Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-19-2009, 04:49 PM   #1
TopSpeed
Vendor Sales Rating: (5)
Member#: 78884
Go faster
at TopSpeed
Default TopSpeed Inc. Holiday Sale!! Cobb :: DW :: AMS
TopSpeed is setting you up for the Holidays.
We have all your performance needs from a huge parts inventory, world class service, and professional custom dyno tuning!
Please feel free to email me or call with any questions, or pricing on parts you don’t see.
:: There isn’t anything we can’t get or any price we can’t beat! ::
AMS V-Band STi Turbo Kits
-Available For 2004-2007:
GT3076R
GT3582R
GT3586
-For 2008-2009 STi Application:
750r Kit
850r Kit
:: CALL OR PM FOR PRICE ::
The AMS 2002-2007 Subaru WRX/STI Rotated Mount V-band Turbo Kit is the new benchmark in Subaru performance. Designed to meet the demanding needs of road race, drag race and street cars alike, we have successfully achieved unparalleled drivability, response, and horsepower. Our unique design has been tested and refined for over 1 year to provide reliability, OEM like fitment and options never available in a Subaru turbo kit before.
The AMS kit brings some new ideas to the table…
  • V-band housings
  • Top Mount & Front Mount Intercooler Applications
  • Intake Pipe Solutions
  • Factory ECU & MAF Solution
  • Cast Stainless Steel V-band Up-pipe
Features
  • 2” ID rotated V-band cast stainless steel up-pipe for optimum flow and durability
  • 5/8” thick flange on up-pipe to ensure a proper seal
  • Turbo support bracket maintains turbo kit reliability under any condition
  • 304 stainless steel TIG welded construction
  • Lifetime Limited Warranty on the up-pipe*
  • True Garrett Dual Ball Bearing GT series turbo with ported shroud compressor covers to prevent compressor surge
  • TiAL Stainless Steel V-band exhaust housing with choice of .63, .82 & 1.06 a/r ratios
  • Your choice of a genuine Tial 44mm or 38mm V-band wastegate to ensure proper boost control
  • Wastegate feed strategically placed on the Up-pipe for precise boost control
  • 10” stainless steel external wastegate dump tube
  • No gaskets needed for the turbo to up-pipe, up-pipe to wastegate or turbo to downpipe
  • Your choice of true 3” cold air intake pipes to suit a pull through or 3” blow through mass air flow sensor intake pipe
  • Bolts up to any stock or aftermarket header that fits the factory up-pipe
  • Downpipe fits AMS & most other aftermarket cat-back exhausts
  • Your choice of turbo outlet pipes for top mount or front mount intercooler application.
  • Kit Utilizes 4 ply silicone tested up to 50 psi of boost!
  • Industry first 4 ply silicone Blow off valve recirculation tube for cars looking to maintain the factory ECU and MAF (optional)
  • New coolant lines for your coolant expansion tank for a clean engine bay
  • DEI heat insulation to protect OEM wiring from excessive heat
  • Kit includes ALL necessary fittings and hardware for installation
  • Class 10.9 fasteners & 4 ply silicon couplers. We use the best hardware and silicone so that it goes together right the first time
Kit Includes
  • Cast stainless steel Up-pipe
  • AMS spec TiAL GT series dual ball bearing turbo with ported compressor cover and Tial V-band turbine housing
  • Genuine Tial 44mm or 38mm V-band wastegate
  • Integrated turbo support bracket
  • AMS high off-road test-pipe (high-flow steel core catalytic converter optional)
  • DEI Heat insulation for your electrical wiring
  • New lines for your coolant expansion tank
  • Stainless steel 3” downpipe with integrated Stainless steel flex section
  • Stainless steel oil feed line (fittings for both WRX and STI included)
  • Custom AMS stainless steel oil return line
  • 4 ply silicon water lines with thermal insulation
  • 4 ply silicone 2.5”” turbo outlet pipe, intercooler and intake couplers
  • Top quality hardware package including nuts, bolts, fittings and clamps
  • Polished aluminum 3” cold air intake pipe with K&N air filter for blow through MAF (pull trough MAF optional)
  • Detailed installation guide
Options
  • Your choice of top mount or front mount 4 ply silicone turbo outlet pipe (no additional charge)
  • Your choice of .63, .82 or 1.06 a/r exhaust housings (no additional charge)
  • Blow off valve recirculation
  • 3” Pull through MAF intake pipe (optional) or 3” Blow through MAF intake pipe (standard)
  • High-flow catalytic converter
  • Tial 44mm (optional) or 38mm V-band (standard) wastegate
Cobb Accessport Ver2
2004-2009 STi
(Free half hour tuning with all AP purchases *$75 value)
POWER. FLEXIBILITY. CONTROL. The AccessPORT is the industry leading OEM ECU flashing, managing and monitoring assistant. Unlock power hidden within the ECU by replacing conservative factory settings with more aggressive calibrations. The result is impressive gains in torque and horsepower while maintaining a high degree of safety. The AccessPORT comes with pre-installed maps that are optimized for common performance modifications.
Tuning flexibility ranges from simply loading one of the included performance maps designed for common modifications, all the way to complete custom map authoring using our powerful AccessTUNER software. Extract maximum power from virtually any modification while retaining the driveability and sophistication inherent in the OEM ECU.
Deatschwerk Injectors
These are the same injectors demanded by many of the most discriminating Subaru tuners including Cobb. Prices are for a flow balanced set of 4 injectorsEach set is individually tested and flow balanced in-house to within a 1-2% variance. The results are included in your custom flow report that accompanies every set of DW injectors. Our flow report also includes additional set-specific data useful for tuning. WRX/STi injectors also feature... 100% drop-in fitmentHigh Impedance coils to match OEM ECUoptimized atomization and spray patternso-rings Excellent spray pattern and atomization for excellent idle and tuning
04-06 SF 740cc
04-06 SF 850cc
:: CALL OR FOR PRICE ::
02wrx/07STi TF 750cc
02wrx/07STi TF 850cc
02wrx/07STi TF 1000cc
:: I will be updating this thread with new products, check back to see whats new ::
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-23-2009, 11:27 AM   #2
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Monday Bump!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 12-02-2009, 10:15 AM   #3
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump for specials, if you don't see it and you need it PM me!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 12-17-2009, 10:03 AM   #4
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump for some last minute Christmas gifts
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 12-22-2009, 09:37 AM   #5
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump for FREE OVERNIGHT SHIPPING!!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Closed Thread
TopSpeed Inc. Holiday Sale!! KW :: RCE :: BC TopSpeed Suspension/Brakes/Handling 4 12-22-2009 09:38 AM
Job opening: TopSpeed Inc. Badazzcr South East Region Forum 4 04-03-2008 11:01 PM
