Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Flatirons Tuning
Old 11-25-2009, 06:20 PM   #1
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
Rally Stuff Sale on Subaru 4-Pot kits & STI Brembos, Prodrive, Whiteline, Hawk, Racing Brake!!!!!
We stock the Subaru 4-Pot Caliper's - New Lower Price!!!
It there is one weakness to the WRX, it is its brakes, and the more power that you make, the more obvious this becomes. Subaru has finally addressed this issue on the 2006 WRX by putting on Subaru’s 4-Pot brake calipers, and now you can retro-fit these calipers to your WRX and dramatically improve your braking capacity.
The Subaru 4-Pot calipers were first used on the 2000 – 2001 JDM STI, and are what many Subaru Rally Teams are currently using in Open, and Group-N classes.
These calipers are a direct bolt on, and use the same front rotors as the 2002 – 2005 WRX.
Because these are 4-Pot calipers, these calipers may require different wheels.
These calipers will fit under the 02-05 WRX stock wheels with the use of a 5mm spacer.
The kit includes
- 1 pair of calipers (Red or Black)
- All necessary mounting pins and springs
Pads are Now Sold Seperately so you can build your own kit!
The Complete Red kit is $555.00 for the Calipers and mounting hardware!!!
Click Here to order your Red Subaru 4-Pot Brake Upgrade for $555.00
We are offering FREE SHIPPING on Brembo STI Brake Up-Grade Kit's!
This kit put together by Brembo utilizes the exact same calipers, and rotors that are found on the STI, providing a substantial increase in braking performance. The stock brakes on a WRX, Forrester, or Legacy GT are borderline inadequate when used at the track, or in aggressive driving. This kit was put together by Bermbo to give these cars the same awesome stopping power as their big brother, the STI.
The Kit includes:
1 pair of Brembo front or rear calipers
1 pair of Brembo pads
1 pair of Brembo slotted rotors
1 pair of Stainless Steel lines
And all mounting hardware necessary to use these brakes.
Keep in mind that the use of this brake kit may require special wheels. Use the 2004 STI as a guide, as it has the same 5 X 100 bolt pattern as these cars, and those wheels clear these calipers.
Get STI performance and Brembo reliability for a fraction of the cost of other kits.
Click Here for the Front Brembo Brake Kit - $1531.20
Click Here for the Rear Brembo Brake Kit - $1723.20
The Legacy H6 rear brake upgrade is a simple (and cheap!) brake upgrade for the 2002-2005 Subaru WRX.
This upgrade uses your stock rear calipers. By moving the caliper out with a different caliper bracket, it allows you to use the H6 Legacy rear rotors, which have the same contact patch as the WRX rear brakes, but are an inch larger in diameter.
For the 2002 (and early 03') WRX kit, you will be getting the 2002 style bracket by RacingBrake, and for the 03-05 WRX's, you will be getting a RacingBrake caliper bracket designed for your calipers. They are different, so contact us if you are unsure which kit you need!
For rotors, you have a choice between the OEM H6 rear rotors and the Disc Brakes Australia DBA657SLR slotted rear rotors.
Click Here to order your H6 Rear Brake kit - $241.92
These adaptors have been designed by Kartboy to allow you to adapt the Subaru 2-Pot rear calipers off of the 2006 - 2007 WRX to fit on the 2002 - 2005 WRX.
You do not need to remove the OEM dust Shields with these spacers. However, the brake calipers, and rotors are sold seperately.
The Kartboy part # for these brackets is KB-022, and they are sold as a pair only.
Click Here to order your Kartboy 2-Pot Brake Adaptor Brackets - $225.00
These have been hard to come by for quite some time, but we finally got in a good sized shippment so we have these in stock and Ready to Ship!
The Cusco Brake Cylinder Stopper is designed to reduce the unwanted flex of the brake master cylinder when the brakes are applied. Limiting this movement means that more of the force that you apply to the brake pedal is directly applied to the brake calipers, substantially improving pedal feel.
This works well paired with Stainless Steel Brake Lines.
This part fits the 2002 - 2007 Subaru WRX and STi.
Cusco Part # -- 666561ALHD
Please note that the car pictured above is right-hand drive, and that your part will be the same item designed for the left hand drive vehicles.
Click Here to order your Cusco Master Cylinder Brace - $114.00
__________________
303.402.5142
Contact us at:
FlatironsTuning.com is offline   Reply With Quote
Old 11-25-2009, 06:22 PM   #2
FlatironsTuning.com
Member#: 171650
We stock both the Hawk HPS and HP+ Compound pads for a wide variety of applications, and if you aren’t sure which one is right for you, we are happy to answer any questions that you have.
