Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 11-17-2009, 09:38 AM   #1
chaoskingb
Member#: 176829
06 WRB STI
1 crazy clean machine
Default Slight Ticking on Cobb Stg 1 map
06 STi-
Has anyone had this problem on the stg 1 91 oct map?
I just ran the map on Sunday and noticed this morning a slight tick just before boost kicks in. Once im in boost, i cant hear it over the turbo but as soon as i come back down its there again.
I searched iwsti and there really was no conclusion
Anyone else have that issue?
thanks!
chaoskingb is offline   Reply With Quote
Old 11-17-2009, 09:44 AM   #2
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
do you have an aftermarket ebcs?
06HAWKMAN is offline   Reply With Quote
Old 11-17-2009, 09:46 AM   #3
chaoskingb
Member#: 176829
06 WRB STI
No only thing done to the car is Cobb Cat back, Spt intake.
sorry i should have included that lol
Old 11-17-2009, 10:06 AM   #4
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
a slight tick could be one of the compressor blades hitting the compressor housing???? how is it boosting? like normal? slow spool?
Old 11-17-2009, 10:26 AM   #5
chaoskingb
Member#: 176829
06 WRB STI
The spool is still strong as ever! Thats what i baffling me here. I read a few other places that people were having the same problem, examples were: Wastegate flutter, up pipe gasket blown, exhaust leak etc.
Im going to check peak boost tonight when i get home, but its pulling like it should and not hesitating at all
under acceleration in 1st & 2nd from take-off till about 3k rpm or so is about the time that i can hear it.
Old 11-17-2009, 11:08 AM   #6
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Could Be An Exhaust Leak But I Dont Think So Since You Still Have The Stock D.p., To Me It Doesnt Sound Like Wastegate Flutter But I Cant Hear It So Idk. Got A Vid?
Old 11-17-2009, 11:16 AM   #7
chaoskingb
Member#: 176829
06 WRB STI
Il get a vid up shortly, im not even quite sure if its loud outside of the car? If you sitting in the car, it sounds as if its comming from the passenger side inside the engine bay.
Old 11-17-2009, 11:30 AM   #8
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
that almost sounds like the ebcs to me?????? mine did that when i swapped my ebcs until i muffled the sound with a piece of foam for a damper
Old 11-17-2009, 06:13 PM   #9
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
question, what kind of intake?
if its a aps (or probably any other kind that goes into the fender) its probably the intake moving the metal that it goes through into the fender. my car makes that sound sometimes.
and then if not that, i would say predetonating could be your problem, my car was predetonating on the cobb map so i had to get a tune by cody! PM me for his number if you'd like
if neither of those, no idea
801_STi is offline   Reply With Quote
Old 11-17-2009, 06:55 PM   #10
nme187
Member#: 117763
Have you tried uninstalling the AccessPort and seeing if it's still present? Or datalog using the AccessPort when it happens then post the results here; we'd be able to tell you if it's tune related or mechanical.
nme187 is offline   Reply With Quote
Old 11-17-2009, 08:55 PM   #11
chaoskingb
Member#: 176829
06 WRB STI
I am going to uninstall it tonight, and see if i get the problem. It decided to stop this afternoon? i dont know if it being cold had effect on it or what? but il datalog it if its still doing it after i uninstall the map.
Thanks!
Old 11-18-2009, 05:53 PM   #12
chaoskingb
Member#: 176829
06 WRB STI
Anyone else running the Stage 1 ACN map? flashed to that this afternoon and the car runs 10x smoother. Even at idle it makes such a difference. Wel see tomorrow morning if the ticking is there...
Cobb stg 1 map compatible with aftermarket pulleys? xaznxeclipsex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-12-2008 03:11 AM
MPG on cobb stg 1 and 2? Need4speedTC AccessPort 30 07-28-2006 08:43 AM
Which version Cobb stg. 2 map is better? MF-DIF Engine Management & Tuning 4 03-05-2005 12:38 PM
New Cobb Stg.1 map better than the old version? MF-DIF Engine Management & Tuning 2 01-28-2005 06:00 PM
flashing CEL on cobb stg 1? surfer5567 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-05-2004 02:54 AM
