Old 05-16-2002, 05:40 PM   #1
dub976
Member#: 11301
2002 impreza WRX
midnight black pearl
Default fuel cut defender/ is it worht it?
what good would a fuel cut defender do on a WRX with an CAI & dual stage boost control. I'm to broke to afford a unichip or some kind of engine managment right onw.
dub976 is offline   Reply With Quote
Old 05-16-2002, 06:51 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
A fuel cut defender/defencer/defenser (FCD) will allow you to run much higher boost. The question of "what good" it (an FCD) does is open to discussion. I'm sure that many variables (beyond performance) were considered at FHI before settling on its current WRX ECU boost limits, not the least of which is the California Emissions Warranty which requires that Subaru repace any turbo or precat that fails within the first 7 yrs/70K miles.
Jon [in CT] is offline   Reply With Quote
Old 05-16-2002, 08:07 PM   #3
Z1 Performance
Member#: 9327
If you are at the point where you need a fuel cut defencer, you are running far too much booost. Your next nmod, in case you don't have it, is an exhaust
Z1 Performance is offline   Reply With Quote
HKS fuel cut defender?? are you using it? trboCIVIC&WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-07-2003 08:09 PM
looking for hds fuel cut defender wiring diagram boogerwrx Southern California Impreza Club Forum -- SCIC 2 07-14-2002 12:43 AM
looking for hks fuel cut defender wiring diagram boogerwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-13-2002 11:16 PM
Fuel cut defender BleuWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-31-2001 12:42 AM
fuel cut defender? fastline Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-11-2001 07:52 PM
