Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 11-21-2009, 12:19 AM   #1
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Default wheel offset difference, which way to go in this situation?
A bit of a theoretical situation. Assuming all other suspension settings remain the same. Assuming that tires are the same. Assuming there are no clearance issues with either. Tires are 225/45/17 RE01R's...
Wheel 1: 17x7.5, ET48
Wheel 2: 17x7.5 (same wheel), ET53.
The question for discussion: Which is better for the typical autocross course? Does the 10mm overall extra stance width benefit outweigh any (presumably negative) impact on scrub radius angles and turn-in?
Just thinking out loud here and interested in what everyone thinks.
irish44j is offline   Reply With Quote
Old 11-21-2009, 07:32 AM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
I have a feeling the difference would be totally unnoticeable.
sniper1rfa is offline   Reply With Quote
Old 11-21-2009, 07:43 AM   #3
KC
Member#: 442
16 SS
00 S2000
Nothing noticeable on either wheel. The 48mm gives you 10mm more track.
Down the road, if you want a wider tire, the 48mm may want the fenders rolled.
--kC
KC is online now   Reply With Quote
Old 11-21-2009, 10:22 AM   #4
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Eh, with wide 245 Dunlops and 17x8 +45s I barely need a roll in the rear only (it rubs a little on the highway when the car is loaded with autox gear). I would not worry about that.
Old 11-21-2009, 09:53 PM   #5
irish44j
Member#: 191290
09 OPB SM WRXsedan
i figured not, but it was just a random though, lol....
Old 11-22-2009, 11:55 AM   #6
STirish
Member#: 71515
'06 STi
I won't tell you what is better, but I can say a 10mm track change can be felt in back to back runs.
Rob
STirish is offline   Reply With Quote
a few more wheel bearing questions..which way to go. poetic--playa Newbies & FAQs 3 10-10-2008 08:48 PM
which way to go to houston? KevinHeist Texas Impreza Club Forum -- TXIC 35 04-26-2006 12:28 AM
Driving From Knoxville to Raleigh, which way to go? WagonMonster South East Region Forum 15 03-22-2004 12:45 PM
Another tuner Noob here trying to figure out which way to go & why Drew888 Engine Management & Tuning 8 02-04-2003 01:52 PM
Which weight oil to use in this situation? armand1 Service & Maintenance 12 02-07-2002 02:16 PM
