#1 |
Member#: 197221
Vehicle:2008 WRX VF48 EFI Logics Tuned!!! |
Hey guys i've been lookin at buying some seatbelts for my 08 wrx hatch but I have a few questions.
1. I have stock seats. Which seatbelts should i get 3, 4 or 5 point? (for autocross) 2. Also does brand matter? any preferred brands? 3. How do I install them? I don't have a roll cage and it's my daily driver so i need the back-seats is this still possible? thanks guys p.s. I'm lookin to get seats but right now my budget doesn't allow just an fyi
#2 |
Member#: 52007
NESIC
Vehicle:2004 STI WRB |
I love my Scroth quick fit 4 point harness! It utilizes the rear seat belt mount points as well as the front ones and can be taken out when you need to use the rear seats and you can just use the stock belt. It's great for autocross and very simple to install/ remove.
#3 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
Scroth Rallye 4 is the best choice if you still need back seats. The 3 isn't bad, but the 4 gives more lateral support. The front and back parts quick disconnect to let you use the back seat without needing to remove a harness bar.
#4 | |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
Because I'm too lazy to retype this:
This all being said, there may be some harnesses that are better than others if you have to use them on the street, but I have not looked into that. I work as a vehicle safety systems engineer for a living. I'm not going to lie however in order to make a point; I do not work in seatbelts so my knowledge on the subject is rather limited. That being said, I've seen a lot of crash data and I've seen a lot of crash results. I know better than most what the body does in the event of a collision. EDIT: Also, if you have your mad tyte harnesses and you like them, fine. I don't need to be flamed or told I'm wrong like every time I share info on racing belts for street use. People do silly, dangerous things on here every day and it doesn't effect me in the least. However, don't tell everyone there's nothing wrong with racing belts of the street simply because you've never died or you got in a crash and walked away. Last edited by kpluiten; 11-19-2009 at 10:56 AM. |
#5 |
Member#: 156861
Vehicle:2002 Wagon mbp, evo3/e85 |
We had crash analysis from BMW and the Army come in and talk to us about safety equipement with motor vehicles. They said that they had looked into 3-4 point systems but always found that the stress placed on the neck was too great. Also, in a side impact, the aorta has a nasty tendency to detach with a sudden change in speed. Having less "give" only worsens this....
All that said...was the OP even suggesting that he was going to use it on the street. Sounds like an AutoX only thing. |
#6 | |
Member#: 52007
NESIC
Yes However the Scroth DOT aprooved belts are designed to give 3in in the case of an accident. Never ever use a track harness on a street car unless you feel like wearing a helmet and a HANS device everywhere you go
#7 |
Member#: 197221
yea i wasn't planning on street use but now that you mentioned all that it certainly solidifies my thoughts about it. I would only be using it for auto x.
#8 |
Member#: 120273
SWIC
Good call!
#9 |
Member#: 189606
SCIC
Vehicle:E46 M3 Ti Silver |
I kept my stock seat belts on for the street and had my 4 points installed but just pushed aside till I needed them.
#10 |
Member#: 52007
NESIC
Very good call! Not only can they be dangerous depending on what harness you get, but they also get quite uncomfortable and you can't really turn around to look when your backing up with them on. They do make a HUGE difference for autocross though!
#11 |
Member#: 120273
SWIC
| Thread Tools | |
| Display Modes | |
| WTB: JDM STi Version 3/4 or 5/6 Seats! | jdmgary | Private 'Wanted' Classifieds | 11 | 04-04-2007 12:56 PM |
| 4 or 5 Point Harness question | ConeMasher | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 07-03-2002 09:23 AM |
| Anyone install a 4 or 5 point harness??? | veloLexus | Bay Area Impreza Club Forum -- BAIC | 4 | 11-11-2001 10:48 PM |
| 4 or 5 point harnesses for non caged WRX??? | FreeBMW | Factory 2.0L Turbo Powertrain | 1 | 10-15-2001 12:07 AM |
| Need to borrow/look at someones 4 or 5 point seat harness | Ryan24 | North West Impreza Club Forum -- NWIC | 14 | 08-28-2001 10:57 PM |
