Old 11-16-2009, 10:58 PM   #1
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Default 2.5L 05 STi + Blouch Dom 3.0 XT-R makes 380whp and 355wtq
Event: dyno pull/tune
Ambient Temp: 69 F
Elevation: The elevation of Houston, TX is 43Ft.
Weather: sunny, dry, clear, cool, low humidity
Tires: Potenza RE 010 245/45/18
Car: 2005 STi
Tuner: Brad
Dyno Info: DynoDynamics
Peak HP at RPM: 380.8 @ 6500
Peak Torque at RPM: 354.9 @ 4900
Baseline hp/tq for a stock on same dyno: 218-228 whp
Target Boost: 24 psi
Target AFR:11.5
Fuel: 93 unleaded Shell V-Power w/ 100% Meth injection
Engine/Power Modifications: dw 850 injectors, catless invidia bellmouth dp, Tanabe Medallion Touring 3" CBE, grimmspeed port polish/ceramic coated manifold and uppipe, custom 72mm short ram intake, aps inlet, txs large topmount I/C, spec C I/C sprayer/tank, smc 100% meth injection, 1 step colder ngk iridium plugs, walbro 255, grimmspeed ebcs, grimmspeed tgv deletes port and polished/ceramic coated and phenolic spacers
Driveline Modifications: ACT streetlite clutch and flywheel
Suspension Modifications: Prodrive STi lowering springs (eibach), strut tower braces
Other Modifications: Advan RS 18x8.5
this is comparison to my former FP Green w same supporting setup (blue): dom 3.0 xt-r and (red): fp green
krambte79 is offline   Reply With Quote
Old 11-16-2009, 11:24 PM   #2
oversteer
Member#: 14923
2007 Subaru turbo
Thanks for posting. Considering you have a TMIC the spool appears to be a bit lazy. Other Dom3 XTR dynos showed faster spool. Less load with this brand of dyno?
oversteer is offline   Reply With Quote
Old 11-16-2009, 11:29 PM   #3
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
i wonder if those have the same hot side. i have the 10cm^3 hotside which i believe makes for slower spool. however i am not well versed/educated on any of this. i am not sure about the load w/ this dyno
Old 11-16-2009, 11:31 PM   #4
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
the others i have seen also appeared to spool about 1kRPM sooner.
they were also XTR turbos.
look for IAG's graphs, numbers aside the spool does look lazy.
jnorth85 is offline   Reply With Quote
Old 11-17-2009, 10:38 AM   #5
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1 spools late, also power look a bit low for running pump and meth. Even for the dyno... Maybe is from the tmic? Not trying to bash, just comparing other results Ive seen.
rexworx is offline   Reply With Quote
Old 11-17-2009, 11:03 AM   #6
jnorth85
Member#: 76785
SRP
you should be making way more power than the FP green that was on there previously.
here is IAG's graph, the TMIC should not make that big of a difference, if anything it should improve the spool.
Here is the thread for reference.
http://forums.nasioc.com/forums/show...&highlight=IAG
Old 11-17-2009, 11:19 AM   #7
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
I'm almost sure that the Dyno Dynamics they're using is not on 1.2 CF.
Soo looks about correct...
BUILTSTI is offline   Reply With Quote
Old 11-17-2009, 11:28 AM   #8
jnorth85
Member#: 76785
SRP
Jorge, will never display a CF so the IAG dyno is also Uncorrected.
Old 11-17-2009, 11:57 AM   #9
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
ya, uncorrected dynojets read LIKE Dyno Dynamics on 1.2CF
understand?
If you put a stock sti on a dynojet it would make about 240 - 250whp uncorrected
Old 11-17-2009, 12:06 PM   #10
jnorth85
Member#: 76785
SRP
understand?
Understand numbers wise.
but look at the curve.
Old 11-17-2009, 12:08 PM   #11
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
what about the curve?
Turbo looks very laggy on this car.
Not very impressed with the turbo anyway.
FP has had a turbo that could do this for years now.
Old 11-17-2009, 12:13 PM   #12
jnorth85
Member#: 76785
SRP
very laggy on this car, the car in IAG's graph has a FMIC and spools quicker. something isnt right.
FP has not had a stock location turbo that could do this.
un-impressed or not something is not right about the results with OP's car.