The Hawk HPS Compound pad is perfect for someone who wants better performance than the OEM pads offer, but doesn’t want to worry about brake dust, or squeaking. These pads behave almost exactly as the OEM pads do, but offer better initial bite, as well as more linear pedal response, but they are still very easy on the rotors. They are sufficient for some spirited street driving, or light track use. If you are going to drive at the track, especially with a higher horsepower car, We would recommend a more aggressive brake compound.
Hawk Performance HPS material provides advanced braking characteristics to enhance your driving experience. This unique Ferro-Carbon compound combines the safety and quality of Aerospace design partnered with the braking technology of Motorsports. HPS is one of the first materials to pass the new FMVSS 135 government safety test. Performance, safety, & quality are the trademarks of this material.
Features:
- Long Pad Life
- Extremely low dust
- Gentle on rotors
- Virtually noise-free
- High friction/torque hot or cold
- Much improved braking over OE
Click Here for the 2004 - 2009 STI Front HPS Pads
Click Here for the 2004 - 2009 STI Rear HPS Pads
Click Here for the 2002 WRX Front HPS Pads
Click Here for the 2002 WRX Rear HPS pads
Click Here for the 2003 - 2005 WRX Front HPS Pads
Click Here for the 2003 - 2005 WRX Rear HPS Pads
Click Here for the 2006 - 2007 WRX Front & Rear HPS Pads
Click Here for the 2008 - 2009 WRX Front & Rear HPS Pads
Click Here for the 2005 - 2009 Legacy GT Front & Rear HPS Pads
Click Here for the 2005 - 2009 Outback XT Front & Rear HPS Pads
Click Here for the 2004 - 2008 Forester XT Front HPS Pads
Click Here for hte 2004 - 2008 Forester XT Rear HPS Pads
The Hawk HP+ Compound is Hawk’s entry level track pad. The nice thing about this compound is that it doesn’t need to have any heat in it for it to work, so it can still be used on the street. (We have even driven on them in the winter here in Colorado with no issues though we don’t necessarily recommend this) Because it is a track pad, this compound will dust quite a bit, and it will make a reasonable amount of racket when you are driving on the street. Since it is a more aggressive friction compound, it will also wear your rotors more quickly, so we recommend using Cryo-Treated rotors if possible.
But at the track, you will be surprised how much of a difference these pads make even compared to the HPS compound. They offer much better initial bite, and are extremely linear. They are perfect for mild to moderate track use, and if you are looking for a pad that you can put in at home, and drive to the event with, this one is worth trying. Also, before you go out and spend a lot of money on a big brake kit, you owe it to yourself to try a pad of this caliber first. You will likely be surprised how much of a difference the HP+ pads can make.
Hawk’s HP+ brake compound is designed for Auto-Cross and other racing enthusiasts who drive their race vehicle to the race track. It is designed to be a true race/street pad that provides exceptional stopping performance over a wide variety of temperature ranges.
Warning - Due to the dramatic friction levels produced by this product, increased noise, dust, and pad & rotor wear may be noticed.
Optimal Temperature – 100 – 900 Deg F
Click Here for the 2004 - 2009 STI Front HP+ Pads
Click Here for the 2004 - 2009 STI Rear HP+ Pads
Click Here for the 2002 WRX Front HP+ Pads
Click Here for the 2002 WRX Rear HP+ pads
Click Here for the 2003 - 2005 WRX Front HP+ Pads
Click Here for the 2003 - 2005 WRX Rear HP+ Pads
Click Here for the 2006 - 2007 WRX Front & Rear HP+ Pads
Racing Brake ET500 Compound Pads
The ET500 compount falls between the Hawk HPS and HP+ Compounds. If you want a pad that is a bit more agressive than the HPS but don't want to deal with the noise and rotor wear that can come with the HP+, this is the pad for you.
We have been trying out these pads for a while now, and are very happy with them. If you want something more agressive than the HPS, but are concerned about noise and dust (but are willing to live with a little of both), these are a perfect option. They are a great street pad, and are definitely up to some light track duty as well. If you are doing more agressive track sessions, then we would recommend the HP+ though.
- This compound is offered for the adventurous drivers who:
- Do not like loud squeaking
- Do not like a lot of dust
- Do like extended rotor life
Being these pads are streetable therefore they are not intended for intensive and continuous hard braking over the temperature and speed limit on the race track, otherwise excessive wear may occur.
ET500 Series Characteristics:
Excellent Modulation
Consistent friction and torque output
Run from ambient temperature (even in cold winter morning)
Extended life if they are used under the temperature guide
Affordable pricing
Performacne Street Break-in Procedure:
All brake pads must be bedded-in with the rotor they will be used against. Even though performance street pads have been burnished at the factory, a transfer film must be generated at the pad and rotor interface for optimal performance. Whether you have new or used rotors, you must follow the bed-in steps listed below to maximize brake performance.
