Old 11-23-2009, 03:21 PM   #1
WRC_Fever
Member#: 145491
2004 STi
WR Blue
Default CEL p0442 fixed- may help you
Was throwing a p0442 every month or so for the last 5 months (evap system small leak) on my 2004 STi. Wasn't my fuel cap. Friday I used a smoker to attempt to find the leak in the system. Tapped in at the secondary purge valve coming off the intake. A few seconds in and smoke was pouring out from below. Turns out one of the nipples had broken off of my Evap purge valve (primary). I have included a pic below.
WRC_Fever is offline   Reply With Quote
Old 12-02-2009, 11:04 PM   #2
soob noob
Member#: 220158
02 bugeye
medamullet tuned
bump.. can you fix your pics because i keep getting this CEL and its not my gas cap
soob noob is offline   Reply With Quote
Old 12-13-2009, 11:55 AM   #3
jokers
Member#: 136839
yes thank you i got the cel
and found one of my nipples were broken
jokers is offline   Reply With Quote
Old 12-13-2009, 06:27 PM   #4
Badler
Member#: 133597
Pics please!
Badler is offline   Reply With Quote
Old 12-13-2009, 08:28 PM   #5
Badler
Member#: 133597
Pics please!
Old 12-15-2009, 09:35 PM   #6
KiggerSTI
Member#: 93813
2005 STi
Sir We need this pic please!!!
Pic Please!!!
KiggerSTI is offline   Reply With Quote
Old 12-15-2009, 10:56 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this failure point is quite common and is likely THE most common cause of the
p0442 other than the gas cap not being tight
Old 12-16-2009, 09:29 PM   #8
KiggerSTI
Member#: 93813
2005 STi
is not gas cap!!! i checked and checked~!!! it come out when hit some bump on freeway, goin like 70-75 mph!!!
Old 12-16-2009, 09:52 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 12-17-2009, 01:14 AM   #10
soob noob
Member#: 220158
02 bugeye
medamullet tuned
alright i found some photos somewhere on line that i can find now... take off your alternator cover and just to the left of the alternator there are some hoses. check those the blue t-connector is down there but its a bitch to get to. good luck man
Old 12-17-2009, 03:14 AM   #11
penusai
Member#: 102808
1995 v8 EJ207 v7 6sp
30r swap in progress
penusai is online now   Reply With Quote
Old 12-17-2009, 07:47 PM   #12
KiggerSTI
Member#: 93813
2005 STi
ummm Pic??? Pic Please....
Old 12-18-2009, 03:00 AM   #13
soob noob
Member#: 220158
02 bugeye
medamullet tuned
http://www.clubwrx.net/forums/engine...-post-maf.html
look at the picture and check ALLLL the hoses that connect or are in the surrounding area! if you look just below this valve for the evap system is where the "blue" piece that is talked about. like i said tho its a bitch to get to
Old 12-20-2009, 06:38 AM   #14
jokers
Member#: 136839
Default thx for this wrx_fever
thanks to this
replaced the solenoid now the car runs how it suppose to run, holds boost, car idles smoother, plus no more evap system cel, which i left on there for months cuz had no idea what it could be....
and i thought before it was normal dam hahah it would boost and then go down but now it holds it there and my eyes just open big
great now i want to retune the car
Old 12-20-2009, 06:43 AM   #15
jokers
Member#: 136839
look down left of alternator under the hoses u see a blue piece left of that is the solenoid
i also had to change some hoses cuz they were all hard and cracked on me
to replace i removed the alternator, not too bad just wiggle it out and wiggle it in
Old 12-20-2009, 06:50 AM   #16
jokers
Member#: 136839
found this pic off something else
thats the solenoid he taking off
Old 12-21-2009, 11:57 AM   #17
KiggerSTI
Member#: 93813
2005 STi
thanks Jokers!!! Nice One!!!!
Old 01-08-2010, 03:06 AM   #18
jeffk182
Member#: 150649
2014 STI
I just fixed my P0442 CEL today on my 07 sti.
I used a smoker at work and didnt see any smoke coming out from anywhere. Tested the gas cap and that was fine. I doubt this is a normal problem, but my cause was a bad gasket for the fuel pump...funny because i've never opened that cover before lol. I pressurized the tank and heard a hissing sound and so I sprayed some soap water and saw bubbles coming up through the threads....i just unbolted the cover, cleaned the surfaces and bolted it back up; no more leak!
jeffk182 is offline   Reply With Quote
Old 10-15-2011, 03:03 AM   #19
Deadly_Evolution
Member#: 295471
2006 WRX
Ah thank you for this pic and thread!!
Would the hose at the blue T also cause a boost leak at all?
Deadly_Evolution is offline   Reply With Quote
Old 01-17-2014, 12:30 PM   #20
Srk2014
Member#: 379012
2005 Impreza 2.5rs
Default P0442 possible fix
Suburu recall WVL22 (05-08 Forester, 05-07 Impreza 2.5l) requires the dealer to remove the fuel sender unit. If you started getting this code any time after this recall, this is another location to check. Other threads show how to check this area so I won't go into specifics. However on mine I failed to inspect the dealers work until I got the code, and sure enough a wire was stuck under the sender cover, causing the gasket to fold over. When I first removed the access cover from the trunk, I could see and smell fuel all around this cover. Hopefully this will help.
Srk2014 is offline   Reply With Quote
Cel P0442 PorterFNU Newbies & FAQs 1 10-06-2009 06:52 PM
CEL P0442 stand up imma_stocker Texas Impreza Club Forum -- TXIC 6 11-04-2007 10:19 PM
CEL P0442 (evap small leak) + instable boost frederik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-20-2007 11:49 AM
Cel P0442 Rando Engine Management & Tuning 5 03-29-2006 10:14 PM
CEL P0442/P0457? (Help Needed) APSWRX1 Texas Impreza Club Forum -- TXIC 4 03-28-2006 02:16 PM
