Old 11-27-2009, 10:43 AM   #1
modaddict
Member#: 95840
sold to a good bud
awaiting next car
OMGHi2U *Looking for a Crankshaft? List of Crank Manufacturers*
This thread is being created to help those in need of better rod bearing oiling at high rpm. If you're a noOB and haven't read the stickies at the top of the forum, then you probably don't know the drilling in the OEM crankshaft is less than optimal. So, with that said...........
Are you Baller?
Probably not.
Do you NEED an aftermarket crankshaft?
Probably not.
Do you want to rev over 8k with any hint of rod bearing oiling reliability?
probably don't need to on your vf39 or 20g. But hey, you're the age of 16-24 and still on daddy's teet and have his $ to spend. BTW, how's highschool or college going?
Here's a list of crank manufacturers for our engines.
Note: This may not be all inclusive so please post away if you have a company to add.
www.crawfordperformance.com
www.cosworthusa.com
www.k1technologies.com
www.furiousracingparts.com (someone needs to be the test mule)
www.cobbtuning.com (at one time they made cranks. not sure if they still do)
www.briancrower.com
www.maxspeedingrods.com (someone needs to be the test mule)
www.manleyperformance.com
http://www.tomei-p.co.jp/_2003web-ca...com-eng-e2.htm (ej22 but same 79mm stroke)
www.raw1performance.com (modifies the oiling passages in a stock subaru crankshaft. You be the judge)
http://www.rogerclarkmotorsport.co.u...?productID=659 (interesting as they have decreased the main bearing diameter)
http://www.arrowprecision.co.uk/
FWIW:
Subaru crank part numbers for EJ25:
12200AA370
12200AA400
12200AA430
Thoughts, opinions?
modaddict is offline   Reply With Quote
Old 11-27-2009, 10:47 AM   #2
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I think the the boss man crank is the billet one offered by Cosworth, but isn't it big $$?
As for Ron's crank (Raw Performance) he does alot more to it then what you listed, he just doesn't disclose exactly what he does so others don't know his secrets. It's evident the man can build a mean motor, soo....
D Money is offline   Reply With Quote
Old 11-27-2009, 10:54 AM   #3
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I think cosworth's crank is $3000-3500.
I've seen the pics Ron does to his cranks. In fact, the angles were even posted. He modifies the drilling, balances and polishes a crank.
But it's not on all of his engines.....
Old 11-27-2009, 11:49 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Cobb no longer sells cranks. I got the last Cobb Tuner Crank they had.
mick_the_ginge is offline   Reply With Quote
Old 11-27-2009, 11:56 AM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I knew that
Do you know who is the manufacturer of the crank?
Old 11-27-2009, 12:25 PM   #6
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
^Didn't Arrow http://www.arrowprecision.co.uk/ manufacture the Cobb crank. If not they also make cranks for Subaru's among many others.
John__Gotti is offline   Reply With Quote
Old 11-27-2009, 12:26 PM   #7
Maxwell Power
Member#: 190729
from the pictures I have from furious and the ones posted on maxspeedingrods, I think they are the exact same product... or the exact same scammer.
Maxwell Power is offline   Reply With Quote
Old 11-27-2009, 12:32 PM   #8
Maxwell Power
Member#: 190729
actually I retract that. I do see differences in the pictures, but they are really really similar.
Old 11-27-2009, 12:40 PM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Originally Posted by modaddict View Post
I knew that
So according to K1 they supplied "some" cranks to Cobb. They did not confirm if mine (from pictures) was one of their cranks or not.
Old 11-27-2009, 12:55 PM   #10
modaddict
Member#: 95840
sold to a good bud
awaiting next car
FWIW: I've seen some cranks listed at EN24 and others as EN40B for materials. Here are the two materials:
This was the "maxspeedingrods"
AS1442 AS1448 A.I.S.I. SAE: 4340
BS 970 1955: EN24
Typical Analysis: .4%C .8%Cr 1.7%Ni .2%Mo
Similar Specifications, Other Equilvalents Or Names: Bohler NMH; R16; VAGS Assab 705
Typical Uses:
A steel with a good hardenability which can be heat treated to a wide range of tensile strengths combined with toughness. Suitable for highly stressed gears, shafts, bolts and machine parts
This was the cosworth and the arrowprecision:
SAE or A.I.S.I., DIN:
BS 970 1955: EN40B
Typical Analysis: .25%C 3%Cr .6%Mo
Similar Specifications, Other Equilvalents Or Names: Hykro
Typical Uses:
Offers a medium strength core combined with good ductility and shock resistance. Nitriding produces a very hard wear resistant surface
Old 11-27-2009, 01:30 PM   #11
blackacres
Member#: 134821
2006 STI
I have a Brian Crower crank in my motor, I'm not really sure who made this unit.
But it was interesting to read a while back that a member on here, I think it was mick_the_ginge ^, had the same problem mounting his FW to his Cobb crank.
Ended up that the raised boss on the FW end of the crank, was a few thou larger in dia. than the opening in the FW!
As the problem was identical, I am guessing they were manufactured by the same company.
My tuner ended up sending the FW out to open up half the depth of the hole, so it would fit over the boss on the end of the crank, but allow the pilot bearing to still be a press fit from the other side.
From what I understand the Manley crank is very good quality and value.
Mick discovered his fitment issue at the same time
blackacres is offline   Reply With Quote
Old 11-27-2009, 02:14 PM   #12
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Yeah, that's crazy! $3,500 + the cost of the rest of the motor/head build. You can end up with a $20,000 motor! lol
I'm pretty sure he doesn't cross drill them any longer. Your post kinda made it sound like Ron didn't offer a good crank or something.