After installing new brake pads, make 6 to 10 brakings* from approximately 30-35 mph (do not go below 25 mph) applying moderate pressure.
Make an additional 2 to 3 hard brakings* from approximately 50 to 55 mph (do not go below 40 mph).
Allow 15 minutes for the brake system to cool down.
Caution:
* As you make these brakings, make sure you never drag the braking to a complete stop.
Do not sand or grind the brake pads or rotors after this burnishing procedure has been completed.
Your performance street pads are now ready for driving!
Click here to order ET500 Pads for your 2004 - 2009 STI
Click Here to order ET500 Pads for your 2002 - 2005 WRX
Click Here to order ET500 Pads for your 2006 - 2007 WRX
We Have Power-Slot Rotors In Stock!
Excessive heat can cause resins in your brake pad to vaporize or “outgas.” As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surface and inhibits performance. Here’s where Power Slot’s slotted brake rotors make a big difference.
Power Slot’s exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, the Vac-U-Slot helps push water off the braking surface for better stopping power.
Power Slot slotted brake rotors are finished in a military-spec Type II/Class II Cadmium plating for the ultimate rust resistance. Although contact with the brake pad will eventually wear out the plating on the braking surface, Power Slot’s Cadmium plating continues to protect the internal cooling vanes that provide critical structural support for the rotor.
For our most performance oriented customers, such as club, and auto-Cross racers, we recommend Power Slot’s Cryo-Treated rotors.
What is cryogenic treatment? Deep cryogenic treatment is a one-time process that permanently improves the performance and service life of metals from brake torots to gear sets. Using a proprietary computer-controlled process, the metal is cooled gradually to -300 deg. F and then slowly returned to room temperature and heat-cycled as the final step.
Although not apparent to the naked eye, the improvements to the rotor are significant. The cryogenic treatment process increases tensile strength and gives the rotor an extra level of protection against warping.
We have performance tested these rotors on the Flatirons Tuning Project Car.
Click Here to order Power Slot Rotors for your 2002 - 2009 WRX
Click Here to order Power Slot Rotors for your 2004 - 2009 STI
Click here to order Cryo-Stop Plain Cryo-Treated Rotors for your 02 - 09 WRX
We also have DBA Rotors In Stock!
The 4000 Series Wiper-Slot rotor has a unique 6x6 slotted design for extreme stopping power on the road and the track. As with every DBA rotor, the 4000 Series rotor bolts right onto the vehicle with no mechanical changes needed.
DBA's mid-series, enhanced-performance, slotted rotor features Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
''Kangaroo Paw'' is a patented, high-tech disc rotor ventilation system designed and manufactured in Australia by Disc Brakes Australia and available on rotors for select applications. "Kangaroo Paw" technology delivers significantly improved braking performance. Even under extreme braking conditions. Kangaroo Paw rotor designs run cooler, are stronger, and outperform traditional straight-vane disc rotors.
The ''Kangaroo Paw'' design features a series of 144 diamond- and tear drop-shaped pillars and columns individually spaced between the rotor faces.
This system provides two key advantages.
First, is the ability to cool the rotor faster than ever before. As the disc rotor rotates, aerodynamic turbulence around the individual pillars and columns is generated, increasing the force of hot air out from within the internal areas of the rotor.
Second is increased dimensional stability across the disc rotor directly achieved by the individually spaced pillars and columns.
These advantages increase the disc rotor's efficiency by as much as 20% when compared to conventional rotor designs. A 20% increase in disc rotor efficiency directly translates to reduced brake operating temperatures, brake fade, disc rotor stresses, disc thickness variation, run-out and shudder.
All 4000 series rotors also benefit from DBA's "Longlife Slotted" design. The rotors are manufactured to QS-9000 quality standards using premium grade materials with a high iron content and dense metal matrix resulting in long wear and safe, consistent stopping power.
- Unidirectional slotting (left and right) increases pad bite, reduces fade and delivers exceptional braking performance.
- Slots continually de-glaze the brake pads improving efficiency and reducing rotor scoring.
- Slots even out wear across the brake pad faces, increasing the effective contact area and extending rotor life.
- Slots help dissipate water when driving in poor weather, as well as pump away dust and dirt.
- Slotting also combats "out-gassing," where gas (from the pad bonding agents) can form a cushion between pad and rotor, greatly reducing braking power.
Click Here to order DBA Front Rotors Rotors for your 2002 - 2009 WRX
Click Here to order DBA Rear Rotors for your 2006 - 2007 WRX
Click Here to order DBA Rotors for your 2005 - 2009 Legacy GT
Old 11-25-2009, 06:23 PM   #3
FlatironsTuning.com
Member#: 171650
Flatirons Tuning is a Tein Authorized Dealer! We have installed various sets of Tein Coilovers on our cars, as well as our customers with great results. And they have so many kits to chose from, there is most likely a kit that will allow you to set your car up the way that you want to. If you ahve any questions, please feel free to PM us, or send us an e-mail.
