Old 11-29-2009, 04:01 PM   #1
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
Default is there supposed to be play in the power steering pump pulley?
Im trying to diagnose a high pitch sound at idle...and I think it might be the power steering pump I took the belt off whcih is only a month old and the pulley moves in and out some ...is this normal? Would this be causing my new belt to leave rubber shavings around the front area of the motor?
thanks
japspecjohn is offline   Reply With Quote
Old 11-29-2009, 06:11 PM   #2
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
oh yeah besides the noise and the pulley the power steering itself works fine though
Old 11-29-2009, 06:12 PM   #3
davis10
Member#: 70011
Ummm ... yea .. i think you need a new pump, thats not normal.
davis10 is offline   Reply With Quote
Old 11-30-2009, 06:23 AM   #4
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
cool thanks...i figured it wasnt normal...just new to subarus...can i run the car with no alternator belt for like 5 min to double check for the noise or is that not recomended?
thanks
Old 11-30-2009, 05:35 PM   #5
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
anyone
Old 12-01-2009, 06:41 PM   #6
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
there may be minimal play there. you can have some. how much are we talking about?
indytruckboy is offline   Reply With Quote
Old 12-01-2009, 07:05 PM   #7
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
1/8" about Im gonna pop the belt off tomm. and look again.....my belts are leaving rubber shavings in the engine bay aswell causing a burnt rubber smell... which idk why arghhhh
Old 12-02-2009, 01:47 PM   #8
Member#: 227521
2004 WRX
AKA "Ashy Larry"
Sir,
You need to get that P/S pump replaced or looked at by someone else that is more familiar with subaru's. That could very well be the reason why you have rubber shavings in your engine bay. Also, The abnormal wear on your belt could be where your noise is coming from.
- Joe
Joe@wrxbrakes is offline   Reply With Quote
what is the Test mode connector for and is it supposed to be plugged in together? CCTXRS Electrical & Lighting 2 10-24-2007 05:11 AM
Um... Is that supposed to be there? Nanners Canada Region Forum 12 06-27-2005 05:46 PM
Is there supposed to be a hole through the cat material in the stock uppipe? atf78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-07-2002 05:28 PM
Is there supposed to be a washer w/ Drain plug? STi-Nismo Dood Newbies & FAQs 10 10-01-2001 01:43 PM
Is there supposed to be an underpan????? samurai General Forum Archive 1 05-19-2000 11:30 AM
