Old 11-14-2009, 03:59 PM   #1
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Default 04 wrx tranny drain bolt size ?
Ive searched for the last hour and couldnt come up with anything. Called the local suby dealer and he couldnt give me a socket size. So can anyone has has ever changed their tranny fluid in their 2004 wrx with a stock 2004 wrx tranny please tell me wither the socket is a 21mm or 22mm ? I dont have either sizes but im going to guess its one of those two. Thanks for the feed back.
04wrxhart is offline   Reply With Quote
Old 11-14-2009, 04:01 PM   #2
prometheum
Member#: 92003
04 bicycle!
i just drained mine 22mm did it for me
prometheum is offline   Reply With Quote
Old 11-14-2009, 06:35 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Mine was a t70 Torx, not a socket at all...
Old 11-14-2009, 09:09 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
you + ruler = the answer.
Old 11-15-2009, 01:40 AM   #5
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
on the 02/03 WRX's its actually 21mm socket, NOT 22mm.
The 04 WRX's use T70 torx like mentioned in 3 post.
rexman2002 is offline   Reply With Quote
Old 11-15-2009, 06:44 AM   #6
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
ORLY? My '04 has a 21mm plug.
Spenk is offline   Reply With Quote
Old 11-15-2009, 11:42 PM   #7
prometheum
Member#: 92003
04 bicycle!
oops
Old 11-16-2009, 12:52 PM   #8
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Ya I actually went to the store and bought a 22m socket and tried to test fit it in the parking lot but ended up having to drive all the way home, put the car up on jack stands just to find out that it was slightly to big. There was too much wiggle room to my liking so i decided it would be best to go back and get a 21mm socket instead of stripping the bolt. Any who, i got the fluid all changed out. I used the cocktail sold by Grimmspeed and i'm absolutely amazed with the results. The car shifts like butter now, and the grind i used to have when shifting into reverse has completely disappeared.
Old 11-16-2009, 01:41 PM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
beginning of 2004 model year cars have 21mm bolt
end of 2004 model year cars have T70 Torx
Concillian is offline   Reply With Quote
Old 12-14-2012, 09:35 AM   #10
UnknownAlly
Member#: 277330
2004 WRX
How can you tell what time of year your Subie was manufactured?
UnknownAlly is offline   Reply With Quote
Old 12-14-2012, 10:55 AM   #11
Tmibiker
Member#: 328048
2002 Impreza 2.5TS
Midnight Black Pearl
There's usually a metal plate inside the drivers side door sill that has a bunch of information on it, including date and month of manufacture. At least that's how it is on my '02.
Tmibiker is offline   Reply With Quote
Old 12-14-2012, 02:50 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I don't know what date they switched, but just stick your hand under the car and feel for the drain bolt. It's directly under the front drive axles
If it's an "outie" bolt, you need a 21mm.
If it's an "innie" bolt, you need a T70 torx bit.
Old 12-16-2012, 11:18 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah...but what size are the threads???
Old 12-17-2012, 06:16 AM   #14
UnknownAlly
Member#: 277330
2004 WRX
Thanks, I didn't know I could check without having to get under the car #lazy
05 wrx tranny wont bolt up to an 04? subbie doo Transmission (AT/MT) & Driveline 2 07-01-2009 08:23 PM
Need Advice: Pep Boys Stripped Tranny Drain Bolt Threads on BELL HOUSING (04 WRX) shinsain Transmission (AT/MT) & Driveline 21 10-17-2007 01:41 PM
Downpipe to tranny braclet bolt size? MF-DIF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-21-2006 09:44 PM
im dumb, wheres the tranny drain bolt? 409Industries Service & Maintenance 3 10-02-2005 06:56 PM
04 WRX tranny drain plug - pic and question SIMPFLY Service & Maintenance 8 01-24-2005 01:29 AM
