Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Go Back   NASIOC > NASIOC General > Motorsports > Press Releases
Old 11-17-2009, 04:12 PM   #1
Fine Line Imports
Member#: 81166
2008 Forester
Default 05 STI suspension overhall
Almost a year ago we finish up a customers 05 STI for him with a pretty complete package. This customers goal was to have a competitive hill climb/road coarse car while still being able to drive it a few days out of the week. With those things in mind Fine Line Imports built and tuned the car below.
After the 2009 Hoopa Hill Climb and a great first time outing for our customer and his car he wanted to change things up and completely over hall his suspension which was in dire need of some updating if more hill climbs and track days were in its future. With performance in mind Fine Line Imports set out to give this 05 STI the suspension boost it needed. With the only after market suspension parts staying being the COBB front and rear sway bars the list of things being added was long.
FLI's first call was to MSI/DMS North America for some of there top quality suspension and chassis components. Starting with a set of DMS 50mm tarmac spec coilovers with DMS front and rear adjustable camber plates, MSI rear sub frame, MSI laterl links, MSI front endlinks, MSI rear endlinks and the MSI antilift kit. Couple all that with Cusco trailing arms, Carbonetics carbon rear LSD, Powerflex front controll arm, rear I-beam and steering rack bushings and you get the car pictured below.
First step out with the old suspension.
Some of the new parts going on
Fine Line Imports is offline   Reply With Quote
Old 11-17-2009, 04:13 PM   #2
Fine Line Imports
Member#: 81166
2008 Forester
More new goodies for the install
Coilovers installed and installing the MSI rear sub frame. Installing the rear subframe requires removing the rear spare tire bracket and minor modification of the rear gas tank.
Rear subframe installed with MSI rear lateral links. With the car being decently low we opted to use the upper mounting points on the sub frame. If you car is near stock ride height you might want to use the lower mounting points.
Cusco rear trailing arms installed
Rear end almost all the way done
Car back on the ground and ready for fun.
Overall the change in the car from Tein Flex coilovers and COBB sway bars to this was nothing short of amazing. The car is solid and very planted in the corners with only a hint of over steer on corner exit if you really have your foot planted. With the DMS 50mm coilovers dialed down street driving is not bad at all either only a touch firmer then some of the RCE Tarmac 2 we have put on in the past. The only down side to the car is the rear diff noise which can drone at free way speeds but that was to be expected.
The addition of the MSI rear subframe really helps stiffen up the rear end of the car dramatically. Short of seam welding and a roll cage I do not think there is a better way to stiffen the rear of your car. I am very happy with the way the car performs overall and am looking forward to some more track sessions where I can fine tune the suspension for even better handling.
05 STI
Engine
ATP GT30
APS FMIC
APS fuel rails
PE 850cc inj
APS TBE
Tomei Headers
COBB AP ver2 with FLI protune
Suspension:
DMS 50mm Tarmac coilovers
MSI front and rear endlinks
MSI rear sub frame
MSI lateral links
MSI Anti lift kit
Cusco trailing arms
Powerflex steering rack bshings
Powerflex rear beam mount bushings
Powerflex front control arm bushings
Carbontectics rear LSD
Alignment Specs
Front camber -3
Rear camber -2
Toe out front and rear
For more info on this carat the Hoopa Hill Climbcheck out our blog at http://fliblog.wordpress.com/2009/08...ll-climb-2009/
and for the Stage 4 power package look here. http://fliblog.wordpress.com/2008/12/10/985/
If you have any questions about anything you have seen please ask.
Ryan
Fine Line Imports
www.finelineimports.net
Old 11-17-2009, 06:06 PM   #3
wrxmuch?
Member#: 196486
2004 WRX
That MSI sub-frame is ballin' out of control...... Like those trailing arms too.
wrxmuch? is offline   Reply With Quote
Old 11-17-2009, 07:13 PM   #4
Fine Line Imports
Member#: 81166
2008 Forester
Both pieces have worked out really well for us. I would not recommend the sub frame for a street car but if you do track days you will really like it.
Ryan
Old 11-18-2009, 02:58 PM   #5
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Does the owner want to sell the OEM lateral links?
MSP608 is offline   Reply With Quote
Old 01-10-2010, 10:50 AM   #6
MSI
Member#: 95419
Have there been any developments on this setup Ryan? Have you guys been able to dial the shocks in for your specific needs?
-mark
MSI is offline   Reply With Quote
Old 01-14-2010, 08:37 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Ryan
Absolute thumbs up on the rear subframe! We've been running one on our car since the middle of last season, and it has been wonderful.
Turn in Concepts is online now   Reply With Quote
Old 06-30-2010, 04:29 AM   #8
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Very interested in doing a similar setup in my car. I have to slighlty reduce the track in my 04STI as im running +30 offset wheels with 245 dulop R comps and we are getting some rubbing..
Im am interested in the adjustable lateral links and wondering if they start off smaller than the standard links or can be reduced at a smaller length..
Also in terms of sway bars which brands provide the best stiffness??
tino is offline   Reply With Quote
Old 06-30-2010, 05:33 AM   #9
jamal
Member#: 71875
98 2.5GT
my wheels fit
why on earth would someone make this thing and then not alter the anti-geometry or caster?
jamal is offline   Reply With Quote
Old 06-30-2010, 09:00 AM   #10
MSI
Member#: 95419
To allow it to be a legal part for NUMEROUS Motorsport categories.
The main benefit of this is it is giving a more constant wheel movement / geometry by removing the deflection inherent in OEM (as well as some of our competitors part).
You also do not need to shim the factory "U" frame.
-mark
Will 05 STi suspension fit an 05 WRX? craver Brakes, Steering & Suspension 12 08-28-2013 07:23 PM
Does an 05 STi suspension fit on the 05/06 WRX (non-STi)? Black-STi Brakes, Steering & Suspension 5 11-13-2006 09:07 PM
05 STI suspension on 05 WRX? SoCal818 WRX Brakes, Steering & Suspension 2 11-03-2006 09:44 AM
05 STi suspension in something other than an STI SubeSTIle South West Impreza Club Forum -- SWIC 6 07-12-2006 09:07 PM
stock 05 STi suspension VS stock 05 RS suspension erikm Brakes, Steering & Suspension 5 03-15-2006 11:55 AM
