Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 11-23-2009, 10:10 PM   #1
TheIglu
Member#: 230875
2002 Impreza 2.5RS
Default Clunking in front end, high milage 2.5RS
Hello all,
I have a 2002 2.5RS. She's got about ~160k on the clock.
Original shocks (yikes).
When I hit larger bumps, I hear a clunking up front. The steering is tight, so I don't think it's a tie rod end.
Given the milage, what is the typical cheap shock replacement running these days? Autozone/Advance don't list any replacement shocks/struts on their website, which is odd since it is such a common car.
Are shock tower mounts something that go south eventually?
Not a Subaru guy, it's my wife's car. Hence my lack of knowledge.
TheIglu is offline   Reply With Quote
Old 11-23-2009, 10:22 PM   #2
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
kyb makes replacement struts specifically for the RS, just do a internet search and you can find tons of retailers that carry them.
evo2rex is offline   Reply With Quote
Old 11-23-2009, 10:24 PM   #3
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Kybs are good, I'd recommend the stock replacements though. And the Mounts can go bad, but it is likely you just need to replace the struts and springs and she will be good to go.
Agkelos is offline   Reply With Quote
Old 11-23-2009, 10:25 PM   #4
van_dutch
Member#: 198633
2004 WRX
Have you checked the endlinks?
van_dutch is offline   Reply With Quote
Old 11-24-2009, 08:26 AM   #5
TheIglu
Member#: 230875
2002 Impreza 2.5RS
Haven't checked the endlinks. Not even sure what you mean by those. I've checked the tie rod ends for play, no issue there.
Old 11-24-2009, 08:41 AM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Make sure the nut on top of the struts is tight. If it works itself loose it will clunk.
Also, look at and shake the swaybar to see if anything came loose.
garface is offline   Reply With Quote
Old 11-24-2009, 08:21 PM   #7
van_dutch
Member#: 198633
2004 WRX
The endlinks aka swaybar endlinks are the links attached to the end of the swaybar and then to the rest of the suspension. I just replaced mine due to a clunking over bumps.
Old 11-24-2009, 09:21 PM   #8
TheIglu
Member#: 230875
2002 Impreza 2.5RS
Ahh, got it now. Those are pretty easy to get to also. I'll jack it up tomorrow and give them a wiggle.
Thanks for the help, that may of just saved me needlessly putting in a set of struts!
Old 11-24-2009, 10:25 PM   #9
jaypt802
Member#: 149730
2002 Impreza WRX
also just double check the control arm bolts, i had a clunk for a few months and then finally got a chance to fix it, turn out that a bolt wasn't torqued down properly!!!!
jaypt802 is offline   Reply With Quote
clunk in rear end???? subeman90 Baja Forum 4 09-27-2006 06:26 AM
Clunk in front suspension carpetsloth Brakes, Steering & Suspension 13 02-03-2006 01:16 PM
Clunk in front end since Prodrive & KYB Install sajohnson Brakes, Steering & Suspension 10 10-10-2005 10:50 AM
Clunk in front end flent Normally Aspirated Powertrain 13 08-13-2002 12:20 AM
Clunking from front end SubieFL Brakes, Steering & Suspension 25 10-29-2000 03:01 PM