Need a second set of TEIN wrenches? Lost yours that came with your coilovers? Or just want the fancy new Chrome Vanadium ones? Flatirons Tuning has got you covered.
The latest version of the TEIN Coilover Wrench includes more features, and a new Chrome Vanadium finish. Three different arcs are incorporated so they can be used on both current and past TEIN products to adjust spring seats, seat locks, and body locks with 70 -90mm, and 132mm outer diameters. Also includes a square hole for 1/2 inch drive socket wrench, 17mm hex for most damper top nuts, and tip extension for use to hold coilover in place while tightening/ loosening locks.
Additional Features:
• Various arcs to accommodate 70-90mm, and 132mm O.D. seats and locks
• Only 6mm thick allowing for more space in tight areas
• Square hole for 1/2 inch drive to be used with breaker bar or torque wrench
• Extended tip can be used to hold damper for ease of seat/ lock adjustment
• Chrome Vanadium finish for improved durability
Click Here to get your set of Tein Coilover Wrenches - $24.00
The EDFC (Electronic Damping Force Controller) makes it possible for the driver to control the damping force at the touch of a button while in the driver's seat.
This is accomplished by controlling incrementally stepping servo motors installed on each shock absorber. Because the damping force can be controlled with such ease, the driver can adjust the suspension while on the road to suit all road/track conditions.
Allows for three suspension presets, as well as 16 degrees of adjustability for both front and rear for fine tuning.
Please ensure you are ordering the correct kit for your application! The part numbers listed in the variants are the motor kit portion, which is what varies between coilover models. If you are not sure which EDFC kit you need, give us a call at 800-830-6675 and we can look it up for you!
This is the entire EDFC Kit, which includes the EDFC Brain as well as the 4 Stepping Servo Motors.
Click Here to order your Tein EDFC Kit - $418.00
Tein has two different OEM replacement springs available. The H-Tech's will give your car a slightly lower stance with improved handling, and the S-Tech's will give your car a very agressive stance. We don't recommend the S-Techs on the OEM struts, and we also strongly recommend the use of a Whiteline Roll Center Adjust kit with them as well. Here is more information about each.
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling.
The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more aggressive appearance, added performance, and excellent comfort. Includes a one year limited warranty against manufactures defect and sag.
Click here to order the Tein H-Tech Springs
TEIN S.Tech Springs are a great step towards more performance oriented suspension tuning without breaking the bank or compromising much ride quality. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability.
Designed to be used with OEM or OEM replacement shocks.
Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty for manufacturing defect.
Click Here to order your Tein S-Tech Springs
Tein Basic Coilovers for your Subaru
Drivers will feel an increase in stability and grip, while maintaining good ride quality on the street and freeway. A shortened shell case is utilized to allow for better ride and improved performance at lowered ride heights. BASIC damper is a great option for consumers wanting a simple and quality made coilover. Each application is test fitted and road tested to ensure the best possible balance between comfort and performance on the street. Includes ride height adjustment to give your vehicle a minor to major drop.
• Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• Ride Height adjustable via spring seat
• Powder coated damper body with Zinc coated threaded section
• 1-year Manufacturers Defect Warranty
• Rebuildable -- Can send off to TEIN for revalve/rebuild
Click Here to order Tein Basic Coilover's for your car
Tein Super Street Coilovers
The TEIN Super Street damper kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course.
Includes both ride height and 16 levels of damping force adjustment to allow the driver to dial in the suspension for various road conditions.
EDFC Compatible for certain applications.
TEIN's Super Street kit with Upper Pillow Ball Mounts includes the upper mounts, unlike the non-Pillow Ball Kit. The upper mounts increase steering response, and allow for EDFC compatibility. On strut type vehicles, the front upper mounts will include camber adjustment plates.
• 16 way adjustable dampers, compression and rebound combined
• Pillow ball upper mounts for increased steering feel
(some applications may include hardened rubber mounts instead of pillowball type)
• Upper camber adjustment on front for strut type vehicles
Click Here to order your Tein Super Street Coilovers with Pillow-Ball Upper Mounts
Click Here to order your Tein Super Street Coilovers without Pillow-Ball Upper Mounts
Tein Flex Coilovers
TEIN has used its years of experience in motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, as well as provide all the adjustments needed for circuit use.
The FLEX damper Kit features the latest technology for all drivers who are seeking performance and adjustability while not totally giving up ride comfort. TEIN has incorporated separate spring perch height and shell case length adjustment, which allows the suspension to retain more stroke.
