Old 11-12-2009, 07:57 PM   #1
Turbospool72505
Member#: 221822
BLACK
Default boost is only 8 psi why
I installed a Boost Gauge and at max i am reading 8 psi all of my connections are tight am i on the wrong line
Turbospool72505 is offline   Reply With Quote
Old 11-12-2009, 07:58 PM   #2
ADAS1223
Member#: 159853
2005 Impreza
wrb
which line
ADAS1223 is offline   Reply With Quote
Old 11-12-2009, 08:01 PM   #3
Nicklz
Member#: 94096
2003 WRX
Does the car actually feel slower?
you may have only been at 8lbs before and not realized it.
dunno, more info.
Nicklz is offline   Reply With Quote
Old 11-12-2009, 08:03 PM   #4
Turbospool72505
Member#: 221822
BLACK
the car does not feel slower it feels the same it is the line i think off of the bov
Old 11-12-2009, 08:05 PM   #5
kasra007
Member#: 225361
2006 wrx sti
beige
doesnt factory sti run 14.7 something? so how can you run 8 o.o
kasra007 is offline   Reply With Quote
Old 11-12-2009, 08:07 PM   #6
CooperS431
Member#: 52007
2004 STI
That seems like you taped into the line that goes from the BPV back to the intake manifold when you let off the throttle. Does the gauge read 8psi when you let off the throttle or when you are actually in boost? and I believe he has an 02 WRX and not and STI.
CooperS431 is offline   Reply With Quote
Old 11-12-2009, 08:07 PM   #7
triplexcel
Member#: 200688
2002 Duba-U-R-X
might have to do with the temperature.
i get 8psi sometimes too but only if i don't floor it for a while. its like the car goes into hibernation mode or something. after 1 or 2 times of flooring it, the boost hits back to 15.5lbs for me.
triplexcel is offline   Reply With Quote
Old 11-12-2009, 08:09 PM   #8
Turbospool72505
Member#: 221822
BLACK
when i start the car she is in vac around 2500 or so the boost is 0 and wot the boost is 8 psi
Old 11-12-2009, 08:09 PM   #9
Scott_2.5TS
Member#: 163806
check your restrictor pill is in the correct location... mine wasn't
http://forums.nasioc.com/forums/show....php?t=1695165
Scott_2.5TS is offline   Reply With Quote
Old 11-12-2009, 08:09 PM   #10
quazimoto
Member#: 70395
Probably missing the pill in the vacuum line for the turbo. I'm guessing you are not the original owner.
quazimoto is offline   Reply With Quote
Old 11-12-2009, 08:09 PM   #11
Turbospool72505
Member#: 221822
BLACK
The car is 2002 wrx
Old 11-12-2009, 08:09 PM   #12
Nicklz
Member#: 94096
2003 WRX
sounds like your only getting wastegate pressure
Old 11-12-2009, 08:10 PM   #13
Turbospool72505
Member#: 221822
BLACK
no i am the 3rd owner
Old 11-12-2009, 08:10 PM   #14
ADAS1223
Member#: 159853
2005 Impreza
wrb
thats the right line. is the hose kinked anywhere? check the lines coming off your turbo's compressor side. do you have an aftermarket bov? tears in IC piping? any exhaust leaks preturbo?
Old 11-12-2009, 08:16 PM   #15
Nicklz
Member#: 94096
2003 WRX
List of mods could help.
Try a reset to see if the car is pissed about something?
Also put it into test mode and see if the solenoid makes a clicking noise or not.
Old 11-12-2009, 08:16 PM   #16
Turbospool72505
Member#: 221822
BLACK
i dont here any leaks that i can here no after market bov no tears in piping
Old 11-12-2009, 08:19 PM   #17
ADAS1223
Member#: 159853
2005 Impreza
wrb
the restrictor pill inside the line from the "T" fitting to turbo. squeeze it to see if a pill is in there. if not, thats your problem
Old 11-12-2009, 08:21 PM   #18
Turbospool72505
Member#: 221822
BLACK
does any body know were i can get a pic of the entire hose system because it seems like i might be missing some thing
Old 11-12-2009, 08:22 PM   #19
ADAS1223
Member#: 159853
2005 Impreza
wrb
check the link on post #9. it has the whole boost control system picture
Old 11-12-2009, 08:23 PM   #20
Nicklz
Member#: 94096
2003 WRX
the link in post #9 in this thread has a pic of it.
edit-ADAS beat me to it
Old 11-12-2009, 08:23 PM   #21
Chi_San
Member#: 53558
2002 WRX Wagon
8PSI can be caused by several things.
Bad gauge
Running regular unleaded instead of premium
Bad knock sensor
Carbon in the cylinders causing excessive knocking/pinging
Rapid changes in elevation
POSSIBLY a bad MAP sensor, I think this would throw a code though
Defective EBC
Boost line disconnected from the EBC (? Or would this cause turbo dynamics to peg, and throw a code since it would basically lock the waste gate shut?)
There's easy ways to narrow these down. Plug in a laptop with a Tactrix cable. Run Learning View. Is the IAM below 8? You're in a limp mode, and the ECU has disabled the EBC. You can see the knock table, and fuel trims to get a general idea on what is going on from there.
If not, then you have a problem where the ECU is commanding 13.5 PSI, but the EBC cannot physically do it, either due to it being failed, or some other problem.
Chi_San is offline   Reply With Quote
Old 11-12-2009, 08:29 PM   #22
Turbospool72505
Member#: 221822
BLACK
okay the post # i have that but what about the pill they were talking about what is that for
Old 11-12-2009, 08:29 PM   #23
Turbospool72505
Member#: 221822
BLACK
at 8 psi the car wont trow a code if that is correct on the gauge
Old 11-12-2009, 08:36 PM   #24
ADAS1223
Member#: 159853
2005 Impreza
wrb
the pill restricts the boost coming in, giving the ebc time to react. adjusting what the wastegate is seeing. thats why it should be between the T fitting and the compressor.
Old 11-12-2009, 08:39 PM   #25
Nicklz
Member#: 94096
2003 WRX
The pill is designed to work with your factory boost control system and dictates the flow/pressure the wastegate/solenoid sees <-- = you need it.
We really need more info to help you.
List mods, any CEL. And confirm/test the things we've already mentioned already.
Only 8 PSI? GlennC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-08-2008 01:56 PM
hitting only 8 psi stealth84ct AccessPort 4 08-07-2006 10:12 AM
Need help. Boosting only 8 psi atom945 Engine Management & Tuning 4 11-21-2005 07:56 PM
Only 8 PSI boost Uncle Scotty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-28-2003 09:09 PM
only 8 psi boost stock? solomrus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-16-2001 02:15 PM
