Old 11-20-2009, 01:38 PM   #26
hammyt
Member#: 92585
2005 Saab 9-2x Aero
13.6@100 EJ205 VF48 93Oct
Great times, but I really don't think LC will help you that much. Just keep working on the launch. I've seen LC make 60' times worse for good drivers.
hammyt is offline   Reply With Quote
Old 11-20-2009, 11:43 PM   #27
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Originally Posted by Phatron View Post
the bright side is ur already setup for ts when atp releases the stock location ts gt30 and 35
well.....tell me another turbo company developing a stock location twin scroll turbo and i'll get a chubby for them.
Yeah, lookin forward to ATP's twinscroll stuff, as well as Litchfield's, but the bright side? I don't think I have properly conveyed how much I like the current setup, its awesome. The off boost power and twinscroll spool make it so much fun to drive. I can't wait to couple that with the short ratios of a 6MT. In fact, once its got a 6MT and is tuned on meth again to have race gas type power everyday, I don't think I'll need to upgrade turbos.
Originally Posted by shadowmd View Post
nice setup. that's what i want when i do my swap.
Thanks, it is super fun. I debated going built, but factory reliability combined with good performance potential won out.
Originally Posted by Hyper View Post
I love scoobysport, as a previous owner, but it sounds terrible on twin scroll
great times though!
Thanks, I love the ScoobySport too. I don't think it sounds bad with the twinscroll and don't really want to get rid of it, but need to upgrade to a 3" and something cheaper will probably sound almost the same.
Originally Posted by Scoobie Steve View Post
Rocking the left lane at Island, that video looks so much like mine its crazy. Run looks good, a better launch and 11.9 is yours. Did you flat shift 3rd?
As soon as I saw the vid after I uploaded it, I thought of your video and went to check it out again. I did flat shift the 3-4 and if I would have got another pass, I would have flat shifted the 2-3 too.
Originally Posted by juanmedina View Post
I agree, but I blame my horrible 60's on my inexperience at the track, my heavy 18X9.5 wheels with crappy Korean tires, and setting my suspension as stiff as possible; not allowing any weight transfer.
With that horrible setup my best 60' was 1.75, I changed the suspension setting for the shootout and I launched a couple of times on the streets and it felt awesome I think a high 1.6' is possible with the suspension adjustment. I have forge front LSD that should get me out the hole quicker.
I was just comparing your 60's to your old 60's
GL
Dude, just a joke. I was looking through the ALL VF thread and when I saw your timeslip, I thought I'd bust your balls a bit.
Thanks, I don't know since I have never tried it, but I can't imagine some boost at the line not helping.
OppositeLock is offline   Reply With Quote
Old 11-21-2009, 12:49 AM   #28
jason miller
Member#: 158313
2003 WRX
Dave from Defiant posted a thread about launching one time without using launch control, and it helped me pull 1.7 60's the first time I tried it.(and my 3rd time ever at the track) I'm not saying you need the help, because you obviously have a lot of experience at the track, but I'll post it anyway to see what you think.
Basically, Dave's method was to rev the motor a bit and get some heat in the exhaust, then start swinging the rpm's up through the range with throttle blips, and on one of swings you just quickly let out on the clutch as you hammer the throttle. I was terrified of trying this, but it seemed to work. There was no burnt clutch smell when done right, and very little when releasing the clutch a tad slow. It also didn't seem to be very shock inducing. I did try take the slack out of the driveline right before I did it though, hoping that would help minimize stress. There was a bit of tire spin too, which I'm thinking might actually be a good thing. Anyway, the rpm jumping helped make just a couple pounds of boost, and I dropped my 60's from 1.9's to 1.7's. Just a thought...
jason miller is offline   Reply With Quote
Old 11-21-2009, 03:50 AM   #29
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i go full throttle and let off the clutch as the rpm is heading towards redline around 5k. this builds more than a few pounds of boost
scoobystas is offline   Reply With Quote
Old 11-21-2009, 10:41 AM   #30
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
All cars have LC, its called the rev limiter. If you arent leaving off the limiter you are not launching as hard as you could. If the car wheel hops you may have to lower tire pressures. Island on Friday nights has very little track prep. I ran my best 60 foot times on Sundays.
Scoobie Steve is offline   Reply With Quote
Old 11-21-2009, 11:00 AM   #31
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Sounds like your lucky you haven't bent a rod yet
2002WRXSTi is offline   Reply With Quote
Old 11-21-2009, 05:45 PM   #32
OppositeLock
Member#: 54060
Thanks guys, its cool to hear what other people have tried with success. If you watch the video, I use sort of a combo of these two. I bounce it (too long in the video, the other guy seriously slow staged) and as the tree comes down I try to time flooring it with letting the clutch out quickly (slipped too much on this run). I probably have at least a hundred slips in the 1.7's and this is the method I have always used for FI/AWD.
Now this is awesome! Crazy, but awesome, I wish I had the balls.