The FLEX damper kit includes pillow ball upper mounts, 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
• Ride Height adjustable via threaded body and spring seats
• EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
Click Here to order your Tein Flex Coilovers
Tein Comfort Master Coilovers for the 2005 - 2009 Legacy GT
The Comfort Sport Damper has been specifically designed for drivers seeking to improve performance without sacrificing ride quality.
Vehicle sway is reduced to increase stability during cornering and increase handling. This coilover kit features a special fluorocarbon coating to protect against corrosion. The mono tube internal design with new MSV technology allows for smooth and quiet operation. Ride height adjustable, as well as EDFC compatible. Developed with larger wheels and tires in mind, the spring rates and damping force provides the perfect balance of performance and comfort.
For Sedan and Wagon Models.
Spring Rates:
Front: 5 kg/mm
Rear: 6 kg/mm
Uses EDFC Kit # EDK05-12120
These coilovers are a special order item from TEIN Japan. Please call to check availability if time is an issue.
• Mono Tube internal construction
• M.S.V. Technology for improved comfort
• Hardened Rubber upper mounts with silencer ring for increased steering feel
• Inverted design for strut type front and rear
• Teflon coated shock body
• EDFC Compatible
Click Here to order your Tein Comfort Master Coilovers
Tein Mono-Flex Coilovers
TEIN's MONO FLEX coilover kit has been developed for entry-level competition motorsports and advanced street driving.
Features include 16-way damping force adjustability (combined compression and rebound), mono-tube internal design, pillowball upper mounts, and EDFC compatibility. There are independent adjustments for ride-height and spring pre-load settings.
The new Mono Flex also includes TEIN's latest technological innovation, Micro Speed Valving (MSV) system, which allows the driver to feel a greater difference in damping force adjustments. Designed and developed for consumers seeking aggressive handling on the street and at the track.
• M.S.V. Technology for improved damping force adjustability
• Anodized brackets with Teflon coated shock body for heavy duty rust prevention
Click Here to order your Tein Mono-Flex Coilovers
Tein Type HG Dirt Master Coilovers
TEIN's Type HG setup is designed for rally and dirt trail racing. It meets the demands of any road surface with its individual compression and rebound damping force adjustment, as well as ride height adjustment. Utilizes a twin-tube design, and is constructed with steel for additional durability on rough courses. In order to prevent aeration that can diminish performance, a unique free piston was adapted in the construction of the HG. Developed from TEIN's extensive experience gained in Rally competitions and support.
Additional Features: • Steel Construction for added durability
• Ride Height adjustable via adjustable spring seats
• 16 16 way adjustable dampers, compression and rebound separately adjustable
• External reservoirs for additional oil capacity and increased stroke
• 3 stage powder coat
• Some applications utilize large diameter spring seats which allows both OEM and aftermarket springs to be used
• Rebuildable by TEIN USA
Click Here to order your Tein Dirt Master Coilovers
Tein Super Racing Coilovers
Developed from actual competition, TEIN was able to create a fully adjustable damper that can be easily tuned for any track and weather conditions. Super Racing Dampers utilize a full-length adjustment system to allow shock length and spring pre-load to be adjusted independently. Separate 16 - way adjustments for compression and rebound damping enable the user to fine tune for any situation.
TEIN has incorporated both camber and caster adjustment into the front pillow ball upper mounts for strut type vehicles. External reservoirs allow for added oil capacity. Spring rates and shock valving were derived from many years of motorsports support, to provide the ultimate damper for competition. Designed and tested for circuit use by advanced and professional drivers who are seeking complete damper tuning capability.
Additional Features
• Upper and lower camber adjustment on front for strut type vehicles
• Caster adjustment on front for strut type vehicles
• Dual EDFC (Electronic Damping Force Controller) compatible
Click Here to order your Tein Super Racing Coilovers
Old 11-25-2009, 06:23 PM   #4
FlatironsTuning.com
Member#: 171650
We stock a wide variety of suspension components to help you get your car set up to handle the way you want it to. We also have a number of products in for the new 2008+ WRX and STI.
We'll be continuously up-dating this thread in the future, but if you don't see what you are looking for, please check out our web-site (www.flatironstuning.com) or send us a PM.
We stock Prodrive Springs! And WRX Springs are back In Stock!
These have definitely become a bit more difficult to get than in the past, but the rumor's about Prodrive not making springs any more are definitely not true. We have both WRX and STI springs in stock:
To further enhance the dynamic characteristics of the Impreza, Prodrive has developed a high-performance spring kit for the STi, which is manufactured by Eibach. Both kits are designed to work with the factory struts.
With the introduction of the re-rated springs, the car is lowered by approximately 25mm. The lowering of the center of gravity leads to a reduction in body roll and gives improved high-speed handling, aerodynamic stability, traction levels and both steering response and weight transfer.
