Forester 6MT
I just installed this in my 07 WRX and the fit was perfect. As a side note you do not have to remove the airbag at all. Just rest it on top of the steering column as you unbolt and unscrew the wheel and install the new one. Now I do not know which method is safer but, if you are worried about unplugging the airbag you do not have to.
sszyma is offline   Reply With Quote
Old 09-03-2010, 09:02 PM   #30
rockthebox50
Member#: 150034
2007 Impreza WRX
Satin White Pearl
thats amazing i needa do that
rockthebox50 is offline   Reply With Quote
Old 12-22-2010, 09:50 PM   #31
HarryN
Member#: 250258
2011 Legacy WRX STI
Dark Grey Metallic
Wow... I wish I could see the install direction on a steering wheel that has that damn bluetooth crap on it. If I get one of these, I want to remove the bluetooth crap. I already have a headset (or 5). Would that be easy to do on this steering wheel?
HarryN is offline   Reply With Quote
Old 12-23-2010, 10:12 AM   #32
RallySport Direct
Member#: 33174
We are Open Late!
We did the wheel on our 2011 STi shop car, and the install was identical to the previous cars. The blue tooth is just 1 extra screw that holds the blue tooth assembly to the center cage.
Old 12-23-2010, 11:03 AM   #33
Projekt Cars
Member#: 268000
Default Alcantara
I have alcantara on the seats and they have pretty much retained their color for three years....how does the oils from the hand affect the look of the steering wheel after a few years?
Projekt Cars is offline   Reply With Quote
Old 12-23-2010, 11:06 AM   #34
RallySport Direct
Member#: 33174
We are Open Late!
It will get matted down if you have sweaty or oily hands.
But you can use the shoe stuff they sell to bring it back to life.
Old 01-06-2011, 11:58 AM   #35
dropkick711
Member#: 254710
thanks for the write up. installed this on my GD last night
dropkick711 is offline   Reply With Quote
Old 02-08-2011, 10:12 PM   #36
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
can you fit any on a 03 wrx
SUBYS R US is offline   Reply With Quote
Old 02-08-2011, 10:58 PM   #37
RallySport Direct
Member#: 33174
We are Open Late!
You should be able to.
First, you would need to install a 05 STi steering wheel and airbag(05 came with the single stage airbag, and the 06+ came with the dual stage). Once the 05 STi wheel is fully installed, you can then install the Prova wheel, using the 05 STi airbag.
This would make for an awesome upgrade while still retaining the airbag for safety.
Thanks,
Rick
Old 08-29-2011, 02:07 AM   #38
AnthonyWang
Member#: 292823
Fuji Factory
Bugeye
informative
AnthonyWang is offline   Reply With Quote
Old 12-08-2011, 02:23 AM   #39
Subaruswaxevos
Member#: 302997
great write up
Subaruswaxevos is offline   Reply With Quote
Old 04-17-2012, 11:48 AM   #40
silversubaru27
Member#: 150487
2006 STi
Gotta have on for my GD
silversubaru27 is offline   Reply With Quote
Old 05-12-2012, 06:22 PM   #41
DJ_RamBam
Member#: 290264
2011 STI Sedan
Can anyone help me troubleshoot my install? I changed my to the prova d today in my 2011 sti and ever since. I have a blinking diff light and my hill assist and vdc light remain on.
I cannot seem to find the problem.
Uploaded with ImageShack.us
DJ_RamBam is offline   Reply With Quote
Old 05-12-2012, 07:29 PM   #42
RallySport Direct
Member#: 33174
We are Open Late!
That would typically mean that the center section (clock spring) was not positioned back properly after the wheel install.
Couple guy have run into this issue, what you will want to do is make sure that the clock spring is dead center when the wheel is dead center.
Old 08-04-2012, 07:22 PM   #43
ketchupdtf
Member#: 175060
GR STi
FYF Squad!
Subscribed for when i buy mine...... Added it to my RSD wish list....
ketchupdtf is offline   Reply With Quote
Old 08-22-2012, 11:58 PM   #44
derek1ee
Member#: 279421
I will be installing this once my 13 sti arrives.
one question:
What is clock spring? Photo would really help!
derek1ee is offline   Reply With Quote
Old 08-23-2012, 12:22 AM   #45
RallySport Direct
Member#: 33174
We are Open Late!
one question:
The clock spring is not a typical "spring". Its a loose term used in the industry for the mechanism that has the wiring inernally that runs to the steering wheel controls.
On the left of the picture, its the black center section around the steering input shaft that the steering wheel splines slide over and has the wires coming out of.
Kirill
RallySportDirect.com
Old 08-23-2012, 12:42 AM   #46
derek1ee
Member#: 279421
Thanks, I will check the services manual for details too.
So if I align the new steering wheel with two plastic pin, will it guarantee I put the new one exactly the same position as the one I took off? There're so many teeth on the shaft I'm a bit worry I'm off by one...
Old 08-23-2012, 12:50 AM   #47
RallySport Direct
Member#: 33174
We are Open Late!
The clock spring can spin free when the wheel is removed. so you need to make sure to park the car straight when you get ready to take the wheel off so its easier to re-align the pins if you on accident bump it out of place
Kirill
Old 08-23-2012, 01:39 AM   #48
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Time frame on a BRZ wheel?
OrbitalEllipses is online now   Reply With Quote
Old 08-23-2012, 02:06 AM   #49
derek1ee
Member#: 279421
Kirill
Thanks! I think what I'm going to do is when the airbag is off, I will put some tape on the clock spring and it's surroundings so it won't spin around. Then I can just align the new one with those two pins on the clock spring and I know I set it into the correct teeth. Any advise?
Old 08-23-2012, 01:18 PM   #50
RallySport Direct
Member#: 33174
We are Open Late!
Nothing yet from Prova for the BRZ units.
Kirill
How To: 2008 WRX/STi Coilover Install RallySport Direct NASIOC Project Cars 40 08-11-2014 05:53 PM
How To: Change a power steering pump on WRX/STi Gamble_WRX Service & Maintenance 23 04-06-2013 08:22 AM
How To: Prova Air Oil Separator RallySport Direct NASIOC Project Cars 52 10-12-2010 10:26 AM
sparco steering wheel adapter wrx sti bootman Interior/Dressup/Audio & Security 1 07-07-2009 03:10 AM
Spec C MY06 steering wheel on WRX/STI 02.. How? alfo40 Interior & Exterior Modification 6 03-06-2006 10:14 AM
