Old 11-22-2009, 02:11 PM   #1
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Default Head bolt question
Do you NEED to replace head bolts when rebuilding or replacing head gaskets. My local Subaru dealer says you don't need to. I was always told that when you remove a head bolt, throw it away. They're junk because they stretch when you torque them.
PSolbergfan is offline   Reply With Quote
Old 11-22-2009, 02:25 PM   #2
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
there is a tool to measure stretch and there are tolerances. they def do stretch. i don't know about remove and throw away but arp head studs can be bought for under 200$.
maxpowr is offline   Reply With Quote
Old 11-22-2009, 02:38 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
This subject has been covered numerous times over the years.
Subaru does not prescribe new bolts when changing headgaskets. Subaru does not use cheap steel in those bolts (as some other mfgrs do). I've done dozens of changes and never had any issues with re used headbolts.
If it makes you sleep better at night....buy new ones.
Jay
Old 11-22-2009, 02:41 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
I never replace the bolts doing head gaskets. I've never had a problem and I have done a ton of head gaskets.
Old 11-22-2009, 02:47 PM   #5
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Some will say you do and that they stretch. Some will say you dont. I personally used the same head bolts for 3 rebuilds on my last motor without any issues, as long as they are torqued bak down to spec. To solve the problem though, use head studs! APR FTW!
rek888v2 is offline   Reply With Quote
Old 11-22-2009, 03:20 PM   #6
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
are you talking about factory head studs? or aftermarket ones like ARP's or something.. I got a pair of ARP's from a friend w low miles, will it be ok to put them in my car wen I do headgasketa
BONFIRE074 is offline   Reply With Quote
Old 11-22-2009, 03:23 PM   #7
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
you can get the tolerances of the arp bolt new and simply measure it. i have seen differences in stretched bolts from a same set but we are talking about in the ten thousands of a difference. i wouldn't worry about using stock head bolts over if your below 350 whp.
Old 11-22-2009, 10:45 PM   #8
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
Thanks for the info everybody! It helps a lot. I am talking about the OEM head bolts.
Old 11-23-2009, 05:18 AM   #9
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Yes, you can reuse head bolts, I have used the same ones 3 times on the same motor.
Old 11-23-2009, 06:30 AM   #10
Mechie3
Member#: 120152
There was a dealer that posted on here. For new bolts they uses the special tightening pattern. For used bolts, he just torques them. I don't recall the value...but it was maybe 76 ft-lbs? Don't quote me on that though.
Mechie3 is offline   Reply With Quote
Old 11-23-2009, 07:12 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Unfortunately, I don't think it's the best advice to follow a procedure devised by someone working on flat rate. There's a few ways to trim time off the job, but I don't think the torque sequence should be one of them.
Jay
Old 11-23-2009, 08:14 AM   #12
Mechie3
Member#: 120152
I've always followed the entire sequence myself.
Old 11-23-2009, 08:22 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
I didn't think you would....Just kinda tossing it out there for others.
Jay
Old 11-23-2009, 08:38 AM   #14
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
They have TQ/sequance specs for a reason. Always follow them, I didnt once and, well, you can guess. Very expensive lesson.
Old 11-23-2009, 03:50 PM   #15
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
I'll ask my local subaru tech. He's never steered me in a wrong direction.
Head Bolts Question kleen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-11-2007 12:01 PM
Stupid cylinder head bolt question - 14mm x 12-point socket? root Built Motor Discussion 3 07-03-2007 07:56 PM
question about 02 wrx head bolts Subynut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-30-2007 11:29 PM
head bolt question?? Pacobeagle Subaru Conversions 2 01-28-2006 04:14 AM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 07:30 AM
