Old 11-22-2009, 08:37 PM   #1
ejcookso
Member#: 35041
Default 2003 Subaru Legacy - CEL Codes P0301 & P0302
Background: I just moved from NC to CO and have a 2003 Legacy L wagon w/ 112.5K miles on it. Upon moving to CO (2 weeks ago) I started using 85 octane gas (which everybody tells me is OK due to the high altitude). Today I got a CEL, and had the local parts place scan it. The result: P0301 & P0302 - misfires in cylinders 1 & 2.
I haven't noticed that it runs rough or runs rough, but I think I can smell a little unburned fuel in the exhaust (not overwhelming, but it does smell like gasoline).
My plan:
1) I'm nearly out of gas. Fill up the next tank w/ 87 (or higher) and hope it goes away
2) I need plugs & wires at 120K anyway, so I'll probably change those out too (with OEM parts).
Hopefully these two things will fix it, but if not, what's the worst case scenario?
Thanks,
Ted C.
ejcookso is offline   Reply With Quote
Old 11-22-2009, 08:50 PM   #2
SpeedmanRC
Member#: 230758
2000 Legacy Wagon
Timberland Green
I had misfire codes cause the previous owner had almost 50k on copper plugs. I changed them out and all was well. if you are due for a plug change I would think about changing them.
SpeedmanRC is offline   Reply With Quote
Old 11-23-2009, 07:56 PM   #3
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Possible aging coilpack? There are probably 3 10mm bolts holding it on. Look at the bottom to see if it's cracked.
If you need one, shout - of three Subarus I currently own, none uses these my-old-Legacy style coilpacks I have in the basement.
LetItSnow is offline   Reply With Quote
P0301 & P0302, what should i do? doubledribble Normally Aspirated Powertrain 13 11-14-2011 09:52 AM
CEL codes P2100 & P2102 dream Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-03-2008 11:46 PM
cel codes p0301 and p0420 hagood22 Newbies & FAQs 0 04-17-2008 09:14 PM
CEL Code P0301 - Bad Gas in CA? EBWRC#1 Southern California Impreza Club Forum -- SCIC 34 07-26-2007 04:11 PM
2003 Subaru Legacy for sale eb50 Private 'For Sale' Classifieds 0 05-17-2005 08:24 AM
