Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-23-2009, 02:29 PM   #1
psychoskip
Member#: 78408
Now selling doses
of Acromegaly - GET SWOLE
Default Thermostat / overheating issues Sort of odd issue
First off, thanks for all the help guys...I don't know what I'd do without you.
Here's the problem. I start my car, and wait for it to get to operating temp. Ill drive to my destination and the moment i'm at a standstill, the car will slowly start to overheat. I've carefully monitored it to find the issue, and it never goes to red.
It's a 2.5T motor w/ roughly 50K.
No leaks at all, i have enough coolant. All hoses appear to be functioning properly.
Is this a thermostat issue?
psychoskip is offline   Reply With Quote
Old 11-23-2009, 02:40 PM   #2
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
To determine that you have enough coolant, did you just look at the overflow?
It sounds to me like there is a bubble in your system. Even with a bad Tstat it would take a second to start cooking. With a bubble, it does what you described (mine has done it before).
CKxx is offline   Reply With Quote
Old 11-23-2009, 03:00 PM   #3
psychoskip
Member#: 78408
Now selling doses
Thanks, should I just burp the system?
Old 11-23-2009, 04:02 PM   #4
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
Burp the system. I would do a 30/70 ratio of coolant to distilled water or a 50/50 (if it gets real cold where you are) and one bottle of Redline water wetter to the mix.
I had the same overheating problem when was at at a stop/standstill. I did the 30/70/Redline water wetter and I also put in a Crucial Cool Safe T-stat. I have not had a problem since (also have cooler temps then ever).
csmithwrx'05 is offline   Reply With Quote
Old 11-23-2009, 04:33 PM   #5
psychoskip
Member#: 78408
Now selling doses
I was eyeing the Grimmspeed thermostat...but I will try what you suggested and see where it gets me
Thanks!
Old 12-15-2009, 08:08 PM   #6
WRXpiprezza
Member#: 69851
did you ever fix this issue? I have the same issue on my car recently
WRXpiprezza is offline   Reply With Quote
Old 12-15-2009, 08:18 PM   #7
psychoskip
Member#: 78408
Now selling doses
I totally forgot to update!
Yes, I fixed it. Just a simple burp of the system. Took me 5 minutes.
Odd issue with Rallitek/IPD swaybar SportyMark Brakes, Steering & Suspension 1 01-25-2010 08:55 PM
Odd issue with 05 WRX shifting NJHK Transmission (AT/MT) & Driveline 3 07-21-2009 08:39 AM
Help My Car Please... All Sorts of Issues!!! Djreversal Service & Maintenance 3 08-13-2008 07:20 PM
odd issue with idle and driving rigpin Factory 2.0L Turbo Powertrain 4 10-24-2006 12:50 AM
odd issue with idle and driving 03 WRX rigpin South East Region Forum 10 10-15-2006 08:57 AM
Message Board Statistics All times are GMT -4. The time now is 01:50 PM.
