Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Mid Atlantic Impreza Club
Old 11-22-2009, 12:14 PM   #1
Angel81
Member#: 165981
2005 STi ZZZZZZZZZZZ
Exclamation Changing out the corner light sucks.
Does anybody know an easy way to reach the corner light on the '05 headlight? Tried unscrewing the bolts that hold the projector but it wont come out. Who knows a way? Thanks.
Angel81 is offline   Reply With Quote
Old 11-22-2009, 12:53 PM   #2
matt06wrxwgn
Member#: 172027
2006 CGM Wagon
322WHP 355 WTQ
you might be better off removing the entire headlight, you don't want to screw up and sever a wire. If you remove the whole thing, you should replace all the small bulbs so you won't have to do it again too soon
matt06wrxwgn is offline   Reply With Quote
Old 11-22-2009, 12:55 PM   #3
Angel81
Member#: 165981
Yeah, but the headlight wont come out. Don't want to force nothing and break it.
Old 11-22-2009, 03:40 PM   #4
Borjaq
Member#: 4812
04 STi
Blk
3 bolts on each headlight assembly, 10mm or 12mm, remove front grille for access to bolts,gotta be a little persistent getting the headlight out and in as it is a "very" tight fit. Make sure the thin rubber seal around the headlight is flush against the fender area when you put it back in, it likes to fold over sometimes. I know this is quick, but I hope it helps.
Add: Give me a few mins. I'll get some pics real quick.
Remove the grille to access the passenger side headlight.
Remove the two bolts (10mm) and the two plastic rivets.
Remove the thrid bolt for the headlight.
Remove these rivets as well to make the process easier.
Gently pull the bumper back and wiggle the headlight. Gently try to pull the headlight out.
The headlight should come out on the fender side first and then the bracket that was holding the third bolt last.
Do any headlight work you need and installing is the reverse of removal.
Here is a pic of the folding rubber that I was talking about earlier.
Hope this helps if you haven't done it already! Later!
Sorry if the pics arn't great. Used my Berry to take them. Post any questions if you still have any.
Borjaq is offline   Reply With Quote
Old 11-22-2009, 06:58 PM   #5
Angel81
Member#: 165981
Thumbs up
Wow, thanks for all that man, I appreciate it.
Old 11-23-2009, 11:34 AM   #6
Borjaq
Member#: 4812
04 STi
Blk
Not a prob!
Old 11-23-2009, 02:54 PM   #7
richy_21
Member#: 58670
2005 got muuuuu?
^folding rubber?
richy_21 is offline   Reply With Quote
Old 11-23-2009, 04:46 PM   #8
Borjaq
Member#: 4812
04 STi
Blk
Originally Posted by richy_21 View Post
^folding rubber?
Yeah. The trim seal around the headlight assembly. Heres the pic again...
Old 11-23-2009, 08:28 PM   #9
Matt
Allergic to turbos
Member#: 181
2009 Forester
Excellent!
I know what I'll be doing this weekend if it stops raining. Thanks for the description and pictures.
Matt is offline   Reply With Quote
Old 11-23-2009, 11:14 PM   #10
Borjaq
Member#: 4812
04 STi
Blk
Originally Posted by Matt View Post
Excellent!
Your very welcome!
Old 01-12-2010, 04:11 PM   #11
nu2boost
Member#: 79748
Thanks.. great pics.. good luck to me
nu2boost is offline   Reply With Quote
Old 01-12-2010, 04:30 PM   #12
Borjaq
Member#: 4812
04 STi
Blk
No prob and good luck.
Old 01-12-2010, 08:20 PM   #13
steverx05
Member#: 128269
'13 VW Golf R
These last 3 clips aren't entirely necessary to remove to get the lights out. I would say just leave them in since these plastic rivet clips just get messed up or lost very easy.
Other than that, great write-up.
steverx05 is offline   Reply With Quote
Old 01-14-2010, 05:02 PM   #14
Borjaq
Member#: 4812
04 STi
Blk
Your right, you don't have to remove those rivets, I just found having them out made it easier to slide the projector in and out and it helps keep stress off the bumper when you pull on it to get the projector in and out. And thanks!
Old 01-14-2010, 05:54 PM   #15
bonzai
Member#: 85031
2003 WRX Axis 2.5
Man!! You have to love people like that.. Nice...
bonzai is offline   Reply With Quote
Visited Philly over the weekend - the traffic lights suck! Cjchaps Off-Topic 1 09-12-2005 04:06 PM
Now I Need To Change Out the Parking Lights... Tek Electrical & Lighting 4 01-22-2004 11:16 PM
Toe setting & additude of car through out the Corner FuJi K Motorsports 14 01-30-2003 12:44 PM
How to get out the corners??? RS22b Interior & Exterior Modification 5 05-18-2001 07:06 PM
Anyone change out the end links on the rear swaybar of a WRX yet? Snappy Brakes, Steering & Suspension 3 04-29-2001 05:23 AM
