Old 11-20-2009, 08:13 AM   #1
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
Default Up pipe leaks and loss of boost
If my up pipe isnt sealing well, could that cause a 10 psi drop in boost?
or would a leaky up pipe result more in a 2-3 psi drop?
xrocket21 is offline   Reply With Quote
Old 11-20-2009, 08:22 AM   #2
jays05
Member#: 78165
05 STI 35r + e85
It depends on how bad it's leaking. When I made my [email protected] pass I had a blown uppipe gasket, it was down about 4-5psi in 1st gear and pretty close to target boost in 5th, but I did jack up the wgdc a few % before that pass because I knew it was leaking.
jays05 is offline   Reply With Quote
Old 11-20-2009, 08:34 AM   #3
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
I dont know, it has a small crack in the collector, and I keep blowing out header/uppipe gaskets, pretty sure its currently blown again.
Old 11-20-2009, 10:18 AM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
If it was bad enough to drop your boost by 10 psi, it would sound like you were running open header or EWG. It wouldn't be a "leak", it would be a hole.
Old 11-20-2009, 11:16 AM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I found your boost, it's in my garage. For $5 you can have it back.
What "the suicidal eggroll" said
mick_the_ginge is offline   Reply With Quote
Old 11-20-2009, 02:09 PM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Car smoking and loss of boost riosseb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 01-24-2010 06:00 PM
Up-pipe leak = loss of Horsepower? BillyC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-21-2005 02:27 AM
Up-Pipe leak... different kind of question: Hazdaz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-23-2003 02:09 PM
UTEC, Up-pipe leak, and det DocDetroit Engine Management & Tuning 15 03-13-2003 05:23 PM
RE: Up-pipe leaks and removing turbo bracket bolts BeavisNuke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-13-2002 11:40 PM
