Old 11-14-2009, 07:30 PM   #1
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default Stock 2010 LGT 6MT Dyno Graphs
I thought some people might be curious about the new front mount turbo setup on the 2010 LGT.
The first pull was rather impressive. The rest were not and we couldn't figure out why. Stability control was off for all pulls. We gave it time to cool off nicely between pulls. I'm sure whatever made the stock ECU reduce the boost on the later pulls can be fixed via custom tuning once this new ECU code is mapped.
Event: dyno pulls
Ambient Temp: ~55
Elevation: ~700 feet above sea level
Weather: partly cloudy
Tires: uknown
Car: 2010 LGT 6MT
Tuner: stock ECU on stock tune
Dyno Info: Mustang AWD 500 SE
Peak HP at RPM: Multiple graphs shown. All are SAE corrected.
Peak Torque at RPM: Multiple graphs shown. All are SAE corrected.
Baseline hp/tq for a stock on same dyno: 198-199 whp 217-220 wtq for 2008 STI 2.5L
Target Boost: 10-12 psi or 5-12 psi depending on the run
Target AFR: stock ECU
Fuel: 93 unleaded
Engine/Power Modifications: none
Driveline Modifications: none
Suspension Modifications: rear sway bar only
Other Modifications: aftermarket wheels/tires
Innovative Tuning is offline   Reply With Quote
Old 11-14-2009, 08:13 PM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Interesting....
TDagen is offline   Reply With Quote
Old 11-14-2009, 08:26 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Hey guys, please edit your post to reflect the new required format found in the Sticky at the top of the forum, to avoid having this thread closed. Thank you
Audiosavvy is offline   Reply With Quote
Old 11-14-2009, 08:28 PM   #4
afviper
Member#: 89493
2001 330ci
So the 2010 LGT makes more torque than the STI nearly everywhere in the rev range?
afviper is offline   Reply With Quote
Old 11-14-2009, 08:45 PM   #5
Remnex
Member#: 83790
Would you look at that...
Remnex is offline   Reply With Quote
Old 11-14-2009, 08:51 PM   #6
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Hrmmmmm....
BUILTSTI is offline   Reply With Quote
Old 11-14-2009, 08:58 PM   #7
KurtP
Member#: 44836
1999 Fozzy
short runner manifold ftw....
KurtP is offline   Reply With Quote
Old 11-14-2009, 09:09 PM   #8
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
just the difference of an up-pipe correct? lol, all subaru has to do to update the sti is drop the lgt's drivetrain in it and tune... 320 hp?
Nimbus09 is offline   Reply With Quote
Old 11-14-2009, 09:36 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That 08 STI looks very unhappy. Have you dyno'd any other stock 08 STI's?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 11-14-2009, 09:57 PM   #10
slowgrey08
Member#: 211738
2015 STI LE
2014 SWP Forester XT
have you run any 09+ sti's? the mapping is supposed to be a lot diffrent.
slowgrey08 is offline   Reply With Quote
Old 11-14-2009, 09:58 PM   #11
KurtP
Member#: 44836
1999 Fozzy
No, there is no up-pipe. The turbo sits right under the motor with a short runner manifold (not sure if the USDM is a TS or not, I think JDM is....)
Im guessing the turbo is also bigger than previous years, simply by the fact it is making as much/more power than a 07-09 lgt with ~5psi less boost. Pretty significant....
Old 11-14-2009, 10:19 PM   #12
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
uhhh, that's what i said?
anyway, isn't the turbo a vf 52, same as the new wrx's? the fhp figures are the same between the cars but the leggy has a bit more ftq.
any lag?
Old 11-14-2009, 10:26 PM   #13
KurtP
Member#: 44836
1999 Fozzy
any lag?
I read the difference of an uppipe to mean a different uppipe, sorry.
I think it is a VF56, actually. The thing I find interesting is it makes the 225ish that, for example, my 09 legacy did, but its doing it with 4-5less pounds of boost. I dont know if the wheels inside the turbo are the same as a vf52, but again, I dont see the manifold making up the difference in power of 5psi.
The boost response seems to be slightly quicker than with the previous model too. The new manifold does a great job of making power efficiently.
here is a graph of a 08 legacy vs a 10 on the same dyno, both dynod in 4th gear on a 6spd box.
