Old 05-16-2002, 02:28 AM   #1
WRX_man20
Member#: 10669
World Rally Blue
Question What gauges are required?
Hey all, I am going to be making improvements on my engine in the future and it was brought to my attention that I needed gauges to monitor the engine when adjusting turbo psi ect. What guages are a MUST and which come in second as a good to have. I've been looking at Greddy gauges since they match the lighting scheme of the car, but are they better gauges out there. Thanks, Chris
WRX_man20 is offline   Reply With Quote
Old 05-16-2002, 06:28 AM   #2
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Boost would be the most important, EGT would be a really good idea, a knock sensor, and air/fuel... those would be my top four choices, probably in that order, but it depends on how far you're planning to tune the car. I'm using a Vishnu stage 0 and all I did was use a boost gauge to tune it, and now it sits in my glove box. I plan to add an EGT and knocklink before I go to stage 1, and air/fuel will probably come in the form of a SAFC at some point.
Just out of curiosity, which GReddy gauges did you find that matched the stock interior well?
Edit: Bad spelling this early in the morning...
Narcisse91 is offline   Reply With Quote
Old 05-16-2002, 01:12 PM   #3
WRX_man20
Member#: 10669
World Rally Blue
The black faced gauges that illuminate green at night look good with the interior and gauge lights.
Old 05-16-2002, 08:39 PM   #4
Z1 Performance
Member#: 9327
Boost, EGT and oil pressure.
the rest just go blinkey blinkey and won't tell you much,.
i would personally skip the knocklink and A/F gauge...invest ina good datalogger instead
Z1 Performance is offline   Reply With Quote
Old 05-17-2002, 08:22 PM   #5
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
I have 6 of the GReddy electronic gauges (black face) in my WRX and love them. In the A pillar I have (52mm) water temp, fuel pressure, and oil pressure. In the Defi gauge pod I have (60mm) boost, EGT, and air/fuel ratio. If I only had 3 gauge spots, I would choose boost, EGT, and oil something (in this case, something being either pressure or temp, depending on who you ask, in terms of which is more important). The air/fuel ratio gauge has probably been the most vexing of them all.
GoodFinder
GoodFinder is offline   Reply With Quote
Old 05-26-2002, 02:14 PM   #6
SilverWRX02
Member#: 11127
what does EGT and oil pressure gauge tell you?
I want these gauges righthere
but they don't have EGT I don't know how accurate they are either. How can you tell if they're accurate or not?
SilverWRX02 is offline   Reply With Quote
Old 05-26-2002, 02:25 PM   #7
GoodFinder
Member#: 8943
Both Blue
My impression of EGT readings is that it is a good way to help you keep the insides of your engine in good shape. In other words, if the EGTs are too high for any significant length in time, either you are pushing the car too hard, or something is wrong inside.
As it relates to oil pressure or oil temperature, it seems to be (for me) more of an important "just to be sure all is OK" kind of monitoring.
I am sure somebody or bodies on the board here can give a more technical description of why EGT and oil are good things to monitor.
I am not familiar with the brand of gauges in the link you posted. I know the GReddy gauges are some of the more expensive, but to me they seemed to be well worth it, from a long term perspective.
Hopefully there will be some others here who can comment further.
GoodFinder
Old 05-26-2002, 05:10 PM   #8
SilverWRX02
Member#: 11127
thanks for reply goodfinder
I'm looking for those gauges because I need to match my reverse indiglos. After all my search I only find 2 sites that actually make reverse indiglo boost gauges. Omori USA and that other website that I linked.
does anyone know other companies that make reverse indiglo boost, egt and oil?
btw I found this
where the heck does that thing goes in the car??
the explaination is not very clear at all, either that or I just can't understand...
Meter hood panel of carbon make. Boost meter and the like it is the range of vision characteristic which until now is not. Being also to be able to open and close the hood, sort you can use also the BOX until now.
Old 05-27-2002, 01:33 AM   #9
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Smile My silly 2 cents
Boost (important until car is finally tuned how you want it)
EGT (important until car is finally tuned how you want it)
Time - use it everyday
Outside temp - use it most everyday
for a temporary gauge consider intercooler temp (ie if you are going to be changing out the intercooler this could be helpful).
Sordid Philosopher is offline   Reply With Quote
Old 05-27-2002, 04:08 AM   #10
jlogan9
Member#: 15511
Default boost gauge
I currently have the stock boost gauge which measures up to 1.5 kPa, I was wondering if I should get a gauge like the Greddry that measures up to 2.0 kPA.
Also, does anyone know the conversion factor from kPa to PSI
Thanks
jlogan9 is offline   Reply With Quote
Old 05-27-2002, 10:47 AM   #11
jesse370
Member#: 12147
2005 g-35
ivory pearl
0.1 (mpa)= 1 bar
1 bar = 14.508 psi
1 atmosphere (atm)= 14.689
* psi by .00689
(ex) 14.2 * .0069 = .097 mpa
jesse370 is offline   Reply With Quote
Old 05-27-2002, 04:36 PM   #12
jlogan9
Member#: 15511
Default Thanks
On a completely stock WRX what is normal boost?
Old 05-27-2002, 07:06 PM   #13
nqwan
Member#: 2916
02 duburu arr exu
Originally posted by SilverWRX02
btw I found this
its a replacement for the clock and its made for the rhd impreza. from the looks of it, i'd say its for the older gc8 bodystyle and not the new age impreza....
stock should peak at 14.2psi and taper off as you approach redline. people here report anywhere from 13.5-14psi as their observed peak boost.
nqwan is offline   Reply With Quote
Headgasket replacement - What parts are required? silentt Service & Maintenance 7 01-06-2009 06:10 PM
What gauges are essential? atibus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-12-2002 08:58 PM
What gauges are a must? mdot Newbies & FAQs 16 05-10-2002 11:28 AM
What Gauges are the most Important.. conernr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-10-2002 09:10 PM
What gauges are best to monitor a turbo engine? Neil Wallerstein WRX Forum Archive 18 02-18-2001 07:55 AM