Click Here to order STI Springs - $318.99
New! - Whiteline Com-C Camber/Caster Strut Top Mounts
Whiteline is pleased to announce the release of the
COM ‘C’ front upper strut mounts for the majority of
Subaru models. The COM ‘C’ is a NO COMPROMISE
strut mount replacement that offers desirable camber
and caster gains with out sacrificing the ride quality or
ride height of your Subaru.
The Whiteline COM ‘C’ strut mount’s can be rotated 120 degrees
to achieve different caster gains of up to +0 deg 45min
and negative camber gains of up to -1 deg 30 min.
This part fits the following Subaru Models:
Impreza 1994-2007 All models
Forester 1998-2007 All models
Legacy 1989-2007 All models
The Whiteline Part # is KCA335
This is one pair of Front Strut-Top Mounts. Com 'C' Mounts are not available for the rear at this time.
Click Here to order your Whiteline Com-C Strut Mounts - $193.00
We Stock the Whiteline Roll Center Adjust kit!
The Front Roll Center Adjustment Kit from Whiteline is designed to raise front roll-centre geometry by using new special ball-joints, while maintaining original bump-steer by using new tie-rod ends. Changing the front suspension geometry by raising roll-centre results in substantial increase to roll resistance and significant reduction of suspension compression of the outside front wheel during cornering through improved weight transfer distribution. During cornering, this leads to significantly reduced understeer by reducing front wheel compression, as well as improved steering feel and precision and vehicle stability.
This Kit is a must for all cars that are lowered, and the more agressivly you have lowered your car, the more you need this kit.
Part# KCA313.
Kit Contains:
2 x ball-joints with dust boots and clips
2 x tie-rod ends with dust boots and nuts
Click here to order your Whiteline Roll Center Adjust Kit - $190.75
We have a number of Whiteline products for the 2008+ WRX and STI.
Whiteline has designed their Positive Shift Kit for the 2008+ WRX and STI to replace the OEM rubber bushings with a stiffer polyurethane bushing.
They stiffen up the mounts, making the transmission have less “play” or movement; thus giving more direct and secure feel when shifting.
Click Here for the Whiteline Positive Shift Kit - $43.45
Whiteline designed the Positive Traction Kit for the 2008+ STI to lock the rear subframe to the chassis. This dramatically reduces "play" or movement of the subframe, increasing the life of the rear differential, and stiffening up the rear of the car.
This will also give your 2008+ STI a more planted feel in the rear.
Click Here to order the Whiteline Positive Traction Kit - $45.86
Whiteline designed the Rear Differential Lock Down Kit to reduce movement of the rear differential. This helps to improve transmission feedback when shifting, and gives the car a more solid feel under hard acceleration.
The Whiteline Rear Differential Lock Down Kit can also help keep your rear differential in good condition.
The rear differential lock down kit (KDT903) is for the 08 WRX and STi ONLY.
Click Here to order the Whiteline Rear Differential Lock Down Kit - $34.90
Whiteline designed their Rear Camber Correction kit for the 2008 WRX and STI to give up to 0.75 degrees of - or + camber adjustment.
The stock suspension does not offer any adjustment, and this kit is essential if you are going to lower your car.
KCA326 is for the 08 Impreza WRX and STi ONLY.
Click Here to order the Whitleine Rear Camber Correction Kit - $136.10
Whiteline's end links will allow you to adjust pre-load as well as settings on a rear sway bar for the 2008 STI & WRX.
These are also stronger than the OEM end link, and are strongly advised if you are putting on a larger aftermarket sway-bar.
Click here to order the Whiteline 2008+ WRX & STI Rear Sway-Bar Endlinks - $127.80
This Whitleline kit alows you to adjust the rear camber of your car by up to 1.25 +or- degrees.
Whiteline Part # KCA399
Click Here to order your Whiteline Legacy GT Rear Camber Adjust Kit - $39.48
Old 11-25-2009, 06:23 PM   #5
FlatironsTuning.com
Member#: 171650
Cobb and Whiteline Sway-Bar's in stock and Ready to Ship!
Looking to eliminate the body roll and understeer that the standard WRX is cursed with? Look no further than the race inspired design of the new COBB Tuning Sway Bars.
The primary goal when upgrading your sway bars is to “balance” the suspension of your vehicle by increasing the spring rate, or the amount of force it takes to flex the bar. The main Chromoly splined rear bar is black zinc plated with anodized aluminum arms fitted to both ends. This new style design significantly increases the spring rate over the OEM rear sway bar by 230%, 350%, and 535% with the three different end link mounting positions.