Old 11-27-2009, 02:33 PM   #13
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Anyone know how the K1 billet crank stands against the Cosworth version? other than cosworth at more than double the price.
DemiSlayer is offline   Reply With Quote
Old 11-27-2009, 02:33 PM   #14
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Take it at face value and don't read into it. I'm not in high school. "you be the judge". There's enough info on nasioc to figure out if you want this to be done to your crank or not.
http://www.tomei-p.co.jp/_2003web-ca...m-genesis.html
click on EJ SPEC and look at that price.
Old 11-27-2009, 03:39 PM   #15
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
haha you're real cool dude.
Old 11-27-2009, 04:16 PM   #16
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
MSRP $23,500.00 (USD)
^for the lazy
Thug Nasty is offline   Reply With Quote
Old 11-27-2009, 04:19 PM   #17
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Hey, don't get your panties in a bunch. You came into MY thread remember. Don't let the door hit you.
Old 11-27-2009, 04:25 PM   #18
Agile Auto
Member#: 91335
There a few differences. The one is most important for me is oiling for rods.
You can find more info about cosworth here
Agile Auto is offline   Reply With Quote
Old 11-27-2009, 07:34 PM   #19
ScorpionT
Member#: 195677
Ive seen K1 cranks make 1100whp in 4cyl motors. They will handle anything you can throw at them, thats for sure.
ScorpionT is offline   Reply With Quote
Old 11-27-2009, 08:21 PM   #20
25rsti
Member#: 166324
Old 11-27-2009, 09:02 PM   #21
berdugo
Member#: 163108
07 EuroDM STi 2.5L
hey Ryan, this is an excellent thread you started buddy, very informative
please add the RCM team Ice crank on the list, it has very interesting specs and difference with other cranks
berdugo is offline   Reply With Quote
Old 11-28-2009, 08:59 AM   #22
DSM_Outback
Member#: 56345
93 Swapped L
Green
US Crankshaft is doing 4340 & EN30B EJ Series billets in strokes from 2.445-3.385". Disclosure: US Crank is owned by Scat.
DSM_Outback is offline   Reply With Quote
Old 11-28-2009, 09:30 AM   #23
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
No one talks about the replacement EJ205 crank that's double crossdrilled? It can't be all about the 79mm crank....
FuJi K is offline   Reply With Quote
Old 11-28-2009, 10:14 AM   #24
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Thanks for the info.
I know AMS uses the K1 cranks. I believe a K1 crank was in their 1000+hp engine in the modified mag shootout. I think a K1 crank is in their 800whp time attack monster.
Micah had a good post about K1 and the parent companies which i'd like to post. It has good information.
This is what the K1 site says:
K1 Technologies, is part of the Performance Motorsport (PMI) Group, a subsidiary of Dover Corporation, which encompasses many highly specialized companies in the field of motorsport engine components. Through the various companies of the PMI Group, we are able to meet your needs for complete engine rotating assemblies.
Dover Corporation
280 Park Avenue
New York, New York 10017
www.dovercorporation.com
JE Pistons
With 50 years experience serving the Pros, JE Pistons is the world's leader in high performance forged pistons for automotive, marine and motorcycle applications.
JE Pistons
15312 Connector Lane
Huntington Beach, CA 92649
USA
Tel: 714/898-9763
Fax: 714/891-3454
[email protected]
www.jepistons.com
K1 Technologies
With many years in the field of designing, engineering and manufacturing connecting rods and crankshafts we will do our best to provide you with great products and world class customer service.
K1 Technologies
889 76th Street SW, Unit 6
Byron Center, MI 49315
USA
Tel: 616-583-9700
Fax: 616-878-3612
[email protected]
Performance Motorsports
7201 Industrial Park Blvd.
Mentor, Ohio
USA
ProX Racing Parts
Founded in 1975, Prox Inter b.v. distributes ProX Racing Parts to practically every continent world-wide and is considered the leading brand in the engine part replacement market for motorcycles (dirt & road), moped/scooter, ATV, PWC and snowmobiles.
Worldwide Sales Office of ProX Racing Parts
P.O. Box 140
2150 AC Nieuw Vennep
The Netherlands
Tel: 31 (0)252 622485
Fax: 31 (0)252 689252
www.pro-x.com
Wiseco
For over 60 years Wiseco has been manufacturing the finest aftermarket forged pistons & performance parts for the snowmobile, motorcycle, ATV, personal watercraft, outboard marine, karting and automotive markets.
Wiseco Corporate Headquarters
Mentor, OH 44060-5396
USA
Tel: 800-321-1364
Fax: 440-951-6606
[email protected]
www.wiseco.com
I will add that link. Thanks for the information. Good to hear from you my friend. Hope the weather is treating you well in P.I.
Very interesting. Do you mind following up on this and when it is complete, come back and post the link in this thread?
Alot (if not all) of the companies listed above have a 75mm option.
You have the part number for the Subaru crank that is double crossdrilled?
Old 11-28-2009, 12:11 PM   #25
Maxwell Power
Member#: 190729
that's the Arrow crank.
Also if you go to the Arrow site, the RCM Gobstopper is on the front page.
Looking for the exhaust listing thread Speedette General Community 5 08-17-2009 02:51 PM
Looking for a Good EJ205/207 crank GeneralTJI Private 'Wanted' Classifieds 2 08-15-2008 12:04 PM
Lookig for a Complete List of SCCA Autocross Rules for Street Mod Spun Autosports Motorsports 7 04-10-2006 01:42 PM
dealers looking for these items, list your best price. also looking for used parts. David Glasscock Private 'Wanted' Classifieds 1 10-13-2003 11:28 PM
Looking for 200+hp at the crank... Spenk Normally Aspirated Powertrain 7 07-07-2002 12:17 PM
