Old 03-01-2011, 12:31 AM   #26
cbigbie191
Member#: 275192
Thanks Marco
cbigbie191 is offline   Reply With Quote
Old 03-02-2011, 03:55 AM   #27
cbigbie191
Member#: 275192
I took my car to the dealer to see if they could fix the rattles. They said they wrapped a plug in foam and it was fixed. It was exactly the same when I got it back, I took the door panel off and they did nothing. I did what Marco said and the door is perfect now...100% better.
Old 03-04-2011, 04:59 PM   #28
armilburn
Member#: 273134
I bought a pair of pioneer ts-a1673r for my 09 obs and it so happened to be that the stock speakers supplied more bass than the new pioneers but the pioneers did sound clearer. Can anybody recommend a speaker for the front? I have the stock head unit and no amp.
armilburn is offline   Reply With Quote
Old 05-22-2011, 02:01 PM   #29
acm
Member#: 272208
thank you, this is very informative. Bookmarked.
acm is offline   Reply With Quote
Old 05-22-2011, 04:32 PM   #30
th30dd7
Member#: 281451
2011 Impreza 2.5i
Camellia Red
Is this the white box that is being removed?
th30dd7 is offline   Reply With Quote
Old 05-22-2011, 07:24 PM   #31
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
Yep, that's it.
MarcoPolo360 is offline   Reply With Quote
Old 05-23-2011, 11:22 AM   #32
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Other than "Rattle," what do the the white boxes do? Meaning, why did Subaru install them in the first place?
phenryiv1 is offline   Reply With Quote
Old 05-26-2011, 03:49 AM   #33
WMBishop
Member#: 275752
2011 WRX sedan
WR Blue
@th30dd7
Thanks for the pics man! I am printing them out and taking them with me to the dealer tomorrow to show them what exactly what needs to be fixed. I went in before and I was told some part had to be ordered and had to come back once they received the part. I doubt they will remove it but hopefully they can put some sort of sound deadening material on it.
WMBishop is offline   Reply With Quote
Old 06-03-2011, 12:47 PM   #34
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Originally Posted by MarcoPolo360 View Post
Problem: Annoying rattle
Cause: Two white plastic "boxes" inside the bottom portion of both door panels.
Solution: Remove them.
Result:
Thanks! To take them off do we have to cut the OEM plastic that seals moisture off from the door panel? I'm just going off past pictures I saw of the WRX door panel.
Phil_Dunphy is offline   Reply With Quote
Old 06-03-2011, 09:46 PM   #35
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
No, you don't have to cut the weather shield.
Old 06-10-2011, 11:05 AM   #36
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
The pictures aren't showing up on these instructions anymore! I want to print them out and tackle this today. Are there any other instructions available or via a PDF file??? Let me know.
Old 06-10-2011, 12:21 PM   #37
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
http://forums.nasioc.com/forums/show....php?t=2180530
Old 06-21-2011, 01:46 PM   #38
dragoryte
Member#: 277733
2011 STi 4D
Silver Spark Metallic
Originally Posted by ejhayes76 View Post
I will echo about being careful with the rear triangle sail panels. You have to pull them straight out, or the clip will break. I broke the first one I removed and had to order a replacement panel @ $7 from subaruonlineparts.
The other issue I had was removing the screw cover in the armrests. I found an eyeglass screwdriver was able to pry the cover up from the front cover of the cover.
I actually managed to break one of them putting it back in....yeah I'm an idiot . At least I didn't make the same mistake twice right?
Anyways, can someone point me to the right link for a replacement for the rear passenger side sail?
dragoryte is offline   Reply With Quote
Old 06-21-2011, 03:05 PM   #39
dragoryte
Member#: 277733
2011 STi 4D
http://parts.subarupartswarehouse.co...layCatalogid=0
Is part #8 the part I'm looking for in the picture there and is this a reputable place to buy it or should I just go to the dealer?
Old 06-21-2011, 03:52 PM   #40
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
subarupartswarehouse is reputible.
Old 09-08-2011, 11:19 AM   #41
Chutes
Member#: 289719
2011 WRX
This box definitely rattles, but I am hesitant to remove it because it looks like it has a function. If you look in the actual door there is another white plastic piece that may require that white box to be there (ignore the arrow, it's the white piece on the right side of the picture):
http://img6.imageshack.us/img6/1633/dsc7830v.jpg
does anyone know what that other white plastic piece does in the door?
Chutes is offline   Reply With Quote
Old 09-08-2011, 03:58 PM   #42
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
I have removed them from ever door panel that i have removed. No detrimental effect. Ironically, i believe that they were intended to absorb sounds between the inner door skin and the interior panel.
Fail...
Old 09-10-2011, 01:22 AM   #43
TuningIsLife
Member#: 191380
2014 Jeep Wrangler
Hydro Blue
Nice guide. Will definitely need this soon.
TuningIsLife is offline   Reply With Quote
Old 03-20-2012, 06:17 AM   #44
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I thought they had something to do with the airbags in the seats so I left them on and fixed the vibration with some foam. edit.. Oops.. old thread..
BWX is offline   Reply With Quote
Old 07-14-2012, 11:31 AM   #45
08Legacy-GT
Member#: 325949
Great writeup
08Legacy-GT is offline   Reply With Quote
Old 08-29-2012, 01:26 AM   #46
realsuv123
Member#: 329751
2011 WRX
WR Blue
Default RE: Annoying rattle
Result:
Or, you can use rubber grommets behind the screw holes and re-attach them. This also works. I'm not even sure why they put the darn things there, it's not like they're water-tight to prevent moisture or anything...
realsuv123 is offline   Reply With Quote
Old 08-29-2012, 01:28 AM   #47
realsuv123
Member#: 329751
2011 WRX
WR Blue
Great thread! Thanks for posting!
Old 12-12-2012, 03:07 PM   #48
luan87us
Member#: 335013
2013 Premium WRX 5dr
great old post! now I know how to run wires for the tweeter without having the car lol.
luan87us is offline   Reply With Quote
WRX rear door panel removal WRXBjlevy Car Audio, Video & Security 11 01-03-2014 01:28 PM
JDM Subaru Impreza GC8 STI Interior Door Panels cash-manny-money SCIC Private Classifieds 8 07-03-2009 05:13 PM
Rear door panel remove WRX_06 Newbies & FAQs 3 09-13-2006 03:01 PM
WTB: 2000-01 Impreza RS SEDAN rear door panels Texas25RS Private 'Wanted' Classifieds 1 11-08-2005 03:01 PM
STi rear door panel removal - window switch trim? das Car Audio, Video & Security 1 08-18-2003 02:02 PM