Old 11-14-2009, 11:40 PM   #14
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
^ no worries. could have worded my statement better.
both are 6spd's but they're different boxes though. one is an sti tranny the other is the usual 5spd + 1 more gear (with different ratios, of course). are the ratios of 4th the same between the two trannies? if so, that on top of the absent up pipe might make the 5psi diff, no?
Old 11-15-2009, 12:02 AM   #15
KurtP
Member#: 44836
1999 Fozzy
Not sure what the difference is of the gearing, but it wont make that big of a difference either way, I dont think. I didnt realize the 2010's are sti trannies.
I think the fact that its a short runner/el manifold is what makes the difference, so yeah part of that is the sans up pipe design....
Old 11-15-2009, 02:36 AM   #16
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
actually, i meant the 08 spec b 6mt has the sti tranny. 2010 lgt 6mt's are the 5spd variant. lol, my communication skills are all out of wack today. sorry.
yeah, the ratios probably shouldn't matter.
Old 11-15-2009, 08:15 AM   #17
KurtP
Member#: 44836
1999 Fozzy
Spec b's dont have a Sti tranny...its a 6spd variant of the 5spd....
Old 11-15-2009, 06:11 PM   #18
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
spec b tannys are the sti 6spd with no dccd and no front diff and longer gearing. im like 98% sure
achavez is offline   Reply With Quote
Old 11-15-2009, 06:35 PM   #19
dye.sti
Member#: 136297
2012 WRX
OBP w/ Red and Flat Black
wrong.
+1 your correct
the new 2010 6-speeds are not STi spec transmission its a 6spd variant of the 5spd
dye.sti is offline   Reply With Quote
Old 11-15-2009, 06:38 PM   #20
KurtP
Member#: 44836
1999 Fozzy
I really don't think they are....I always thought they were until I was corrected by a friend who worked both at a large subaru dealer in the tech dept and also at one of the more reputable speed shops....not sayin I couldn't be wrong.....doesn't really matter either way for the topic though.
Old 11-16-2009, 08:51 AM   #21
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Sorry I totally forgot. Updated now. Thanks!
-- Ed
No more than any other 07-09 STI on the stock tune. Those are normal numbers for stock STIs and Evos on this dyno. Keep in mild filtering is on 25 on that graph so it doesn't smooth over the issues in the stock tune.
Old 11-16-2009, 09:14 AM   #22
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Practically the only thing they share is the case, thats it.
"Oh hey, my WRX is just like the STI because the body is the same"
cucamelsmd15 is offline   Reply With Quote
Old 11-16-2009, 11:53 AM   #23
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Mike, I have sent a couple of emails to you, please respond, and let me know
jigga is offline   Reply With Quote
Old 11-16-2009, 03:47 PM   #24
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
What he is meaning is that the case (as you caught onto) and thus size and strength of the spec B trans is like that of the STi...same cases but no DCCD and it has an open front diff. I'm not 100% certain on the gearing differences though...even then all of this is pending which STi you want to compare it too
The new 2010 legacy 6-spds are a variant of the 5-spd trans, as subaru has publicly released. I just wonder how similar the two really are...?
Also wondering what the weight is? do we now have a 'lightweight' 6-spd option or will it be a glassbox like the 5-spds?
Old 11-16-2009, 04:03 PM   #25
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
Both Innovative Tuning (NY) and EFI Logics (CT) get 219 whp, but they have huge torque differences. What gives? 205 wtq vs 245 wtq.
Dyno graph comparison - stock SOHC vs. stock DOHC Patrick Olsen Normally Aspirated Powertrain 41 07-09-2013 07:10 PM
100% stock vs. upgraded turbo dyno graphs desert pirate Proven Power Bragging 9 08-07-2006 01:50 AM
Stock Dyno Graphs HERE and ECU Thoughts adg016 Southern California Impreza Club Forum -- SCIC 16 07-14-2004 09:14 PM
Stock Dyno Graphs HERE and ECU Thoughts adg016 Bay Area Impreza Club Forum -- BAIC 8 07-14-2004 07:41 PM
Need STI stock Boost v. Air Fuel Ratios dyno graph Nivek-CA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-08-2004 07:21 PM
