Old 05-17-2002, 11:39 AM   #1
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Default More EJ22T Head Questions
Hi all,
Lots of EJ22T questions today, that's nice. The thing I'm wondering is for those with EJ22T blocks and EJ25 Top ends, did you modify the heads at all to get them to work? The reason I ask is the different bore. Speaking of which, what is the Bore of a 2.5RS vs the Bore of a 2.2T? Will or does this cause a problem?
Chad
93 1.8T (possibly (very) soon to be 2.2T)
subachad is offline   Reply With Quote
Old 05-17-2002, 12:08 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
The EJ25 (SOHC) heads bolts directly to the EJ22T without modification. Bore really doesn't affect what heads you can use because the combustion chambers are all going to be smaller than the block bore
Eric
Eric SS is offline   Reply With Quote
Old 05-18-2002, 07:44 AM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Chad,
The bore differences shouldn't matter too much, since along with the head gasket bore and thickness, that only affects the squish volume. You should be much more concerned about squish volumes, valve angle/timing, fuel management, ignition timing, and compression ratios instead. And choosing head gaskets that won't leak.
I have read elsewhere that engineers spend a lot of time optimizing squish volumes. But by the sounds of the wide variety of EJ22T hybrids using all sorts of DOHC/SOHC head gaskets, we're probably safe with the EJ series motor at the lower boost levels we run. Cobb's EJ20/EJ25 hybrids are extreme examples that seem to work.
You can find bore numbers by doing a search on the Net, and I have also compiled them at:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
Hope this helps,
-WaC
Wayne
wac is offline   Reply With Quote
Old 05-18-2002, 12:26 PM   #4
subachad
Member#: 8488
Teal
Thanks for the good answers. Wayne, that's an excellent write up, I keep meaning to add you to my links page, I think I'll just do that now.
Chad
93 1.8T
FS: 3 Sets of injectors, ej22t heads and Intake manifold, more! silentt Engine/Power/Exhaust 21 08-06-2007 10:33 PM
EJ22t with rs heads question Olson Subaru Conversions 7 08-16-2005 05:31 PM
More EJ22T Hyrbid Questions seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 5 03-11-2003 05:32 PM
