Old 11-16-2009, 05:44 PM   #1
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Default 2.5L VF39 Road dyno lots of HP/TQ
Event: Road Dyno
Ambient Temp: 38*F
Elevation: 4400'
Weather: Clear, cool, and dry
Track and Conditions: asphalt, clean, flat
Tires: Potenza RE019 225/45R 17 (Brand new)
Car: 2006 STI
Tuner:Keith Astley
Peak HP at RPM:
Peak Torque at RPM:
STi 2.5L
Target Boost: 24 psi
Target AFR: 11.7
Fuel: E85
Engine/Power Modifications: 3" APS TBE Ceramic coated and heat wrapped
65mm APS CAI
3" APS inlet
Stock header ported Ceramic coated and heat wrapped
Grimmspeed Crossover pipe Ceramic coated and heat wrapped
Grimmspeed 38mm EWG up pipe Ceramic coated and heat wrapped
Tial 38mm EWG
Grimmspeed EBC
Grimmspeed MBC
Grimmspeed 8mm phenolic spacers
TGV deletes ported polished and Ceramic coated
20x7.5x4.5 TMIC (Core measurements)
830cc injectors
1 step colder plugs
Suspension Modifications:
17x8 45 offset RFP1 PC black
H brace
Front and rear strut town bars
Tanabe GF210 aprings (stock struts)
27mm WL front Sway
22mm WL rear Sway
WL end links
Stainless brake lines
DBA 2 piece slotted Rotors
Hawk Blue pads
Brake fluid
CT Front splitter
255 40r 17 NT01 (track only tires on stock BBS)
logging team:
I can't remember any more engine stuff right now....
I am hitting 24.23 PSI at 3164 RPM and hold 18.14 at redline (6958rpm) I am adding a APS BOV probably next week to see if I can hold it any better/longer.
Keith Astley is doing all the magic. I stopped tuning my car when I was 91 octane and about 275. Ketih and I started talking about E85 and since I have a pump close to my work I decided to give it a show. It's like crack for me. I don't think I will ever get off the stuff....
medamullet is offline   Reply With Quote
Old 11-16-2009, 05:49 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
wow prepare to flame , WHP?
E85 FTW
GL
Old 11-16-2009, 06:02 PM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I log everyday I come home from work with at least 4 logs. This was this mornings log. They very from 340 hp to 370 pretty consistant. (not same stretch of road, and so on) tq ranges from 360 to over 400 again not same stretch of road. I understand that I can change the setting to get what ever numbers I want I really could care less what the numbers actually are. I use ECUedit and AB just to compare, todays AB numbers for the same log 362/392 I use the same parameters for both pieces of software to try to eleminate as much inconsistance as possible. Obviously every dyno puts out different numbers.
It's fun to drive and pulls like a MF. It ripped the steering wheel out of my hand the other day. I was going under a bridge and wanted to hear the EWG. 1 hand on teh shifter and 1 hand on the wheel, 2nd gear WOT torqued teh wheel right out of my hand. Scared me
Old 11-16-2009, 06:52 PM   #4
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
dude... what the hell is going on up top? u drop like 275whp by redline. have plans for the track, curious to see a trap. make sure u shift at 6k
STi Mikey is offline   Reply With Quote
Old 11-16-2009, 06:58 PM   #5
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
That is an unusual power band. You don't make 300whp until north of 4000rpms.
crand002 is offline   Reply With Quote
Old 11-16-2009, 07:52 PM   #6
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
here is tonights AB spread sheet. I added full tank of fuel AND 3 kids, 13, 10, 9 so it's about 260lb more.
I am not too into the numbers. What I care abotu is when do I hit full boost, 3100ish rpm, and what is it at readline 18psi.
It's fast, real fast.
I track it Miller Motorsports Park FTW
Old 11-16-2009, 08:01 PM   #7
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Man, that is really impressive power for the stock turbo. I was able to hold 310 @ redline on 100 octane, looks like you'll hold more. 18psi @ redline for the win! Get to the track!!
Old 11-16-2009, 08:17 PM   #8
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
What gear?
OppositeLock is offline   Reply With Quote
Old 11-16-2009, 08:18 PM   #9
juanmedina
Member#: 133146
now that is more believable I made 346whp 404wtq, sick car you should post your logs here
http://forums.nasioc.com/forums/show....php?t=1728653
Is the EWG Mikey, this car is just like Downsti's car
Old 11-16-2009, 08:45 PM   #10
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
This thing hauls ass... from **** eating grin experience last week...lol
Kastley85891 is offline   Reply With Quote
Old 11-16-2009, 08:47 PM   #11
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
these logs were both in 4th gear. I don't like 4th, I think it puts too much load on the motor. I am more of a 3rd gear fan.
