Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 11-21-2009, 10:44 AM   #1
Dave G
Member#: 4738
2006 Baja Turbo
Default tailgate won't close, unless I slam it three or four times
I did a search in Baja forum, and saw a couple old posts where people had similar problems, but nobody talked about the solution because their dealer fixed the problem.
My car is out of warranty, so I'd prefer to tackle the problem myself first. Otherwise I'm guessing the dealer will just spray some WD-40 and charge me $100++, not to mention that I'll have to pay for a rental car to get to work or I'd have to take the day off.
My tailgate doesn't want to close or lock in place etc until I slam it three or four times (or more), and its getting worse. I haven't done anything to it, nor abused it etc. I've probably only used the tailgate once a month (since late 2006 when I bought the car).
I do not have a bed cover or tonneau cover. The bed is always open. The car is usually garaged, but not always. But it sits outside at work during the day, and the car has about 56K miles on it, although this problem has been occurring since about 42K miles.
Does anybody have ideas about what to do, as a do-it-yourself project?
Will some moving parts just need lubrication? Or will I need to replace some parts?
Dave G is offline   Reply With Quote
Old 11-21-2009, 11:19 AM   #2
kidjoe
Member#: 120797
2004 Baja Turbo
My 04 baja did the same thing......the tailgate latches were sticking. Very much a do it yourselfer!
You will need to remove the plastic bedliner on the inside of the tailgate (uses torx screwdriver....don't know the size off hand). Under the plastic cover is a metal cover plate that runs the length of the tailgate (also torx), you will need to remove this as well. Once it is off you will be able to see both latches at either side of the tailgate. Chances are the springs on the latches are sticking due to corrosion or grime. You we need to work the springs free with some sort of penetrant (pb blaster, liquid wrench, wd40...etc). Once the latches are free and the tailgate closes lubricate the latches with something like white lithium grease (spray).
kidjoe is offline   Reply With Quote
Old 11-21-2009, 12:13 PM   #3
speedymatt
Member#: 54910
2003 BAJA Classic
Silver/Silver/& uh Silver
^ what he said!
speedymatt is offline   Reply With Quote
Old 11-21-2009, 02:27 PM   #4
sabber
Member#: 224705
2003 NA Baja sport
My tailgate latch sticks too. I just push the latch into the closed pasition by hand and close the gate.
sabber is offline   Reply With Quote
Old 11-21-2009, 08:23 PM   #5
Bajabeef
Member#: 151304
2003 Baja Sport
Yellow/Silver
My latch sticks as well, and i do the same, by putting it in the closed position then closing the gate
Bajabeef is offline   Reply With Quote
Old 11-21-2009, 11:40 PM   #6
shipjumper
Member#: 6307
what I has no car...
am carless
I have done it twice to my handle and again, if I dont physically return the handle to the "out" position, it will not close, so I have trained myself to do that...
shipjumper is offline   Reply With Quote
Old 11-24-2009, 04:22 PM   #7
seaview
Member#: 201074
2005 Baja
Me too.............Pete L.
seaview is offline   Reply With Quote
Old 12-13-2009, 09:54 PM   #8
Dave G
Member#: 4738
2006 Baja Turbo
Thanks for the info!
I did the fix a few weeks ago and it worked great.
I used white lithium grease, a Torx 25 screwdriver, a Phillips #3 screwdriver, and some rags, and I finished in about 15 minutes.
As some other posters mentioned, the biggest issue was the tailgate handle sticking. The white lithium grease fixed that too.
Now the tailgate works like new.
Old 07-02-2010, 06:43 PM   #9
jayshawaii
Member#: 250277
Chapter/Region: HIIC
'03 Baja
Black/Silver
Default Baja tailgate stuck closed
My problem is just the opposite. The tailgate on my '03 Baja is stuck in the closed position. I took the plastic liner and the metal hatch off, from inside the bed, to take a look. It appears that the whole latch mechanism is a bit weak, or I have a very heavy, ham-hand.
When the release handle, at the back of the gate, was engaged, to open the gate, the latches (inside the latches, on both sides of the tailgate) malfunctioned. The pawls that lift the latch mechanisms, came past the latch lifters. They are, now, just floating above the latch. Now there is no way to get them to go down past the lifters, within the mechanism, to be able to re-engage the latch. It would be a royal pain to try to remove the latches when they are engaged in the closed position.
Has anyone else had this problem? Or, does anyone know how to get the latches to disengage from the outside so that I can let the gate down to disassemble the latch mechanism to get the lifter pawls to re-engage the latch?
jayshawaii is offline   Reply With Quote
Old 07-14-2010, 09:44 PM   #10
drchiro1
Member#: 252101
Default sticky tailgate
I have same problem with tailgate. Noticed that the handle gets stuck. If you manually push the handle back to its starting position the gate will close on the first attempt. I still need to dismantle the door to lubricate necessary parts.
drchiro1 is offline   Reply With Quote
Old 07-21-2010, 02:29 PM   #11
vfr750mmm
Member#: 252685
Default Tailgate Not Closing?
Like others who have posted, my 2003 Baja also will also not close unless I push the latch into the closed position by hand and close the gate. Slightly a pain if your other hand is holding something. Also be careful not to let the gate slam closed once the latch it secure as the plastic lip on the gate will catch and tear skin EASILY.
vfr750mmm is offline   Reply With Quote
Old 10-05-2010, 08:50 PM   #12
jayshawaii
Member#: 250277
'03 Baja
Black/Silver
Sorry to see that no one has come up with a solution to this problem. Guess I'll have to bite the bullet and take it to the dealer. Cheers.
Old 10-06-2010, 12:29 PM   #13
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Its normally not the latch, the plastic handle is whats sticking. Just need a new handle, or just lube it. <-------SOLUTION
Samirr76 is offline   Reply With Quote
Old 10-06-2010, 05:16 PM   #14
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
This is not a difficult fix, it's very simple.
1) Take off the rubberized cover on the inside of the tailgate.
2) Take off the large metal panel sheet that you'll find under the rubber cover.
3) Take some WD-40 to all moveable springs, pins and latches. Open/Close the tailgate several times - work the lube in there real good. Squirt a little more WD-40 in there to be safe.
4) Put it back together.
TaDA!
NOTE: I had to do this for my `04 Baja earlier this summer - had the same problem. The steps above solved the problem.
moonzie is offline   Reply With Quote
08 OEM Tune. is it Me or, is it Crap? dstn2bdoa Engine Management & Tuning 2 06-05-2010 04:04 PM
Yeah!!! I did it. Four Times.. tcarter South East Region Forum 9 02-09-2004 01:28 PM
No Suby for three or four weeks! nitrohuffer Tri-State Area Forum 3 08-31-2001 04:52 PM
Dang it. Three body shops won't paint my sideskirts. Snoopy General Forum Archive 9 06-03-2000 06:49 PM
Three or four new RS's in KC area??! Bahumut Mid West Subaru Owners Club Forum -- MWSOC 1 03-24-2000 11:53 PM
