Old 05-17-2002, 07:09 AM   #1
WRXterminate
Member#: 5945
Question Downpipe - twin dump vs single
Is there any dyno evidence whether a BPM style pipe (twin dump)
that separates the wastegate exhaust over a long stretch of the pipe is significantly better than something with a single, albeit large mouthed, pipe like the TurboXS downpipe? (And you all know Vishnu is developing a twin dump with a cat and is claiming good performance numbers.)
http://www.subaruwrxparts.com/parts/bpm_dp_2.jpg
http://www.turboxs.com/WRX%20Exhaust.htm
WRXterminate is offline   Reply With Quote
Old 05-17-2002, 07:40 AM   #2
Dori Dori
Member#: 6780
1993 Nissan
If you do a search, there is a very good thread out there...I forgot who started it though...
Basically, most people feel that on the stock turbo, it doesn't really make a difference. Shiv and Joel at Vishnu feel different though.
Everyone does agree though, that in design, the twin dump is better.
Dori Dori is offline   Reply With Quote
Old 05-17-2002, 08:19 AM   #3
WRXterminate
Member#: 5945
Post
Actually I did do a search, but it didn't turn up any dyno plots, scientific evidence.
Someone did say though the TXS pipe gave smoother power than the BPM twin dump, which should show up on a dyno.
Note: I'm considering the MRT downpipe which is somewhere in between the two types to cover my bets (and reduce the possibility of a CEL). Vishnu is my other option, but it isn't available yet.
Old 05-17-2002, 08:40 AM   #4
mlambert
Member#: 13831
id think that godspeed would be a good option if you are worried about cel's
mlambert is offline   Reply With Quote
Old 05-17-2002, 03:04 PM   #5
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
And which one should I choose If I go with a VF30? Would love to add the Vishnu with an HKS or Kakimoto, though I guess it will not work with neither of these.
Julio is offline   Reply With Quote
Old 05-18-2002, 01:40 PM   #6
Z1 Performance
Member#: 9327
For a Vf30, it honestly won't matter if you go twin dump or bellmouth...just make sure the wastegate gasses are not totally blocked off (like the factory downpipe).
Twin dump is a nicer design, more costly to make, and tends to fit better though.....it also will take you further should you upgrade from the VF30 in the future.....
adam
Z-1 Performance
Z1 Performance is offline   Reply With Quote
Old 05-20-2002, 08:54 AM   #7
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Cool
Thanks, Z1
Old 05-20-2002, 11:12 AM   #8
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
A twin dump or a bell mouth is there for boost control, not horsepower. When in boost your wantegate for the most time is closed and nothing is going though there. Only when you have a turbo that gives you boost creep, only then will having a smooth or even a sepate path for the wastegate give you more power and better wastegage control. Speaking from experience.
Alex...
amelnikov is offline   Reply With Quote
Old 05-20-2002, 11:20 AM   #9
rota wheels wrx
Member#: 13856
04/5 STI
white/WRB
With the STI OE turbo (VF23 I think?) I have tried both a twin dump and single dump design, In terms of power, they are not far off. You might say no diff but the sound, Oh my God the sound!!! With the twin dump, the sound it makes when the wastegate starts dumping boost is incredible. It like having another blow off valve going off during full throttle.
rota wheels wrx is offline   Reply With Quote
Old 05-20-2002, 11:22 AM   #10
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
Listen, do a search, I've discussed this many times before. Simply put twin-dump is better for preventing the wastegate charge from disrupting the airflow coming out of the turbo. Now this really isn't a factor until you reach 400+ horsepower. So until you reach that power level, which most people aren't, then the extra expense of running a twin-dump system isn't really worthwhile. For most street driven applications, a properly designed bellmouth like Cobb's Cast unit on their down-pipe should be more then adequate.
sherif
sherifx is offline   Reply With Quote
Old 05-20-2002, 11:25 AM   #11
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
One possible rational for Shiv and Joel at Vishnu feeling this way is because their stage packages are progressive. Each stage builds upon itself, so by the time they drop stage 3 and 4, the car would be making monster power, so a twin-dump setup becomes more efficient.
sherif
Old 05-20-2002, 12:05 PM   #12
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
I know you have "discussed this many times before" but the purpose of the twin dump isn't to prevent the wastegate exhaust from interfering with the turbine section exhaust, it's the other way around. You probably know that and just got it backwards
Conduit is offline   Reply With Quote
Twin plate vs. single plate clutch? w321shark Newbies & FAQs 4 08-18-2008 08:52 PM
FS: Catted downpipe - twin dump - cheap nimaxpro Tri-State Area Private Classifieds 13 06-22-2006 11:23 PM
FS: Catted downpipe - twin dump - cheap nimaxpro Private 'For Sale' Classifieds 9 06-22-2006 03:25 PM
zilla td06-20g, *DOWNPIPE* twin dump or bellmouth? WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-04-2005 04:38 PM
twin dump vs single dump downpipe FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-10-2001 03:07 PM
