#1 |
Member#: 54918
Event: Phil Grabow Hydra EMS Tune
Location: Element Tuning, Gaithersburg, Maryland Ambient Temp: 68.92 degrees Elevation: Sea level Weather: Raining Track and Conditions: NA Tires: Michelin Pilot ![]() I wasn’t really sure what to call this turbocharger as it’s based off of what we call the GT75 but this is a GT series housing with a Garrett 75 lbs compressor wheel and a Tial 1.03 exhaust housing. This was changed from the FP HTA since that was damaged (oil seals). We made a little more power on pump 93 hitting 524 whp up from about 503 whp. It did spool a little slower than the HTA but had more top end. Very impressive for pump gas especially on this dyno! On VP Q16 power was very good. There was some boost taper and overall we wanted more boost but that’s all the WG had in it. Upon further inspection we pulled the WG apart to upgrade the springs and noticed the diaphragm was folded over so this could have caused some issues. We’ll get stiffer springs in there and turn up the boost! Target boost will be 35 psi which this turbocharger should have no issues running. Tuning went well and power came easily with boost. So far no sign of detonation issues as boost was increased or any other difficult symptoms. We did have misfire issues the last time the car was on the dyno but that was corrected with very tight spark plug gaps. Car: 2007 Subaru STi Tuner: Phil Grabow, Element Tuning Dyno Info: Dynajet Peak HP at RPM: 629.02@7600 rpm Uncorrected Peak Torque at RPM: 405.94@6600 rpm Uncorrected Baseline: 08 WRX 184 whp Uncorrected Target Boost: 25-28 psi Target AFR: 11.3 Fuel: 93, VP Q16 Engine: Cosworth Long Block Intake: Cosworth Turbo: Element Garrett/Tial 75 lbs T3 1.03 Header: GT Spec? Exhaust: 3”? Fuel System: 1600cc, A1000 Fuel Regulator and pump EMS: Hydra 2.6 Engine Management Driveline Modifications: Exedy Triple Suspension Modifications: Tein Coilovers Again this setup has been similar to the other large turbochargers I’ve tuned with the Cosworth cams and or head package. It just doesn’t like variable cam timing advance but really big turbochargers like this are all about the top end. On the next runs I may push the RPM a little further if oil pressure looks ok. For now I’m limiting the engine to 8k rpm but clearly it will make power to about 9k rpm Thanks, Phil Grabow
#2 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
WOW on lots of different accounts. The power...and having 300ft/lbs of torque at 5400rpms
But when you're reving that thing out past 8k who cars??Is this vehicle your shop car? Customers? I assume racecar only? This would be quite the handful on the street ![]() |
#3 |
Member#: 54918
It's a street car for now and it's a customer car. She's definitely a screamer! Honestly it's too much power for this car's suspension and tires. LOL! I think an upgrade is definitely around the corner.
#4 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
great looking graph phil
congrats to the owner must be a joy to drive...definitely not too much power for the street ![]() |
#5 |
Member#: 54918
Thanks but it's not enough power
Stiffer WG spring it is! I think we should see about 700 whp when done unless the T3 exhaust housing results in too much back pressure. So far there were no signs of this so I'm optimistic that 35 psi should get us there. |
#6 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
I can't imagine daily driving this |
#7 |
Member#: 54918
Why it's a pussycat up to 5k rpm
#8 |
Member#: 167462
SCIC
Vehicle:2003 wrx sedona red |
this thing screams above 5K. Any vids of the dyno by any chance? I'd love to see this start spooling
#9 |
Member#: 54918
Maybe we'll work on that for the next pulls at higher boost.
#10 |
Member#: 195473
Vehicle:2007 STI OBP |
Thank you, it is AWESOME and I have not even driven it on race gas yet ! Phil has done wonders with this car ! Will try to get some videos and a time slip here shortly of this beast !
#11 |
Member#: 59238
SWIC
post some pics of this beast
#12 |
Member#: 90436
TXIC
Vehicle:2005 STI Obsidian black pearl |
big turbo, big power. nicely done. for a street car though its a bit overkill for my tastes.
