Old 11-19-2009, 12:43 PM   #1
Trogasarus
Member#: 187624
'99 Impreza Wagon
Default No Crank no start mmkay?
I have a 99 impreza wAgon and just recently I replaced my clutch battery and starter. It ran good for about 2-3 weeks and just kinda died a few days ago. The car clicks once (so the starter is engaging ) but it won't crank over. The dash lights also dim out but I'm guessing thAt's because th starter is trying to engage. It's not a bad fuse ,grounds or bad connections to the starter I've just got done testing that, so what else can it be? are there any other sensors that i can Chek for open or short to grounds??
Trogasarus is offline   Reply With Quote
Old 11-19-2009, 12:54 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You may need to replace the starter solenoid contacts. They wear out and cause this kind of trouble. Make sure your battery has a good charge on it as a low battery or bad battery connections will cause this kind of trouble also.
Old 11-19-2009, 01:17 PM   #3
Trogasarus
Member#: 187624
'99 Impreza Wagon
The starter is remanufactured. Is there a test I could do quick to check it? The batt reads 12.40v so I know there's no parisitic drain.
Old 11-19-2009, 11:45 PM   #4
Cougar4
Member#: 53443
Winestone
To see if the wiring to the starter is ok check the voltage at the main terminal on the starter motor. Make sure it is getting at least 10 volts while in the start position. If that is ok then something is wrong inside the starter.
can anyone help with this problem?? No crank, No fire. Not all dash lights ncarn8 Electrical & Lighting 4 11-12-2009 06:21 PM
Crank/no start - no spark - ideas? PeteDucati Built Motor Discussion 12 04-29-2007 04:29 PM
Crank.. no start.. severe flooding??? PeteDucati Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-10-2006 11:43 PM
Stock STi: crank, no start, flashing CEL. cnstman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-28-2004 11:18 PM
XT6 (92), Does anyone have a illustration of the timing belt(s) Crank No Start. munkis Normally Aspirated Powertrain 0 10-20-2002 11:25 PM