Old 11-17-2009, 01:01 PM   #13
rexblake
Member#: 178426
2010 S4
Gray
Hey OP did you write down the wrong color for you turbo comparison? It looks to me like the fp green is red and the dom 3 xt-r is blue. Dyno Dynamics are notorious for showing late spool, does it spool any quicker on the street?
rexblake is offline   Reply With Quote
Old 11-17-2009, 01:44 PM   #14
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Yes FP has...
uhh it's called a RED
Old 11-17-2009, 01:49 PM   #15
jnorth85
Member#: 76785
SRP
Yes FP has...
The RED is no longer avaliable (check the site)
It only has an 8cm hot side, is journal bearing and does not have an HTA option.
it is not comparable. It WILL post the numbers but the power band will not be the same.
Old 11-17-2009, 01:56 PM   #16
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Journal bearing and not having a HTA option has NOTHING todo with this.
Yes it might only have a 8cm hot side, but that should only hurt the performance of that turbo.
With that said here is a FP Red on pump gas 93 octane.
This powerband would rape this or any other Blouch Dom 3.0 XT-R
Old 11-17-2009, 02:00 PM   #17
Blouchturbo
Member#: 119764
2006 STi
Yes FP has...
FP Red is 60lb per min turbo
FP Red is journal bearing
turbo was available with 7 or 8cm turbine housing
Dom 3.0XT-R
Blouch 55lb per min billet compressor
Uses a Garrett GT30R CHRA
Has a stock location 10cm turbine housing
The 4.0XTR is more like the FP Red as far as HP ratings go
Blouchturbo is offline   Reply With Quote
Old 11-17-2009, 02:02 PM   #18
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Dom 3.0XT-R
Love your turbos, just dont get why everyone is having such a circle jerk.
10cm turbine housing is tits
Old 11-17-2009, 03:11 PM   #19
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Hmmmm. Im not positive but confident that the dyno dynamics graph displaying 380 has a correction applied. If it didnt, its literally a 124mph car. Very doubtful. Dont forget 300whp on a dynodynamics on 1.0CF = 115 traps
STi Mikey is offline   Reply With Quote
Old 11-17-2009, 03:16 PM   #20
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
The IAG graph above is on 93, they tried q16 and the clutch said hell no.
2gnt2wrx is offline   Reply With Quote
Old 11-17-2009, 03:18 PM   #21
jnorth85
Member#: 76785
SRP
the IAG graph is on 93oct.
here is their Q16 graph, they had to let up early due to a slipping clutch
Old 11-17-2009, 03:26 PM   #22
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
How many pounds of boost were they running when they did the q16 tune?
Old 11-17-2009, 03:32 PM   #23
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Can you post up a graph that has RPM, not speed..
hard to compare to the other sheets
Old 11-17-2009, 03:35 PM   #24
jnorth85
Member#: 76785
SRP
Check out the thread it has lots of info in it
Old 11-18-2009, 01:24 AM   #25
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
no one asked why i switched turbo's ? i loved the green turbo on my car....however it did not last any longer than 600 mi before major shaft play and oil all up in the hot side. so decided to go w/ the Blouch and wow the fitment/install was much better than the FP. the FP did not fit well at all issues everywhere. the Blouch turbo definitely seems to be engineered better. my thoughts/my money
the red is the fp green and blue is the dom turbo graphs just read the heading again i know i could have worded it better.
yes i can definitely tell the difference in lag btwn the green and the dom; however, it does not feel as if it is that late in rpm band maybe somewhere near 500-800 rpm sooner than pictured.
hey, the car is fun to drive i will keep you guys posted on time slips....plan to head to track for run ASAP. i ran a 12.6 if i remember correctly at 109mph on my VF39 w/ meth rated at 300 whp on the same dyno so im hoping for high 11's/low 12's
FS Blouch Dom 3.0 XT-R 2.4" mywifesSTi NESIC Private Classifieds 25 07-13-2011 07:08 PM
Dyno Tune: IAG makes 409whp on 2.5L + Prototype Blouch DOM 3.0 XT-R IAG Performance Proven Power Bragging 155 07-13-2011 07:06 PM
Brand New Blouch Dom 3.0 Blacked out STI Engine/Power/Exhaust 4 06-08-2008 06:16 PM
Brand New Blouch Dom 3.0 Blacked out STI Engine/Power/Exhaust 7 06-06-2008 09:40 AM