#13 |
Member#: 204644
Vehicle:2005 STi 10.7 @ 125 FPRED PUMPGAS 93oct |
your the only person that has no issues with hydra's....
strange |
#14 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
^^^ I have never had a problem with any of the hydras I have tuned.
#15 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
when are you hitting full boost in 4th gear?
Look like in this graph around 5800? The boost threshold on that looks................less than optimal. |
#16 | ||
Member#: 48713
NESIC
Vehicle:1888 Bellipotent Wooden |
Seems like you've contradicted yourself.
#17 |
Member#: 77470
no not really because they weren't major problems just small quirks do to the earlier software that just made it a little more time consuming to get the cold and hot start dialed in,other than that the cars ran fine.
#18 |
Member#: 78884
Vehicle:Go faster at TopSpeed |
What kind of boost does it make in 1st or 2nd.. Awesome numbers no doubt, but hell I have seen 42r's with faster spool.
Doug |
#19 |
Member#: 54918
It's likely a combination of parts that increased the lag we have built similar setups that have spooled much quicker. I just have to work with what I've been given. I do my best to work with customer has and then recommend different parts if they feel an improvement needs to be made.
Just getting off the plane from Seattle after tuning multiple 600+ whp Subarus so we'll get those posts up soon. Our GT65 bolt on made over 450 whp on 92 octane with a car that didn't even have bigger valves which was very impressive at only 22 psi. Now for me being the only person that doesn't have problems with Hydras to that I say we've sold thousands and really it's only a few tuners that really struggle and have consistent issues. I am the source and there hasn't been a car I've been flown in to sort that I haven't been able to. It's 99% of the time tuning issues. The Hydra has very advanced options and very high resolution so it takes more than an average tuner to make a difficult setup great. I'm always available to help guide tuners and when that is not enough I'm available to travel. Thanks Phil Grabow |
#20 |
Member#: 192024
Vehicle:06 sti drag car silver, built by the shop |
i have a hydra for sale anyone interested??
#21 |
Member#: 195473
[IMG]
[/IMG]This is what happens when a Cosworth head gasket blows ! Was told Cosworth gaskets are not as good as the oem gasket, it sure sucks having only 4000 miles on a longblock and this **** happening. And of course Cosworth won't stand behind their $15000.00 built engine ! Slight hydroloc also caused one connecting rod to be slightly bent, having to replace rods and block of course, thank god everything else is alright. |
#22 |
Member#: 78884
who says cosworth gaskets aren't as good as stock?
#23 |
Member#: 95840
NWIC
Can you get a high resolution pic of the piston tops?
Looks like you may have had a massive lean spot? |
#24 |
Member#: 133146
Lately Cosworth FTL
#25 |
Top Scoob 019
Member#: 43630
Vehicle:2004 GT40R-built 2.5 604 whp @1.8 BAR on VP109 |
wow...
What head studs do they run 11mm??? looks like what happened to my engine with a blown headgasket took a chunk out of the block and the head.. both junked (not cosworth though).. |
| Thread Tools | |
| Display Modes | |
| Element Tuning Hydra Nemesis Stand Alone ECU for STI | HeK | Engine/Power/Exhaust | 3 | 04-16-2011 10:47 PM |
| Element Tuning Pro Comp 2.5 STi Engine, Hydra EMS, GT75, Hydramist 602 WHP | Element Tuning | Proven Power Bragging | 9 | 11-16-2009 06:43 PM |
| Accept no compromises -- Element Tuning Hydra EMS and HOA 3-Port Boost Solenoids! | WorldOne | Engine Management | 144 | 11-09-2009 01:17 PM |
| Element Tuning HYDRA EMS 2.5 02-05 WRX w/ LAUNCH CONTROL | dan avoN7 | Engine/Power/Exhaust | 27 | 06-03-2009 02:17 AM |
| October Sale on Element Tuning Hydra EMS v2.6 and Cobb Accessports! | WorldOne | Engine Management | 59 | 12-23-2008 03:30 PM |
