Old 11-20-2009, 04:12 AM   #1
redzfit
Member#: 191518
2007 STI
Default Dyno: 2.5 Stock Turbo Makes 320 WHP
Event: Dyno Pull
Ambient Temp: 75 degrees Fahrenheit
Elevation: 15-45 Feet Above Sea Level
Weather: Sunny
Tires: Dunlop Sp 225/45/17
Car: 2009 WRX
Tuner: Jon @ HB Speed
Dyno Info: Dynomite
Peak HP at RPM: 320 @ 5k SAE Correction
Peak Torque at RPM: 335 @ 4.5K SAE Correction
Baseline hp/tq for a stock on same dyno: ???
Target Boost: 20 PSI
Target AFR: ???
Fuel: Pump 91 Octane
Engine/Power Modifications:
Cobb AP
Stock VF 52 Turbo
Header (PnP by wrxsubiemod)
Walboro Fuel Pump
Prodrive 3 Port BCS
AEM Intake
Perrin FMIC
Perrin TBE
Perrin Up Pipe
Perrin Turbo Inlet Hose
Other Modifications: Kartboy SS w/ Bushings
redzfit is offline   Reply With Quote
Old 11-20-2009, 05:14 AM   #2
redzfit
Member#: 191518
2007 STI
here is my old dyno to compare.....
http://forums.nasioc.com/forums/show....php?t=1681620
Old 11-20-2009, 12:58 PM   #3
swiftwrx1
Member#: 72352
06 E85 v-mount
wht/bronzse WFC#555
looks nice
swiftwrx1 is offline   Reply With Quote
Old 11-20-2009, 02:12 PM   #4
redzfit
Member#: 191518
2007 STI
^^^ Thanks. I just drove it to Big Bear and Back this morning and we went through the mountain so it was a fun drive.
Old 11-20-2009, 02:56 PM   #5
PERRIN_Chris
Member#: 186665
2014 BRZ
Nice! Must be super quick now!
PERRIN_Chris is offline   Reply With Quote
Old 11-20-2009, 03:05 PM   #6
mcganz121
Member#: 138569
2010 A4 Quattro <-
06STI <- 09WRX <- 06WRX
WOAH. Redfitz, im copying your setup.... stock injectors? they arnt maxed??
mcganz121 is offline   Reply With Quote
Old 11-21-2009, 01:24 AM   #7
redzfit
Member#: 191518
2007 STI
Ya tahnks to you and Adam and all of our PM/Emails back and forth haha
Yes my injectors are stock. I dont know what the ICD's are I can call and find out. Whats nice if you compare graphs I have hp and tq gains of 30+ Under the hood is nice because I have that limited fmic with the red tubes and black core which goes well with the wrinkle red AEM intake and red perrin inlet hose...
I wish there was launch control for the AP so I can get some good 0-60 times.
Matt at HB Speed said pretty much anything from 330+ WHP is close to blowing the motor status so for now I plan on keeping the car as is for awhile.
Old 11-21-2009, 01:26 AM   #8
redzfit
Member#: 191518
2007 STI
here is a crappy cell phone pic of my engine bay
Old 11-21-2009, 01:49 AM   #9
gtturborex
Member#: 90397
They told you 330 is close to blowing the motor? I made 504 on that dyno on my stock motor. No wonder why I'm having issues
gtturborex is offline   Reply With Quote
Old 11-21-2009, 09:17 AM   #10
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Thats very impressive, I didnt know 09 WRX could do so well with its stock turbo.
wrxsubiemod is offline   Reply With Quote
Old 11-21-2009, 09:26 AM   #11
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
nice numbers on that stock turbo congrats
DarkKnightBaku is offline   Reply With Quote
Old 11-21-2009, 02:11 PM   #12
redzfit
Member#: 191518
2007 STI
What kind of car do you have? A STI motor can handle alot more power than a wrx can. I would assume anytime your making 500+ whp on stock internals you are gonna run into some problems.
Thanks! I am pretty sure it is close to its peak...
Thanks. With all my mods I those where the numbers I wanted to put down on his dyno so I am happy it did
Old 11-21-2009, 02:33 PM   #13
jexeffectz
Member#: 131976
2006 18g'd WRX
CGM on Black
Awesome numbers man. I bet this is HUGE step up from the fit.
jexeffectz is offline   Reply With Quote
Old 11-21-2009, 02:52 PM   #14
redzfit
Member#: 191518
2007 STI
+1,000,000 haha. I can not believe I wasted so much money into that car with i/h/e and volk's. It was a nice car and all but it was no Subie. To me it just seems like you get sooooo much more out of modding a turbo compared to a n/a car. You figure MAYBE 5 whp with exhaust on the fit compared to +30 whp with a turbo back on the Subie.
Old 11-21-2009, 03:16 PM   #15
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
How do you figure? only difference between the two motors is the dish in the pistons, same rods, same crank, different pistons and different heads. the pistons are the same strangth and the heads just have a different chamber. So basically the same engine but wrx's have a higher compression ratio so in turn can make a bit more power.
