Old 11-15-2009, 07:31 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default DIY MAF Wire Extension ( diy shielded sensor cable )
I couldn't find correct gauge wires I needed to extend the maf wiring for a blow-thru setup. So I made some:
A shielded wire is nothing more than a Faraday Cage around the signal wire. The concept is simple, wrap whatever you want with some conducting metal and ground it. This is important because it prevents interference when power carrying wires are close to one another. In case of the MAF wires, it will produce a clean signal when routing the wire around the engine bay.
When you undo the harness, there will be some shielded wires that look like:
From what I've read, this is usually the yellow/blue wire. But on my car it was white. Either way, these two wires cay the maf signals so I decided to shield both.
So to make some shielded wires, stretch the wire, grab some spray glue, and cut a 1" thick strip of aluminum foil (the heavy dudty stuff) as long as the wire you will coat:
Spray the foil with glue, wait a second for it to get tacky, then wrap the wire with it:
Once that's done, get some dollar store twisty tie and cut and strip a piece the length of the wire. It looks like:
Run it down the length of the wire, then finish wrapping the aluminum foil around:
This wire will be used to ground the aluminum foil wrap. Now get some shrink tubing and coat the whole thing:
Next, solder some regular wire to the solid wire, this is the wire you will ground, The finish up with the shrink tubing:
Next, solder your extension to the original maf wire and make sure the ground can reach the firewall
You're going to do something similar with the wires that have shielding on them. I first strip them:
I then soldered the inner wires together and covered them with some liquid electrical tape:
Bad Noodle is offline   Reply With Quote
Old 11-15-2009, 07:32 PM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Then i wrapped the inner wires with a layer of foil and soldered the outside wires together: (kinda hard to see)
Then wrap that in some electrical tape. Wrap everything with some wire loom and run wire to where you will be putting the maf:
From here just strip wires, solder on plug and you're done. You don't do anything to the shielding on the maf plug end
Old 11-15-2009, 10:46 PM   #3
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
hope this harbness works for you.
scby rex is offline   Reply With Quote
Old 11-15-2009, 11:23 PM   #4
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Yes, harbness.
I extended mine w/o shielding it and it worked fine (Yes I was aware it was shielded).
My motor has to come out for some other crap, though, so I'll probably go ahead and try this.
CKxx is offline   Reply With Quote
Old 11-16-2009, 12:44 AM   #5
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Would shielded audio or video cable work? Chop connectors off, strip, solder... I'd think the the spooled cable would work pretty well for this, it's built with the assumption that someone's gonna want solder up to the conductor, and the shielding too for that matter.
Old 11-16-2009, 06:50 AM   #6
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
That was my first thought, but I haven't found audio cable that's the correct gauge unless it's a monster or something expensive. And I don't want to chop up a monster.
I tried to match the thickness of the wire coming out of the ecu.
I admit that this is probably overkill or maybe even unnecessary, but I didn't want to run into any strange issues. This was cheap to do as well. I think it was a total of like $6 for everything. I figured it was worth the piece of mind.
Old 11-16-2009, 09:53 AM   #7
Mechie3
Member#: 120152
McMaster carr has tinned copper braiding that works well for this. Simply push the braid together to get it to expand, put the wire through it, then pull the ends to tighten the braid. Ground one (or both) ends.
Part number 5537k26 is 1/4" ID copper @$1.13/ft, SS is part number 1478T1 and is $2.10/ft.
Mechie3 is offline   Reply With Quote
Old 11-16-2009, 10:11 AM   #8
CKxx
Member#: 33458
93 RX7+09 Forester
For those of you who understand this stuff better, is there any reason I can't just shield the whole 6-wire bundle rather than taking it apart and shielding the single signal wire?
Old 11-16-2009, 10:25 AM   #9
Mechie3
Member#: 120152
Yes. You want to isolate that single wire by itself. Bunching it up prevents signals from outside the bundle from getting in, but doesn't prevent electrical noise occuring from within the bundle.
Old 11-16-2009, 10:29 AM   #10
LastResort
Member#: 99289
Usually it is inadvisable to ground both ends as this can give rise to current flow and induce error onto the signal wire. Ideally you ground at the source of the signal.
Bundling the wires together will not prevent cross talk between the wires.
LastResort is offline   Reply With Quote
Old 11-16-2009, 02:09 PM   #11
Haelan
Member#: 151045
2013 Subaru STI
CBP
Glad you got the kinks worked out.
Just to add some engineering notes--when a wire has current flowing though it it creates a small magnetic field around said wire. This magnetic field can induce currents in other wires in close proximity ie. 'cross talk'. To prevent cross talk you can twist the power wire and it's ground wire together. Take a look at how Ethernet cables are twisted pairs--same concept. They are twisted together to prevent cross talk and reduce noise.
This concept works since the same current flowing to the device on the power wire is flowing out of the device in the opposite direction on the ground wire. These magnetic fields actually cancel each other out.
Shielding a cable in the above manner does not prevent cross talk. It prevents RF and EMF from causing havoc with the sensors and ECU. Any wires lying around act as antennas that pick up a lot of noise from the background. The longer the wire run the more prone it is to such interference.
Haelan is offline   Reply With Quote
Old 04-05-2012, 06:31 PM   #12
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Good thread. Thanks!
wgr73 is offline   Reply With Quote
Old 04-05-2012, 09:00 PM   #13
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
does this work? Do you think I would get away with using shielded audio rca cable?
scootarida1 is offline   Reply With Quote
Old 04-05-2012, 09:36 PM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
probably not because rca cables are not the correct gauge on the inside. I did switch over to real shielded cable I got from www.aircraftspruce.com/ and didnt' notice any difference
Old 04-08-2012, 05:29 PM   #15
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Originally Posted by Bad Noodle View Post
probably not because rca cables are the correct gauge on the inside. I did switch over to real shielded cable I got from www.aircraftspruce.com/ and didnt' notice any difference
which cable did you buy from there? Do you have a part number
Old 04-13-2012, 07:22 PM   #16
Tlove subaru
Member#: 287096
2010 impreza
black
Hello I'm looking for the wire colors for the maf sensor for a 2010 subaru impreza can anyone help me figure it out?
Tlove subaru is offline   Reply With Quote
Source of rear O2 sensor wire extensions Flaps Normally Aspirated Powertrain 16 12-28-2011 06:55 PM
Extending MAF wires - wierd white wire ? Bad Noodle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-13-2009 08:41 PM
removing MAF connector from MAF wires garagedefeat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-30-2007 04:02 AM
Oem Spoiler: WIRE Extension Voltron Private 'Wanted' Classifieds 2 02-18-2004 11:02 PM
questions about DIY 5-wire WB sensors Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-16-2003 10:26 PM