The improvements result in the race car-like response you have been looking for! The new splined rear bar design allows you the ability to pre-tension the bar by simply adjusting the positions of the arms on the splines as well as the three positions the end links can attach to the arms. The tubular construction of the front bar, coupled with the unmatched adjustability of the rear bar makes this set a must have for any handling enthusiast!
Included with the kit are all required hardware, poly bushings, and aluminum spacer mounts. Aftermarket endlinks are recommended but not required.
We strongly recommend replacing both your Front and Rear Sway-Bars as a kit.
Click here to order the Cobb STI Sway-Bar Kit - $495.00
Click Here to order the Cobb WRX Sway-Bar kit - $495.00
Cobb's sway bars are designed to greatly reduce body roll and provide a much more predictable handling characteristic without decreasing the ride quality. Cobb bars have been carefully balanced and when used as a system, understeer is a thing of the past. To allow the driver to cater the system to their tastes, the rear bar is adjustable which can provide more or less oversteer for given conditions.
What makes these bars unique is their hollow (tubular) construction which results in a much lighter and technically superior design compared to the lesser solid bar design. This is the very reason why you'll find tubular sway bars used on high-end performance vehicles and race cars.
The tubular design is more expensive and more difficult to manufacturer but that should not be any excuse for not offering the best solution possible. From even a purely aesthetic point of view, the style of the thick, aggressive 25mm diameter sway bar easily visible from behind the car screams that you're serious about performance!!
Fits both the WRX Sedan and Wagon.
Click Here to order the Cobb Sway-Bar Kit for the WRX Sedan or Wagon - $350.00
Click Here to order the Cobb Sway-Bar kit for the STI with Standard Mounts - $350.00
Click Here to order the Cobb Sway-Bar Kit for the STI with Adjustable Mounts - $450.00
Click Here to order the Cobb Sway-Bar Kit for the Legacy GT - $380.00
We have lots of Whiteline Sway-Bar's in stock!
Whiteline offer's a variety of choices when it comes to Sway-Bar's, and we have most of them in stock. They Start at $174.00 and go up depending on diameter.
Whiteline Automotive has been developing and manufacturing suspension components for over 40 years in Australia. They also specialize in producing a wide variety of suspension components for Subaru’s, and offer a number of different sway-bar options.
All Whiteline Sway-Bars are constructed of solid high-grade steel, and most of Whiteline Sway-Bars are available in either 2-way or 3-way adjustable versions.
A 3-way adjustable bar is rated at its neutral setting, which is the middle hole on the bar. If you mount the endlinks to the bar using the soft setting (making the lever arm longest, or the furthest hole away from the sway-bar mounts), this will reduce it’s effective diameter by approximately 1mm. Mounting the endlinks in the stiff setting (with the shortest lever arm) will increase the bars effective diameter by aproximtely 1mm.
So a 3-way adjustable 22mm bar can be set to be either 21mm, 22mm, or 23mm.
A 2-Way adjustable bar is rated at its neutral setting which is actually in-between the two mounting holes on the bar. The softer setting will actually decrease the bars effective diameter by approximately .5mm, where as the still setting will increase the bars effective diameter by approximately .5mm.
So a 2-way adjustable 20mm bar can be set to either 19.5mm, or 20.5mm.
Click Here for Sway-Bar's for the 2008+ WRX and STI
Click Here for Sway-Bars for the 2002 - 2007 WRX
Click Here for Sway-Bar's for the 2002 - 2007 STI
Click Here for Sway-Bar's for the Legacy GT
Click Here for Sway-Bars for the Forester XT
You Need the Flatirons Tuning Subframe Lock-Down Kit!
Both the Perrin Rear Sub-Frame Lock-down Kit, and the Cusco Rear Power Brace are designed to improve your car's handling by minimizing movement in the rear sub-frame. Both make a solid improvement, and do make the car feel more stable when cornering.
We have tested both on the Flatirons Tuning Project Car, and have found that though they work well on their own, they perfectly compliment each other, and reduce rear sub-frame flex almost to zero when used together. So we have decided to put them together in a kit for our customers.
Keep in mind that this will increase the noise and vibration that you hear in the cabin when driving.
Professional installation is strongly recommended.
Click Here to order the Flatirons Tuning Subframe Lock-Down Kit - $173.99
Cusco Power Braces are In Stock!
Cusco is best known for their top quality suspension products. New for 2007, Cusco has developed their Power Braces to dramatically increase the chassis stiffness in the Impreza WRX and STI. By increasing chassis rigidity, you allow the suspension to work more efficiently and your car will behave more consistently in harsh driving situations. If you have all ready upgraded your sway-bars, struts, and springs, these components will help you realize the full potential of your car’s suspension.