I posted these in 4th becuase I knew the numbers would be bigger
I will post my logs there as well. I wanted to only post there once. Since I am pretty much done for a while I will post them up. I log and tune everyday, so I make LOTS and LOTS of graphs. haha.
I am going to take my car to Cobb and put it on an actual dyno. There are a few non believers here in Utah as well even if I pull 320/350 on that heart breaking Mustang dyno I will be happy.
Old 11-16-2009, 08:53 PM   #12
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I suck on the 1/4 mile track. I went to the last midnight drags a few months ago, just to see what I can do. I showed up too late to run so I just watched. The idea was for me to take 1 run. Then let my Stig brother drive. He runs low 12's in his 18g bugeye. He is a good driver. I will get out there at least once next season. I like Miller much better.
Old 11-16-2009, 09:02 PM   #13
OppositeLock
Member#: 54060
Old 11-16-2009, 09:14 PM   #14
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
sucks your power falls on its face after 5k.
scby rex is offline   Reply With Quote
Old 11-16-2009, 09:16 PM   #15
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
its a small turbo
here is boost and WG
Old 11-16-2009, 10:14 PM   #16
cireturbo
Member#: 119777
2013 BRZ
Originally Posted by OppositeLock View Post
I'm glad I wasn't the only person who noticed this...
cireturbo is offline   Reply With Quote
Old 11-16-2009, 10:26 PM   #17
juanmedina
Member#: 133146
4th tops out at what on a Sti? 120
I am not hating..............
Old 11-16-2009, 10:47 PM   #18
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
please.... haha, where I log there isn't a sole out there. I have a secret spot. Call the kettle black I am teh last guy you will see driving like an asshat on the roads....
I thought you were saying I have fat kids. 260 was including the full tank of fuel as well.
I don't think the 06 gets to 120. i will look tomorrow morning. I think it's just over 100. my 3rd gear is about 85. (Utah freeway speed) If you aren't going 85 when you merge you are getting run over! haha
Old 11-17-2009, 02:00 AM   #19
GeneralTJI
Member#: 152680
Sounds like it runs good for a stock turbo.. but maybe make the WOT pulls without the kiddos?
GeneralTJI is offline   Reply With Quote
Old 11-17-2009, 02:22 AM   #20
WRrexu
Member#: 217061
2009 Wrx
am i the only one noticing he took his 3 young children in his 360 whp sti topping out 4th gear ? ( OVER 100 MPH ) honestly, no matter where you do it, i think you are the most irresponsible person ive ever ..come across in my life.
dude. im 19 years old and ive done stupid **** but that ...is just sad if you take ur kids in ur car doin anything over the speed limit. shame on u...
what r u thinkin
WRrexu is offline   Reply With Quote
Old 11-17-2009, 04:20 AM   #21
subynation
Member#: 229023
06 STi
obp
ive found that just letting it go works the best.
the 2 big things that always stay the same are
1)common sense isnt so common anymore
2)natural selection ALWAYS wins in the end
your an asshat for doing that with your kids.regardless of location you wouldnt see your kids for 30+ days if CPS ever caught wind of it.
subynation is offline   Reply With Quote
Old 11-17-2009, 08:18 AM   #22
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
Nice numbers not so much on the kids though I don't even do pulls with my younger cousins in the car (13 and 16)
DarkKnightBaku is offline   Reply With Quote
Old 11-17-2009, 09:12 AM   #23
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
You are all right, bad call. I am not going to justify my doings.
Back on track If anyone is interested I will post todays runs. my WB was going crazy on some of my pulls yesterday. Everything is reset so I will post up my AF today.
Old 11-17-2009, 09:39 AM   #24
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
what r u thinkin
wow, this guy is a douche.........
BUILTSTI is offline   Reply With Quote
Old 11-17-2009, 11:50 AM   #25
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
what r u thinkin
I noticed the same thing. Irresponsible, negligent, and just being a total tool. WTF?!
t
WolfPlayer is offline   Reply With Quote
2.5L VF39 E85 CAMs and Ported heads VS 2.5L VF39 E85 juanmedina Proven Power Bragging 156 09-05-2009 04:27 AM
Cobb Tuning 2.5L NA Build - Dyno Results [LONG] Trey Normally Aspirated Powertrain 99 04-03-2007 03:06 PM
2.0L to 2.5L short setup: Dyno session questions? MarylandEcstasy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-01-2006 11:54 PM
Is my 2.25 axle back restricting a lot of hp? datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-08-2003 05:42 PM