Old 11-21-2009, 06:09 PM   #33
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i'm curious as to how you bend a rod launching hard?
de-tooth 1st gear? sure.
snap an axle? not likely but it does happen.
bend a rod? hmm. not followin' ya.
ride5000 is online now   Reply With Quote
Old 11-21-2009, 06:37 PM   #34
2002WRXSTi
Member#: 58647
02 Exedy Carbon
When I first started racing my V7 swap I would launch in the 55 to 6k range and pulled some 1.69 60' but doing that I snapped a rear axle and hub at the same time
While practicing my launches one guy came up to me and was telling me how he was launching off the limiter and claimed he bent a rod doing it. I say go ahead and try doing it with a EJ205 and see how long your engine lasts
He might be getting away with it cause they are V7 rods but I mistakenly launched off my 8500k redline and was a bit freaked when it happened
Old 11-22-2009, 02:57 PM   #35
ej_trbo_si_eater
Member#: 148009
i have the v7 an i would not go anywhere if i lunched from 8200.. i feel like im launching about as hard as possible while still going forward around 4000 when full boost hits or 5200 when avcs is at full advance. bounc ing off the revlimiter is definately not somethin i would recommend doing at the track unless you have anti lag and some sort of two step program to control the launch.. or money to fix your floated valves, bent rods and or warped heads.. just a thought
ej_trbo_si_eater is offline   Reply With Quote
Old 11-22-2009, 09:32 PM   #36
kade.mads
Member#: 156454
2005 Saabaru
hey man... Met you at iland a couple weeks ago.. i had the black saabaru... after seeing ur car looks liek im goign to have to 207 swap this winter... haha
kade.mads is offline   Reply With Quote
Old 11-22-2009, 09:36 PM   #37
ryanviola
Member#: 148445
06 wrx
FP Green 450whps at 22lbs
good ****!
ryanviola is offline   Reply With Quote
Old 11-23-2009, 12:22 AM   #38
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I love how the 2.0L cars seem to be getting more popular. It's awesome.
CKxx is offline   Reply With Quote
Old 11-23-2009, 11:46 AM   #39
OppositeLock
Member#: 54060
Thanks man, it was good to meet you guys, the Saab looked great. Good thing to plan ahead, that way you can sell your 205 and recoup some cash instead of running around trying to get everything done after its blown up. You definitley won't be disappointed. Maybe I'll see you guys out there again in the Spring.
Originally Posted by ryanviola View Post
good ****!
Thanks!
I'll admit, I was skeptical and wanted to go with bigger displacement, but the early boost (twinscroll+AVCS) combined with the extra revs is just such a blast to drive!
Old 11-23-2009, 11:54 AM   #40
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
so you don't really have an answer to my question.
thanks anyway.
Old 11-23-2009, 12:02 PM   #41
Dom Terreto
Member#: 180034
Great job Dave! I'm sure you'll have driving the new setup down in no time and you'll go back to winning shootouts like it's a second job!
Evan @ Akuma
Dom Terreto is offline   Reply With Quote
Old 11-23-2009, 12:47 PM   #42
RE4PER
Member#: 142753
2005 STI
Nice job
RE4PER is offline   Reply With Quote
Old 11-23-2009, 01:13 PM   #43
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
STOP SETTING RECORDS!!!
Great job by the way!!!
rek888v2 is offline   Reply With Quote
Old 11-23-2009, 02:20 PM   #44
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
nice (:
good work
fearmywrx is offline   Reply With Quote
Old 11-25-2009, 12:27 PM   #45
OppositeLock
Member#: 54060
Evan @ Akuma
Thanks Evan, it may have something to do with that Archuleta pixie dust you sprinkled on it!
Originally Posted by RE4PER View Post
Nice job
Thanks!
Thanks! No records this time, but I'll definitely be cranking it up in the Spring and looking to put it as far into the 11's as possible.
Originally Posted by fearmywrx View Post
nice (:
good work
Thanks!
Old 11-25-2009, 12:37 PM   #46
OppositeLock
Member#: 54060
Also, a note to everyone with a FORGE BPV. I was beginning to get progressively worse compressor surge (seems to be a common problem with this setup) that I thought might be weather or BPV related. I decided to swap to the stock V8 BPV and see if it made a difference and it cleared it right up. It was weird because I checked the FORGE to make sure the spring didn't feel too heavy and that the plunger was still moving and it was, but when I rechecked it after the V8 solved the problem, I realized that it was not moving up far enough in the stroke. I pulled it apart to find that the grease inside was essentially gone and the spring was sticking before it could fully vent. So check and regrease your BPV's people.
Old 11-25-2009, 01:57 PM   #47
2002WRXSTi
Member#: 58647
02 Exedy Carbon
Still using the stock V7 one on my car.
Old 12-02-2009, 01:02 AM   #48
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Dave,
Im glad you are enjoying the car. Let me know when you want to stop down by the shop so we can take our time and get the most out of it. Especially since it wont be 100+ degrees!!
Junior
Junior2JZ is offline   Reply With Quote
