#1 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
My ACT HD clutch started recently slipping on 4th and 5th gear it only lasted like 13k miles with 2 track days
. My stock clutch last me 35k miles with 1 track day...Anyways, can I hurt or damage anything by driving with a slipping clutch? I lowered the boost and I am trying to stay off boost. The last time I drove the car until the clutch was gone, I had to replace my flywheel because it was cracked .I am going with a 6-puck unsprung this time
#2 |
Member#: 141720
South East
Vehicle:2005 LGT 5MT Sedan Satin White |
more slipping means more heat... more chance of warping, etc.
if it is any consolation, I had my clutch slipping for around 10k miles and finally got it replaced... no worse for wear, just machined flat and allwas good.... Maybe you are just too hard on it? T |
#3 |
Member#: 216135
Vehicle:2011 Civic SI STX #66, 06 S2000 STR 180 |
If you are replacing the FW, disc, and PP, then drive it until it is undriveable I say.
As torinalth said, however, the extra heat might put a hurting on your FW/PP so they may need machining. |
#4 | ||
Member#: 133146
![]() Quote:
#5 |
Member#: 133146
UPDATE
I really don't know if my clutch is really slipping . Sometimes it kinds of slips and sometimes it doesn't. My road dynos of 3rd gear pulls show no slippage at all, but sometimes when I do 5th gear pulls it seems that it slips from 3000 rpm to 3500 rpm and then it catches... but I am not certain.How can I find out for sure? should I data log my car doing a 5th year pull from 2000rpm to something? What will the slippage look like? Any other ideas? I really don't want to spend my money if the clutch is fine. Thanks |
#6 |
Member#: 52314
South East
Vehicle:2002 PSM WRX 16G-XT '13 500 Abarth |
My car did something similar when one of the rear axles came unsnapped from the circlip that holds it in the splines of the diff. If you're not sure its the clutch, check your rear axles.
#7 |
Member#: 166656
NESIC
Vehicle:2002 WRX Wagon Silver |
From the sounds of it, you're clutch is JUST starting to slip. It'll get worse over time. Your clutch is more likely to slip in 5th than in any other gear, and I'm guessing from 3000-3500 rpm you're making peak torque, so there's your explanation. I've been experiencing something similar in my bugeye... holds most of the time, but if i gun it and hit my peak torque range in higher gears, it'll start to slip a little. Especially when cold/wet.
Also, I hate to say it, but if you killed 2 clutches in <50k miles, you might want to work on your driving style... |
#8 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
its slipping..
#9 |
Member#: 133146
Juan haz 6-puck sprung
.I was going to install a 6-puck unsprung but after almost everyone told me that it will suck for a daily driver, I sent the unsprung disk back and got a sprung disk. The disk clutch that I replace (the HD street clutch) had a ton of meat left on it, so I guess I was just overpowering the clutch. I have driven the car with new clutch of about 2 days and it seems fine for a daily driver. I don't see what is the big deal, you just have to slip the clutch to get going.... I will update this thread in a few weeks |
#10 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
What did the pressure plate and flywheel look like?
I just installed a 6 puck unsprung. LIKE BUTTER..... I wonder if its because of the cable versus hydraulic? |
#11 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
I tell you... i'll be gettin an UNSPRUNG 4puck. But I have my reasons.
-lighter disc with 4pucks and no hub mech stuff with the springs means FASTER gear changes. -4puck for better grip The Outback tranny on the '03 WRX runs an unspring 6puck. I have no issues driving it. I don't slip at 3k rpms to get up and go. I slip at idle to 1500rpms. Get it moving and it'll go. Most people complain, but they forgot why they bought it in the first place. |
#12 | |
Member#: 133146
I search for info on the 4-puck in here and there is none, I found a video on streetfire about clutches and they said that 4-pucks drives better than a 6-puck |
#13 |
Member#: 133146
#14 |
Member#: 3687
I prefer drivin with pucks now because of the performance capabilities they give. Don't be afraid..... I'm not. 4puck unsprung for me!
#15 |
Member#: 229023
BAIC
Vehicle:06 STi obp |
im right at the cross road of needing a clutch.at 80k on the oem its still holding but a e85 tune will def kill it
i was going to get the act HD street but was also looking at the 4 and 6 puck clutches.theres just not alot of feedback on them.i want something that will last,hold and be fun to drive |
#16 | |
Member#: 103232
Vehicle:MY05 GDA, MY04 FXTI 2.5ltr,PPG,Front LSD,4.44 |
Im assuming you are ok since you saw it before the install. It also sounds like it slipped mostly in mid rpm ranges when hitting the powerband. Not drag racing, dumping the clutch etc. So the heat that might have been made is less then it could have been. |
#17 | ||
Member#: 133146
In your case the ACT STi street clutch has a higher torque capacity rating than the WRX clutch, IMO u should be ok with it, if you are only running a VF39 on E85 Quote:
#18 |
Member#: 229023
BAIC
vf39,no
blouch td06-20g |
| Thread Tools | |
| Display Modes | |
| HELP is my clutch slipping? | CHwrx | Transmission (AT/MT) & Driveline | 30 | 10-16-2006 07:28 PM |
| Look at these logs...is my clutch slipping? | quickscooby | Proven Power Bragging | 11 | 03-06-2006 01:37 PM |
| is my clutch slipping | gsteclipse33 | Transmission (AT/MT) & Driveline | 5 | 04-30-2005 12:43 AM |
| is my clutch slipping? | aznfoos | Transmission (AT/MT) & Driveline | 1 | 11-03-2004 11:12 PM |
| is my clutch slipping or......? | NA Impreza | Normally Aspirated Powertrain | 6 | 04-30-2001 12:53 AM |
