Old 11-18-2009, 10:12 AM   #1
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
Default Gas Leak-Not due to cold weather.
This just happened last night, I was at a stop light and I stalled out (I just recently started driving a stick shift) and on my way home, everything was fine (approx. 15 minute drive, on the highway ranging from 70-80mph) but when I got home and was in the driveway, I noticed a raw fuel smell in the cabin. I didn't think much of it, went inside and thought it would be gone in the morning.
This morning, I go in the car and still smell the raw gas in the cabin, I tried to start the car and it took longer than usual. As I'm driving to school, the smell still persisted, I had to crack the windows to breathe.
I get to school, pop the hood, and look around the engine bay and I look at the passenger side of the engine bay and I see a stream of gasoline protruding. I'm not really experienced with working on cars so I don't know exactly what I'm looking at. Here's a picture of the stream, it's camera-phone quality, but you can definitely tell what's going on.
In the middle of the picture, there is that black metal piece with little white bubbles on it. From what I can tell, there is a steady spray of sprinkling gasoline. I can't tell what's exactly going on. I'll try to get better pictures of it.
Can anybody here tell me what they think? Any advice would be very helpful.
Edit: I found out that the fuel injector is leaking. I drove it around, revved it up to 6K and then parked it to look under the hood again. The stream of fuel is less, so I'm guessing it's just loose? How do I tighten it to secure the fuel flow?
ChronicWRX is offline   Reply With Quote
Old 11-18-2009, 12:16 PM   #2
SLDWYZ
Member#: 85008
03 wrx
blue
have you had work done on the car recently like spark plugs or injectors ?
SLDWYZ is offline   Reply With Quote
Old 11-18-2009, 01:14 PM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
most likely the o-ring shrank or cracked, search around the injector installation threads for the "how to". You can find a replacement o-ring cheap at your local ace hardware but be sure it is viton.
fastnoypi is offline   Reply With Quote
Old 11-18-2009, 01:19 PM   #4
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
The car was stage 4 with a vf39 and STi Pinks, but it has since then been downgraded to a TD-04 and the stock injectors put back in.
Also, will it be safe to drive it, it is my daily driver.
Old 11-18-2009, 01:32 PM   #5
240sxguy
Member#: 229791
2002 WRX wagon
Spraying fuel out? No, its not safe to drive.
240sxguy is offline   Reply With Quote
Old 11-18-2009, 10:20 PM   #6
jwhitey
Member#: 116204
02 subaru wrx wag
white
I am having this issue, and mine is not due to the cold weather either. I will check this out on my car let me know how yours goes.
jwhitey is offline   Reply With Quote
Old 11-18-2009, 10:31 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
For future reference to anyone reading this...if you smell raw fuel...DO NO DRIVE AROUND AND HOPE IT WILL FIX ITSELF.
A good plan would be to grab a fire extinguisher and see if you can find and fix the leak.
CKxx is offline   Reply With Quote
Old 11-18-2009, 10:44 PM   #8
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
Well, It's my daily driver, and tomorrow's going to be the last day it's going to be driven until I get it fixed. Also, it's only dripping now. Nothing's spraying anymore.
Jwhitey: Yes, please tell me. My fuel injector is the one at the top left that's leaking if you're facing the engine bay from the front of the vehicle.
Old 11-20-2009, 12:26 AM   #9
jwhitey
Member#: 116204
02 subaru wrx wag
white
Cool I am going to check mine out tomorrow after I get off work. My car is mostly a garage queen during the work week, and then driven on the weekends. It was my daily driver at one time but I thought I would save some miles on her. I am going to see if mine is leaking/ spraying for sure and I will let you know what is going on with mine and maybe you are having the same issue.
Old 11-20-2009, 08:26 PM   #10
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
So what did you find out?
Old 11-24-2009, 11:21 PM   #11
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
Does anybody know if I have to worry about fuel pressure when I disconnect the injector? What are some things I need to know before I start pulling things out so I don't hurt myself?
Old 12-02-2009, 02:55 PM   #12
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
Okay. I'm finally getting around to working on my car (and no I havne't been driving it lol) but I do need to ask a couple of questions..
1.) Do I need to replace the seals as well as the O Rings?
2.) What is the size for the O Ring that I need?
Old 12-02-2009, 03:56 PM   #13
02RexWI
Member#: 165141
Stage 4
02RexWI is offline   Reply With Quote
Old 12-02-2009, 09:37 PM   #14
ChronicWRX
Member#: 221935
02 WRX PSM
Stage 2/Slow
Originally Posted by 02RexWI View Post
Stage 4
Stage 4 = small bolt on turbo + fueling + turboback exhaust + engine management
but now it's Stage 2
Stage 2 = turboback exhaust + engine management (Stage 2-Colorado Elevation to be exact, essentially, Stage 1 for Hampton Roads, Virginia. I've yet to re-tune the ECU...)
Read Unabombers thread for more info
http://forums.nasioc.com/forums/show....php?t=1471734
Speakers not working in cold weather All4thaN0okie Car Audio, Video & Security 12 01-26-2008 12:48 AM
have a gas leak when it gets cold...anyone know how to fix? boxerline Texas Impreza Club Forum -- TXIC 4 01-09-2007 02:40 PM
Gas smell that is not related to cold weather ImpreziveWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-08-2006 09:41 PM
My STI Does NOT like the cold weather!!!! Mikemar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-12-2004 05:28 PM
head lights not coming in cold weather reaubideux Electrical & Lighting 1 11-27-2003 10:28 PM
