Notices
Old 11-29-2009, 10:57 AM   #1
notraceready
Member#: 64556
2003 Stg 4 WRX sedan
Default Dyno tune: 2.5 hybrid - Dom 2.5R - 93 octane - 338 whp
Event: dyno tune
Car: 2003 WRX
Ambient Temp: Run conditions were 73.25 degrees F
Elevation:Unknown
Weather: Indoor tune in November
Tuner: Jorge at P&L Motorsports, Franklin Park/Chicago, Illinois
Dyno Info: Dynojet
Peak HP at RPM: 337.63 @6270 rpm
Peak Torque at RPM: 326.74 @ 3550 rpm (uncorrected)
Baseline hp/tq for a stock on same dyno: Unknown
Target Boost: 20psi
Target AFR: ~11:1
Fuel: Unleaded 93 octane
Engine/Power Modifications:
Raw Performance's ej25 street series short block
03 WRX heads
accessport
Blouch Dom 2.5r (ppc'd)
DW 850 injectors
P&L highFLO intake
aps inlet, aps tmic
GrimmSpeed ewg with tial 38mm wastegate
catless tbe
wrapped Ingen crosspipe
coated TGV deletes
phenolic intake manifold spacers and ppc'd manifolds
Driveline Modifications:
Act sport clutch
act streetlight flywheel
Suspension Modifications:
Crucial springs
koni strut inserts
hotchkis front/rear sway bars
Cusco ft/r strut bars
group-N tranny and motor mounts
ingalls pitch mount 17" SSR Comp wheels
Wanted it tuned with 50-50 meth/water but *my SMC water injection kit wasn't working when tuned so I'm gonna replace it with another kit and get tuned with meth injection in a month or so. Anyway, I think those are the primary power mods.
Ended up getting 338 whp and 327 torque at 20 psi on P&L's dynajet. I'm happy with those results and expect 360+ with alky. I was hoping for around 350-375 whp so the end result should be just what I wanted. The turbo spools nicely as I hit peak torque by 3500 rpms or so.Boost hits fast and holds rock solid. Very smooth delivery of power.
Here's the plot posted on fanatics for anyone interested:*
http://www.WRXFanatics.com/index.php?showtopic=61181
notraceready is offline   Reply With Quote
Old 11-29-2009, 11:50 AM   #2
rexblake
Member#: 178426
2010 S4
Gray
Very nice. Is that the new 2.5xt-r?
rexblake is offline   Reply With Quote
Old 11-29-2009, 12:24 PM   #3
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
subcribd for engine lifespan. hope it works cause i'm building one too!
maxpowr is offline   Reply With Quote
Old 11-29-2009, 12:38 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Thanks for getting the info, now re-open for bidness
Copy and save that plot from the other forum, then host it on flickr or Photobucket. From flickr, just copy the image and paste it here. From Photobucket, copy and paste the IMG code (4th of 4 formats in the list).
Audiosavvy is offline   Reply With Quote
Old 11-29-2009, 07:29 PM   #5
notraceready
Member#: 64556
2.5xt-r...boy, I don't know. Purchased 3 months ago so probably not. When did the xt-r come out?
Maxpowr, good luck with your build. I've got 3000 miles on the engine at this point. I'll try to get the graph displayed.
Old 11-29-2009, 08:55 PM   #6
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
good luck to you and your subaru my friend.
Old 11-30-2009, 11:30 AM   #7
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
The xtr came out some what recently so im assuming you have the OG 2.5R polkapickle. Its a gread turbo IMO...
rexworx is offline   Reply With Quote
Dyno Tune: IAG makes 409whp on 2.5L + Prototype Blouch DOM 3.0 XT-R IAG Performance Proven Power Bragging 155 07-13-2011 07:06 PM
Dyno tune: P and L, 93 octane, Dom 2.5R, 2.5 hybrid, meth makes 366whp notraceready Proven Power Bragging 1 04-22-2010 12:20 PM
Dom 3 or Dom 2.5 or Dom 1 or FP Green? Want ~400 whp with quickest spool? 2.1 stroker NITROS Built Motor Discussion 10 10-26-2009 12:40 PM
2.5 hybrid whp/bhp question? flon3y Built Motor Discussion 25 01-13-2007 01:44 AM
2.5 WRX w/ VF22: 93 Octane 302 WHP- 303 WTQ speedy gp Proven Power Bragging 28 08-08-2004 02:09 PM
