Old 11-18-2009, 12:10 PM   #1
jacobbaz
Member#: 218474
05 Impreza WRX
Default STi pink springs on stock struts?
Looking to get a little lower look and slightly better handling.
Are STi pink springs okay to use on the stock struts?
I have about 46k miles on them right now
jacobbaz is offline   Reply With Quote
Old 11-18-2009, 12:26 PM   #2
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
Are you talking the aftermarket USDM STI/SPT pink springs for the WRX? or the JDM STI pink springs? From personal experience, the USDM pink springs will work well, though they'll be slightly under-damped. Many here will suggest considering STi stock take-off springs, since they give you a similar rate and drop for much less money if you buy them used. The JDM pink springs will be considerably under-damped when paired with the WRX stock struts.
thorongil is offline   Reply With Quote
Old 11-18-2009, 02:08 PM   #3
CGM6
Member#: 146911
^ what thorongil said is spot on. To sum up his last part, the JDM pinks will likely eat up your struts, while the USDM pinks were made for WRX struts. With that said, STI take-offs will work as well.
I personally went with the Mach V WRX springs-perfect drop for someone like me that drives 80 miles everyday and has 4 months of snow each year with a nice increase in handling (slightly less body roll, etc). They are $199 shipped right now from MachV, so not a bad deal at all-still not as cheap as STI takeoffs but the MachV's have lower spring rates and thus will work just a tad better with your stock struts.
CGM6 is offline   Reply With Quote
Old 11-18-2009, 11:18 PM   #4
jacobbaz
Member#: 218474
05 Impreza WRX
I looked into em and they seem pretty good for only $199, so thanks!
Old 11-19-2009, 09:15 AM   #5
CGM6
Member#: 146911
not a problem, good luck!
Old 11-19-2009, 04:30 PM   #6
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
STI take off springs or the STI Pink springs on stock WRX struts is not a great match, but works ok. The struts will wear out earlier and you'll feel the underdampening on expansion joints, etc. when on the highway (will be like a WTF is this). While not ideal it does work uh kay at best.
Tahoe SC is offline   Reply With Quote
Old 11-19-2009, 06:29 PM   #7
subwrx08
Member#: 224575
2008 WRX
blue
this will work, but eventually your struts will probably go... but either way you can get the springs first, use ur current struts for as long as possible then get new struts.
subwrx08 is offline   Reply With Quote
Old 11-19-2009, 07:54 PM   #8
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Can you explain why? Is STI pinks too stiff or too low for the wrx struts?
Thanks!
Ferraz is offline   Reply With Quote
Old 11-20-2009, 12:46 AM   #9
Web Foot STi
Member#: 39086
2004 STi
Stiff.
Web Foot STi is offline   Reply With Quote
Old 11-20-2009, 07:22 PM   #10
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
Pink spring and Koni Struts there is no comparision i road in a car with this set up and its amazing i have the pink springs and im waiting to get the koni struts before i install the springs
BigSky on clubwrx.net says this is the best set up
emsbuff124 is offline   Reply With Quote
Old 11-20-2009, 09:40 PM   #11
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
I have Konis inside my stock struts... I think it is called inserts (not sure if that is how you call it) and pink springs are in my list. But now I'm not sure...
Old 11-20-2009, 10:22 PM   #12
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
Get the pink springs trust me you will thank me thats exactly what my set up is going to be the koni inserts and then the pink springs and sway bars the pinks and konis are awesome its like driving on coil overs you should also look into the knob extenders so you dont have to take your back seat out to adjust the struts
Old 11-20-2009, 10:32 PM   #13
Web Foot STi
Member#: 39086
2004 STi
JDM pink springs and Koni inserts are wonderful. It's just stock WRX struts are a little soft for those springs
Old 11-21-2009, 10:08 AM   #14
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
I was looking into that, but I think I'm not very bright as counld not find it (I'm search challenged ,I think)
I was holping the Knonis could help to prevent the strut problems, but it looks like there is no way out...
Old 11-21-2009, 10:51 AM   #15
Web Foot STi
Member#: 39086
2004 STi
It's the guts, inserts, that you have to think about...
You will be fine with the upgrade.
Unless you are a troll
Old 11-21-2009, 11:53 AM   #16
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
^^ OK, I'm not getting it right! Can you explain what is struts and what's inserts?
Not easy when the forum it is not in your language!
PS. Ignor that! It took me some time but I got it now... You can call me slow. LOL! But thanks for the info!
Old 11-21-2009, 01:44 PM   #17
dc_adio28
Member#: 185057
Chapter/Region: HIIC
2008 Legacy GT
NBP
Anyone run this pinks/konis application with the wagon? If so then I might have found my next mod.
dc_adio28 is offline   Reply With Quote
Old 11-21-2009, 02:21 PM   #18
Web Foot STi
Member#: 39086
2004 STi
Yes, BigSky. Just make sure you use wagon struts.
Old 11-21-2009, 03:04 PM   #19
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
Go to Maperformance.com and look up your year they have them on the suspension section
Old 11-21-2009, 07:21 PM   #20
goat630
Member#: 214779
2004 wrx
Mr. San Remo
KYB struts
goat630 is offline   Reply With Quote
sold 12sechatch NWIC Private Classifieds 21 06-08-2010 10:57 AM
05 STi .....what springs on stock struts gslben Brakes, Steering & Suspension 22 04-25-2006 11:58 AM
STi V8 Pink Springs on V7 struts on WRX 02/03 Arnie Brakes, Steering & Suspension 23 01-28-2004 10:02 PM
STI pink springs on STI red struts? Fugu Brakes, Steering & Suspension 5 09-05-2002 09:05 PM
Poll: Eibach Prokit, Tein H-tech, Prodrive, or STI pink springs with stock struts? Tronner Brakes, Steering & Suspension 1 05-30-2002 12:36 AM