I'm running 420whp/430wtq on stock internals on an sti, no problems yet and its 50,000 miles strong.
Your tanny is getting close to failure at that power if you do not drive it properly.
noonagon is offline   Reply With Quote
Old 11-21-2009, 03:19 PM   #16
gtturborex
Member#: 90397
Yeah I have an 06 Sti with a 35r. I knew I would have problems and eventually need a new motor. I just wished I could of gotten a clean run down the track with this setup. Immediately after my tune I was running extremely rich. Jon told me I have a boost leak somewhere. I still havent been able to find it though.
Old 11-22-2009, 12:34 AM   #17
redzfit
Member#: 191518
2007 STI
Anytime your car is making over twice its original you are gonna run into some problems. I am a "nooby" so I do not know exactly why you would run into problems but I am sure someone more knowledgeable will chime in and answer your question. Personally if I ever went rotated setup I would look into upgrading pistons/rods and retainers + whatever else my tuner would suggest. I know of 2 3g WRX guys who have blown their motor with a stock location turbo but having low compression in a cylinder...
Old 11-22-2009, 02:40 AM   #18
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
Well stock location turbos can get very big. like a dom 4 or so, i have a td06-20g with a lot of meth. have a built block waiting on my 6262 turbo
Old 11-22-2009, 03:00 AM   #19
jexeffectz
Member#: 131976
2006 18g'd WRX
CGM on Black
Just curious...what made you go front mount?
Old 11-22-2009, 03:47 AM   #20
redzfit
Member#: 191518
2007 STI
*Well I got promoted at work so I was able to save up for the extra $$$. And I like the look.
**I have looked into a lot of different dyno sheets and it seemed like people with fmic were putting down more tq compared to similar mods. And I mean +30 wtq and I know different dyno read different etc....
***Something that helped me talk myself into spending that much on a fmic was I live in Socal so it is always hot and a fmic would cool my motor better and have less chance of heat soak. Just yesterday it was almost 80 degress...
****I eventually want to go to a bigger turbo and because I have an 08+ WRX the motor layout is a lot different and the stock location turbos are super limited. By going fmic I can run any stock location turbo the the previous gen WRX/STI can. So that was also something I took into consideration, so I spread the cost out. Because right now all I would need is larger injectors for a bigger turbo...
Old 11-22-2009, 03:51 AM   #21
redzfit
Member#: 191518
2007 STI
I want the DOM 2.5 XT-R but I think that might be too much power for my car. I just want a fun DD maybe when I have the extra $$$ I will upgrade my turbo so if I blow my motor ill have the extra $$$ to build it stronger
Old 11-22-2009, 04:05 AM   #22
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
Event: Dyno Pull
Weather: Sunny
Car: 2009 WRX
Dyno Info: Dynomite
Target AFR: ???
Cobb AP
Stock VF 52 Turbo
Walboro Fuel Pump
Prodrive 3 Port BCS
AEM Intake
Perrin FMIC
Perrin TBE
Perrin Up Pipe
did you run any logs yet? If you did i would like to see plz. Any idea how agressive the tune is?
ramair18954 is offline   Reply With Quote
Old 11-22-2009, 02:13 PM   #23
jexeffectz
Member#: 131976
2006 18g'd WRX
CGM on Black
I live in So Cal too. I guess I'm trying to convince myself to go FMIC. How long have you been FMIC and hows the cop attention?
Old 11-23-2009, 02:20 PM   #24
elscoobie20
Member#: 214606
2009 WRX
DGM AP Stage 2 + AEM CAI
I'm curious if you got equal or unequal length headers?
elscoobie20 is offline   Reply With Quote
Old 11-24-2009, 12:28 AM   #25
redzfit
Member#: 191518
2007 STI
I have only been running fmic for a week or so. Cop attention should be low because its the black core so you can really see unless you know what you are looking for. I have only been pulled over once and that was because I rolled a stop sign right in front of a cop. And my windows are tinted "dark" and I have been ok.....
Sorry I have not had a chance yet. I did have a chance to do some 0-60s on the AP and my clutch started slipping
They are the stock unequal length headers
2.5 non turbo compatible with 2.5 turbo Bradd06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-27-2009 04:42 PM
WTB: (Northern VA) - Stock Injectors 2.5 Liter Turbo Engine (ASAP) hutru01 MAIC Private Classifieds 3 02-09-2009 10:30 PM
95 jdm 2.5 non turbo to a usdm 2.5 non turbo wireharness c1poweredeg Subaru Conversions 2 11-04-2008 12:28 AM
Yes you too can make fun of my 2.0L stock turbo jmlaser Proven Power Bragging 48 05-03-2008 10:23 PM
stock 2.5/ minnam turbo/and NOS? ej25turbo Normally Aspirated with bolt-on Forced Induction Powertrain 19 05-19-2002 08:34 PM