Click Here for the Cusco Center Power Brace - $409.99
Click Here for the Cusco "T" Power Brace - $133.00
Click Here for the Cusco Trunk Power Brace - $179.99
Click Here for the Cusco Type 2 Lower Arm Bar - $155.00
SPT Lower Chassis Brace
High-strength aluminum construction increases chassis rigidity by connecting the sub-frame to the engine cross member. Fits Subaru Impreza WRX & STi 2002-2007.
Click Here for the SPT Lower Chassis Brace - $199.95
Old 11-25-2009, 06:23 PM   #6
FlatironsTuning.com
Member#: 171650
This Genuine Subaru Impreza SPT Lower Chassis Brace is a great performance accessory that contributes to front end chassis to deliver better handling and control of your Impreza. The high-strength aluminum construction increases your chassis rigidity by connecting the subframe to the front suspension engine crossmember underneath your Impreza.
Fits 08-09 WRX And STi ONLY.
Subaru Part Number SOA8431120
CLICK HERE TO ORDER 08-09 WRX & STi Subaru Impreza Lower Chassis Brace MSRP $199.95 ON SALE FOR$169.99
High-strength aluminum alloy bar increases chassis stability by providing additional stiffness to the front upper suspension area.
Fitment includes Subaru Impreza WRX & STi Years 08-09. And the 09 Forester non turbo.
WILL NOT FIT THE FORESTER XT
The Subaru part# is SOA8431130
CLICK HERE TO ORDER SPT Strut Bar for the 08-09 WRX/STi and 09 Forester non turbo $229.95 ON SALE FOR $179.99
We just picked up Buddy Club, and have some super duper cool stuff from them.
First off are their D1 Spec Coilovers for the 02-07 WRX and STi. We have these at an introductory price of only $1080 plus shipping!
We also have their Racing Spec Coilovers, which are also specially priced at $1424 plus shipping. We have these for the GC's as well as GD's from 93 all the way up to 07.
Old 11-25-2009, 06:24 PM   #7
FlatironsTuning.com
Member#: 171650
For Space
Old 11-25-2009, 06:24 PM   #8
FlatironsTuning.com
Member#: 171650
one more still.
Old 11-30-2009, 12:27 PM   #9
FlatironsTuning.com
Member#: 171650
TGIM bump.
Old 12-01-2009, 10:35 AM   #10
FlatironsTuning.com
Member#: 171650
Tuesday bump.
Old 12-02-2009, 01:27 PM   #11
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 12-03-2009, 06:22 PM   #12
FlatironsTuning.com
Member#: 171650
Thursday bump.
Old 12-04-2009, 10:52 AM   #13
FlatironsTuning.com
Member#: 171650
TGIF bump.
Old 12-10-2009, 10:37 AM   #14
FlatironsTuning.com
Member#: 171650
Thursday bump.
Old 12-11-2009, 11:24 AM   #15
FlatironsTuning.com
Member#: 171650
TGIF bump.
Old 12-12-2009, 09:10 AM   #16
FlatironsTuning.com
Member#: 171650
Saturday bump.
Old 12-14-2009, 10:41 AM   #17
FlatironsTuning.com
Member#: 171650
TGIM bump.
Old 12-15-2009, 10:40 AM   #18
FlatironsTuning.com
Member#: 171650
Tuesday bump.
Old 12-16-2009, 11:22 AM   #19
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 12-17-2009, 10:31 AM   #20
FlatironsTuning.com
Member#: 171650
Thursday bump.
Old 12-18-2009, 10:23 AM   #21
FlatironsTuning.com
Member#: 171650
TGIF bump.
Old 12-21-2009, 01:16 PM   #22
FlatironsTuning.com
Member#: 171650
TGIM bump.
Old 12-22-2009, 10:40 AM   #23
FlatironsTuning.com
Member#: 171650
Tuesday bump.
Old 12-23-2009, 11:03 AM   #24
FlatironsTuning.com
Member#: 171650
Wednesday bump.
Old 12-24-2009, 10:46 AM   #25
FlatironsTuning.com
Member#: 171650
Thursday bump.
Suspension/Brake Super Sale! Tein GT Spec Whiteline Cobb Racing Brake Hawk Kartboy! IAG Performance Suspension/Brakes/Handling 14 03-27-2008 06:10 PM
Subaru 4 pot kit missing parts Happy_Days Brakes, Steering & Suspension 63 03-06-2007 10:23 PM
Brand New : Subaru 4-pot + Pads & Defi BF-Series Oil Pressure Gauge (White) Drive4Ever Private 'For Sale' Classifieds 15 06-06-2005 03:00 PM
Subaru 4 pot kit with rotors, great deal for 1 person MastroWRX Suspension/Brakes/Handling 18 04-19-2004 09:23 AM
Best prices on Subaru 4 pots with pads, pins, and braided lines...where? M32WRXin3seconds Brakes, Steering & Suspension 28 08-18-2003 01:22 PM
