Old 11-24-2009, 08:16 PM   #1
jacksonjrs
Member#: 213043
2003 WRX
Default My first log with romraider
This is my first datalog with my xpt stage 2 map. As far as I can tell everything looks good to me. What does everyone else think??
jacksonjrs is offline   Reply With Quote
Old 11-25-2009, 01:06 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
If you read this, you can figure out everything I was going to say:
http://www.romraider.com/forum/topic5384.html
Old 11-25-2009, 01:33 AM   #3
oxox55
Member#: 217423
02 wrx E85
psm
looks pretty good. As I recall xpt maps call for 8* knock correction, yours drops to 7 in a few cells up top. It's probably a correction made to the fine learning correction table thats pulling a degree of timing. I think your boost target is more like 17.5 too, but contact braden he should be able to answer all your questions.
oxox55 is offline   Reply With Quote
Old 11-25-2009, 09:48 AM   #4
jacksonjrs
Member#: 213043
2003 WRX
Boost target is in 4th gear, I did a pull in 3rd gear and according to the instructions should be a target of 16.
Old 11-25-2009, 05:15 PM   #5
oxox55
Member#: 217423
02 wrx E85
psm
well in that case its looks pretty solid
Old 11-25-2009, 05:20 PM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Get rid of A/F sensor, total timing, intake temp, knock correction, and wastegate duty cycle
Replace them with feedback knock correction, fine learning knock correction, IAM, and boost error
Old 11-25-2009, 05:21 PM   #7
Member#: 51961
2005 STi
2012 WRX
double post
Old 11-25-2009, 05:21 PM   #8
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
looks conservative but solid
scoobystas is offline   Reply With Quote
Old 11-26-2009, 10:24 AM   #9
motocooney
Member#: 176235
09 Mazdaspeed3
Is the boost oscillating a bit between 3454rpms and 4604 rpms? It's very slight but it seems to jump up and down a bit.
I only ask because I'm having the same problem. Or maybe it isn't a problem?
motocooney is offline   Reply With Quote
Old 11-26-2009, 01:21 PM   #10
NSFW
Member#: 140444
05 Stage Free LGT
OP, was there any audible wastegate flutter during this pull? That might explain the boost fluctuations... but I'm just guessing here. And I generally only hear it at part-throttle so I'm not even very confident in this guess.
Old 11-27-2009, 09:56 AM   #11
jacksonjrs
Member#: 213043
2003 WRX
I don't belive there was any wg flutter, what would that sound like?
Old 11-27-2009, 03:47 PM   #12
NSFW
Member#: 140444
05 Stage Free LGT
Pft-pft-pft-pft, like 2-3 times per second. It's louder on some cars than others.
Old 11-27-2009, 04:55 PM   #13
jacksonjrs
Member#: 213043
2003 WRX
I've never heard anything like that so I'm gonna say I'm not getting any flutter.
Old 11-29-2009, 06:03 PM   #14
Neohumanist
Member#: 230209
2004 WRX Wagon
Hey all,
I'm new to subies/NASIOC and dont mean to threadjack, but I may be getting a wrx soon that needs a tune and was thinking of going open-source. Are there any FAQ's/tutorials etc that would be good to read first? Also any personal success/failure stories w/opensource tunes? Thanks!!
Neohumanist is offline   Reply With Quote
Old 11-29-2009, 06:31 PM   #15
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Get a wideband w/gauge.
flimflamman is offline   Reply With Quote
Old 11-29-2009, 06:51 PM   #16
kh15
Member#: 132400
2006 WRX
logs look good, take the suicidal eggrolls advice on logging parameters though and don't forget to use learning view before and after a logging session!
i run a xpt stage 2 map as well and its a little conservative but a nice solid platform!
be safe!
kh15 is offline   Reply With Quote
Trouble Logging with RomRaider mr.four Open Source Reflashes 13 02-11-2010 08:00 PM
P0420 on a stock 2005 2.5RS - log with RomRaider? mattmak Normally Aspirated Powertrain 8 01-20-2010 12:19 PM
Can't Log with RomRaider KUrex Open Source Reflashes 2 05-19-2009 08:19 PM
Logging With Romraider 06 wrx lagodcm Open Source Reflashes 4 01-15-2009 09:02 PM
First log with my custom exhaust *ADVICE* CenCali07sti Open Source Reflashes 8 01-21-2008 12:24 AM
